I've owned a Freestyle for over a year and a half, and I don't believe I have ever been over 2300RPM yet. Higher rpm's just don't occur in day to day driving.
I also own another Freestyle with over 30k, and have never heard this sound. Any ideas are welcome.
I recently rotated the Goodyear Assurance tires on my 2005 FS AWD (front to back/back to front, crisscross) and I have noticed a vibration ever since. I checked the tire pressure and it is fine. I even swapped the front/rear back to their original sides but the rears are still on the front the the fronts are still on the rear (hope that makes sense). Anyway, I was wondering what might be causing this vibration which occurs at about 55mph and continues up to and sometimes over 65mph. When I got the new tires back in late August, the dealer did a 4-wheel alignment and the car was glass smooth until I did the rotation. Is is necessary to have the tires balanced and an alignment again just because the tires have changed location? I've got about 600 miles on the tires since the rotation and don't want to cause uneven wear since they have only about 6,700 miles on them.
Thanks for any and all input.
Regards - M. J. McCloskey
2005 Freestyle AWD Limited
By not rotating them, you don't get into messes like this!
Of course, if you've bought tires from a dealer who will rotate them for free, then this argument doesn't work...except for the part about not getting yourself into messes like this. THAT's still valid!
Since the Haldex AWD system sends most of the power to the front tires under normal driving conditions the fronts will wear faster than the rears. If you never rotate your tires as time goes on the fronts will spin faster than the rear tires. This discrepancy of speed between the front and the rear will continue to increase as the tires wear and will cause excessive wear on the AWD system and could even cause a very expensive premature AWD system failure.
So, if you have an AWD Freestyle please rotate your tires for the sake of your AWD system! For the same reason you must also purchase your tires in sets of 4 with an AWD vehicle, and never mix and match different tires on the front and the back.
BTW, there is a Freestyle Tire discussion if anyone wants to discuss these issues further.
- Chad
Thanks to those that have provided their POV regarding my vibration issue. I have since put the tires back in their original postion before the rotation for now with no noticable vibration. I will make arrangements w/the Ford dealership to rotate and balance them in the near future. My intent on rotating them myself was to save the $22.95 the dealer charges (even though I got the tires from them) plus the time to/from the dealership plus waiting around. One would assume that changing the postion of the tires w/only 4K miles on them would not produce vibration. Apparently when installed, each tire was balanced on the car based on position, so moving them around would upset the balance. I invested several hours of my own time only to end up having to get the tires rotated at the dealer. The mileage since the rotation/vibration issue is low, so I feel there was no significant harm done to the tires. I've rotated tires on my other vehicles w/o issue in the past, but since AWD is part of the equation, I will be forced to have the dealership handle this task.
With a bit over 31K miles I am still quite pleased with my FS and hope to accrue many more trouble (and vibration) free miles.
Regards -
M. J. McCloskey
Tires for the Freestyle
Rumor has it that Costco is doing their Michelin tire coupon beginning in early January btw.
Mark.
Thats what they said about the a/c and persistence pays...after three times back and forth they found a pinhole size freon leak which worked once fixed.
Any ideas?? Or has this happened to you.
thank you...Kara
FUELGAUGE OP
1/2 - E
This is the second time I have experienced some wacky behavior with the fuel gauge. Both times while driving on the open highway with about a 1/4 tank or more showing on the gauge it suddenly drops to show completely empty!
The latest was a week or so ago. I left to visit my daughter with a 1/2 tank and while returning I looked down to see the gauge, which was on 1/4 tank, suddenly drop to completely empty. I tried to memorize the exact wording of the warning and I'm sure of everything except whether it was "gauge" and not "level". (My memory is about as long as my......Hold up, that's a story for a different forum!)
In any case, I reset the message so I could check how many gallons I had used since the last fillup and it was 10.6 so I knew I had plenty of gas since the tank capacity is 19 gallons. I stopped and filled up when I got home and it took almost 12 gallons but I had driven quite a while to get home and I knew I was "safe" to do so. The info center only reported low fuel level after that and said I had 5 miles left to empty.
I checked the owner's manual to see if that message is listed and it's not. And, I haven't taken it to the dealer since my guys can't seem to find or duplicate any intermittent condition and certainly not one now that it has gas in it. Too bad it never happens when I can drive directly to the dealer so I can leave the message up on the info center.
I was just wondering if anyone else has seen this happen or knows of any TSB on the fuel gauge.
Mark.
I've been a happy Freestyle (05) user for a year and a half (30 000 km) but the car is at the dealer right now and they can't find the problem.
It started a few days ago, when turning the ignition key the RPM would rise to about 1000 and then immediately drop down to 2-300 and choke and die. This happens only when the engine is cold (which is about - 5 celcius right now).
No warning light was on on the dash and so it is harder for them to pinpoint the problem. They did some adjustment on the cam (whatever that is) and changed the oil but nothing improved. They seem a little perplexed...?
Thanks in advance for your help!
I just got the car back and didn't need to suggest the IAC.
I guess there was a TBS for this problem which simply required reprograming (re-booting?) the computer to fix the problem.
Sounds kinda funny doesn't it? Like a regular computer that suddenly doesn't respond so you do a restart.
Hummmmmm...
Not a "re-boot". They actually gave you an updated version of the software for the engine computer. The new software may be able to command a compensation for the malfunction.
A local dealer said they checked it out, performed a passenger seat zero procedure, and said that everything checks out normal. When the same thing kept happening, and I followed up to ask why, the service manager said the sensor is not very exact, its just a general setting and can be 10% or more off.
Couldn't they replace the sensor or otherwise correct this problem? Should I go to another dealer?
Mark.
Mark.
My Freestyle is only 2 years old and this is my first problem, but I'm frustrated that the ESP wouldn't cover any part of the repairs, even though they were severe enough that I needed to be towed to the dealer. At least the tow was free.
Any comments? Was I cheated?
es.I would however make them show you the exclusion in the extended warranty that negates them paying for the repair. If it is not specifically mentioned, I would raise hell. Good luck.
Mark.
