Mazda5 Owners Care & Maintenance
Discuss routine maintenance and special care issues for your Mazda5 here.
Are the very accurate?
Personally, I will probably get my oil changed every 3000 miles since that has been the standard on every other vehicle I have owned. Having said that, these newer cars that have many more electronic engine parts require less lubrification, this is why the manual says 5000-7500 miles before your first service. This is only my opinion, I am not a mechanic. Again, I would talk to the service manager and then to an independent mechanic and go with what makes sense to you. Obviously going by the vehicle's service manual recommendations is ultimately the way to go, but it can't hurt to have a few extra oil changes at the front end to baby you new vehicle.
Congrats on the new Mazda, hopefully this has been helpful.
PK.
My 04 Mazda3 comes with a cartridge oil filter that fits into a housing on the bottom of the enginer. Which makes DIY a pain the you know what and cartridge filters are hard to find.
I was wondering if Mazda made a change in the 06 Mazda5 to the screw on canister type of oil filter that everyone else uses.
Q
I did a Google search on the words "mazda oil cartridge spin filter" and found an article that details how to make the change, including Mazda part numbers for the new items you'll need. Easy as pie.
As an aside, my local dealer had a bare bones 5 speed Mazda5 a couple weeks ago. That one had my name on it, but I am not quite ready to replace the Tribute just yet. I am waiting for the remaining '05s to sell off. Hopefully there will be another frill-free 5 coming this way when I am ready.
I've seen the step by step conversion on one of the Mazda3 forums.
So far, I haven't made the conversion to the 3, since the dealership is changing the oil for free for the first 24k miles.
I initially didn't worry about it with the Mazda3 because the dealer gave me free oil changes for the first two years. But now that we've traded in the Mazda3 for the Mazda5, I think I may need to revisit the issue.
link title
Ordered step-plate, cargo-cover and other things there, quick response...
good dealer, good prices
http://www.canadiandriver.com/articles/jk/030108.htm
Here are some links on breaking in an engine. Good thing Mazda changed the software otherwise your car might have caught on fire. How loud did the engine sound in second gear on the highway?
The salesman said that was a good idea and that not many people ask to be shown how to check the fluids.
When I removed the stick, I was shocked to see that there was only a speck of orange fluid om the dip stick. The salesman said that it was a new engine and that there was fluid on the stick. When I wiped the dip stick, there was fluid, but I was still suprised that it wasn't orange on the dip stick.
Does this sound correct. I'm used to seeing orange fluid on the dip stick and would like to confirm that all is well with the transmission fluid.
D
Look for tires with a higher wear rating. That should get you a longer lasting set of tires.
I am on my way to get my first change and just want to get an idea of what I might be in for.
thanks :confuse:
zoom 500
It would suck for them to drop the plastic shield, drain the oil and THEN find out that they don't have the filter...
I use synthetic oil in my 5 because it provides better protection. And it certainly flows better in cold temperatures, so I would use it in Canada, too. It costs maybe an extra $25 each oil change, so the price is irrelevant. It does not increase gas mileage by any degree you will be able to detect. The truth is, there just isn't that much friction to overcome in Mazda's little engine; especially with 5w20 oil.
Ethanol-based gas (usually 10%) will not get you better mileage, either. Ethanol has less BTUs (less potential power)than gas. That's why fuel mileage drops significantly (35% or more) when E85 (85% ethanol; 15% gas) is used.
Price is right to $35 for the oil change + $10 for the tire rotation. I rotate my tires at every oil change as the interval to tire rotation is basically the same as the oil change
Today, I took it in to get the right side, rear shock replaced since they said it was faulty. I told them about the bump/bubble in my tire and he said that it is dangerous to have that and that I should get the tire replaced.
I'm wondering why they didn't say or notice this before when I got it serviced. And I am also wondering if it really is all that dangerous to have a bubble on the tire. I mean, it's been there for a while and nothing's happened. I also asked the technician if it was possible to get it replaced from the manufacturer since it could have been a defective tire since I haven't hit a curb or done anything out of the ordinary to cause a bubble. He said it was extremely difficult for a tire manufacturer to admit it was defective and to give a new tire and that he has never seen it happen. So, I am wondering if that is true as well.
I have an 06 Carbon Mica Gray, Mazda 5 Touring with the 17 inchers - I believe they are Toyo tires? Any advice on all the above, please? Thanks!
Check the pamphlets that came in with your owner's manual. There should be one in there about the tire warranty. I believe the tire warranty is good for 12,000 miles.
how to replace it. I have a mazda 5 2006 touring.
I called the dealer and was told the cost of the filter was
around $37.00 and would take about a half hour to install
at about $36.00. any information would be helpful.
Ricky9
Since the temps have dropped below 0 here, the rear suspension has been squeaking. This morning it was nearly -20 and both the front and rear suspension have been squeaking at the slightly bump in the road. Has anyone else experienced this? I called a dealership today and they said they have had similar complaints and that it has been serviced by clearing the ice from the sway bars and lubricating them. I hope this is all it is, and that this operation will cure the problem, because it drives you nutty to drive a new and squeaking car. My appointment is next week, so i hope it works.
Did your dealer replace the bushings with the same ones that were on the vehicle originally? If so, you would think that they'll be giving you problems by next winter. Did they provide you with any other explanation?
When I bring ours in I'd like to have all the information I can!
Of course, everytime I take it to the dealer, the weather warms up and the damned car doesn't make any noise. So, they are unable to hear it again and I have to wait until it is freezing cold again to be able to take it to them and let them hear that it is still happening. So, I don't believe that them changing the bushing has done anything to permanently alleviate the problem. It must be a design issue with the Mazda parts - unless, of course, the dealer is lying to me and has never changed them, but only lubed them up. I am thinking of actually taking the car to another Mazda service center and seeing what they can do about it, but then I feel like I am "cheating" on my regular Mazda service center since they have always been nice to me.
In any case, my noise is back and I would like to know if anyone else out there has their squeaking/crunching noise back after having it "fixed". Thanks!
