EPA lists volume in cubic feet for passengers/cargo:
Elantra........98/14
Optima.......104/14
Spectra........97/12
Manufacturer lists passenger/cargo volume:
Elantra........97.9/14.2
Optima.......104.2/14.8
Spectra........97.0/12.2
"Ride quality varied between the cars we drove, with the LX wearing the Kumho tires on 16-inch wheels the less compliant, although by no means rough or bumpy. This surprised us, as generally the taller a tire's sidewall, the more give and the better the ride, and on the Optima, the 17-inch wheels wear the lower-profile Michelin tires with shorter sidewalls. On the other hand, and probably because of the sidewall height, the EX delivered the crisper, more responsive handling. This isn't to imply the EX is a sports sedan, given its forward-weight bias and comfort-oriented suspension settings, but merely that it's the more enjoyable of the two models."
Looks like the 60 series Kumho tires are actually stiffer than the sporty Michelins. When they wear out you might want to change tires. Kumhos usually score pretty high with TireRack.com's user ratings. This might be a unique tire-- OEM tires are sometimes cheaper.
Yet, the Malibu boards had someone complaining about that--wanted an eight way seat on every car. I guess everyone's expectations change over time. I bought my last new car without air conditioning in 1980.
The first car I bought with air was a 70 Ford LTD.It was a gorgeous car,but it didnt have any power equipment.In 1980 I bought a new 1980 Toyota Corolla station wagon,and the only extra was the automatic transmission.It cost, $6000.00
BTW the 67 Plym and 80 Toyota got almost the same mileage,although the Plym had a slant 6 and the Toyota a 1.8 4 cylinder engine.Not only that,but the Plym. was much heavier.Didnt make much sense to me.
I can live with my MPG,25.5 after 3000 miles,but my Huyndai averaged 3 more MPG,which doesnt make sense.
An average of 28.5 is really outstanding for a mid-sized car. Is this from actual computations or does the Sonata compute mpg in its drivers information computer?
I now have 4k trouble free miles on my Optima, and can honestly say i'm so glad i saved my money and bought this rather than a Camry. The build quality, and refinement continue to amaze me!
The new Elantra and old Spectra are different platforms, however they do share the same motor.
Amazingly, the new 2007 Elantra feels as roomy to me as the "larger" Optima and Sonata, its just smaller on the outside.
2007 Hyundai Elantra
Height 58.3"
Headroom 40"
Legroom 43.5"
2007 Kia Optima\Hyundai Sonata
Height 58.3"
Headroom 39.8"
Legroom 43.7"
EPA figures (passenger/cargo volume in cubic feet):
2007 Elantra 97/12
2007 Spectra 98/14
2007 Optima 104/14
All 3 are EPA mid-size cars.
Bookmark | Reply | E-mail Msg
For 2007, the interior sizes of the 3 are actually all different from one another, but the Elantra and Spectra are very close, while the Optima is significantly larger for passengers.
Optima.......104/14
I do think people could conceivably cross-shop the Elantra and the Optima 4 cylinder. The Elantra is very roomy for its exterior size. It is after all in the same size category as the Bentley Continental Flying Spur sedan as well as the Bentley Arnage.
My original post was stating Elantra and Spectra are very close in size and it seemed to me you were contradicting that idea. If not, nevermind.
(the thread goes way back past posts #354 and #356 stating the new elantra was just like the optima inside)
And the Elantra is 112 cu.ft. not 102, right? A typo?
By comparing it to the Elantra, not the Sonata, I was referring to the fact that the front end has simpler struts like the Elantra, not links like the Sonata. I'm sure both cars aren't parts interchangeable.
The Sonata has one additional cubic foot of interior space and two more of trunk than the Optima. The Elantra is six cubic feet under the Optima. So in truth the Optima is closer in size to the Sonata, it just comes in slightly smaller and misses the cut-off point for full-sized.
Didn't even drive the new Elantra as I was turned off by its external looks and the Optima seemed like more car for slightly more money. The new Elantra certainly seems bigger than the last one (I owned an 01).
I find our Optima to seem considerably smaller than our Malibu Maxx. The Optima is slightly wider (European platform of the 'Bu) and seems considerably higher (even though it doesn't show as that big a difference in height). I'm 6'4 and have a great deal more room over my head in the Optima but whether or not you have two or four inches up there really makes little if any difference in the real world.
Similar equipment, 4 cylinder engines, etc. But the inner structure is no longer shared between the two. Don't know why, as it would have made more sense to share...but they didn't for the latest versions.
Just wound up paying over $800 for an oil change and steering column replacement on my 05 Maxx. This, plus constant (uncalled for by the manual) solicitations to get my transmission fluids changed, combustion chamber cleaned, and god knows what else kind of pyssed me off. In true GM fashion this one seems to have a rock steady power train but complaints about suspension and steering are starting to take over their boards. I guess every brand has their weak points.
I always thought that GM had a better dealer network than Honda/Kia but I'm beginning to wonder. At least the Chevy folks were polite and professional appearing (no experience with Kia at all other than my original delivery).
You seem to be running a bit hot and cold on the Optima. I thought you were unhappy with the mileage. Have things improved there a bit or is it still getting l2+ in town? I assume the air bag sensor is fixed for good.
I don't blame you for being frustrated on that one. Multiple attempts at safety is major IMHO. I still like the Optima a lot but my wife's been sick and since it's her car, it hasn't picked up much mileage as of this point. Planning a late month trip to Atlanta, I'll know better then.
As for my Malibu Maxx, laying out $800+ for a steering column is a bit much. Some people have complained of doing that similar repair four or five times. Hopefully the new parts are better but if I have repeat $800 expenses that WILL sour me on that car. Also a bit ticked at the dealer trying to foist unnecessary services off on me-- the one thing that I thought GM had going for it was a better, more humble dealer corps.
If I had to replace it, the Rondo might be on my short list. Liked that car a lot and if I needed the storage, and the present discounts were on in December, we might have sprung for it.
I am going to order one with the optional Sun and Sound Package(it's $1,500 and includes a 650-watt Rockford Fosgate stereo, 6-CD changer and 9 speakers nicely-placed throughout the cabin AND a sunroof). The sunroof will be nice here in sunny Arizona. There are a lot of places I want to go see here in the Southwest.
The Lancer GTS I am describing will set me back $19,615, which includes the destination charge but does not include tax and license.
The car has too many engineering pluses to mention but suffice to say the ABS w/EBD and 4-wheel disc brakes all around will be nice and safe and it has a driver's knee airbag, airbags up to my eyeballs and all around me, and a Tire Pressure Monitoring system. It will have a trip computer and a mpg-an-o-meter. Oh, it has a nice tachometer built in as well, which I tend to take rather seriously and highly value having.
Mitsubishi engineers are using the 2.0L 4 cyl MIVEC motor that was developed with DCX and Hyundai. It will produce 152 hp and 143 ft-lbs of torque to the wheels. The GTS will have a leather-wrapped steering wheel and leather-wrapped stick shift. Mitsu engineers developed a new exhaust for the '08 Lancer that directs towards the rear(earlier Lancer's strangely had their exhaust directed towards the front of the Lancer)and this has made possible being able to put a new torsional enforcement bar horizontally. This enables the '08 Lancer better handling up front. The GTS has a strut bar up front and back to help with handling.
I have looked at the '08 Lancer interior and it looks smart and neat. I can not find fault with it, at least from internet pictures of it.
I like the new wedge shape of the 2008 Mitsubishi Lancer. I love the rear end taillight design.
I love the 10-spoke wheels, too. This car is so cool looking that I simply must have one. I will strongely convince my wife that I must have one and that we need to be covered by the car's 10-year and 100,000 mile Warranty. I have bought one Kia(our 2001 Kia Sportge 4x4 now has 126,954 miles on it and is still running great...a good candidate to trade in while it still is running like a top)with the Kia Long-Haul Warranty(our '99 Kia Sephia had the then standard 5-year and 60,000 mile Kia Warranty)and it is the best Warranty in the car business.
I think that Mitsubishi's engineering team is very good and Mitsubishi sorely needs to succeed with the new Outlander SUV and the new Lancer. So we will be getting cars with lots of thought and lots of features in them for the money. That is something that I highly value, indeed.
So that's where I've been. I have decided on a '08 Lancer and I'm not researching other cars much at all now.
what would be the good price to pay for?
and how do I make a deal to lower price? (this will be my first time purchasing new car)
looking for some help guys!
Then, look up MSRP and invoice prices on Edmunds for each car you select as a possible purchase. Also find out what rebates you are eligible for as well as any incentives to the dealer you can find out about.
Subtract the rebates and incentives from invoice price, then subtract another 1% from the remainder.
That is your firm offer to buy today. Make the offer in writing at every dealership you visit. If the dealer rejects your offer, drive away to the next dealer.
If you don't start driving away then you probably will not get to buy for your price.
If no dealer sells to you, then start over adding that last 1% deduction back into your offer at every dealership. If necessary go back and do it all over again adding another 1%. The only leverage you have in this type of negotiation is driving away after they initially refuse your offer.
Oh, and if you have a trade-in, don't. Sell it privately instead.
Be nice and good luck.
I always look for "Ad Cars"... for example, if you look back at my earlier posts; you'll see that I paid only $11,000 for my Optima (sticker was ~$18,000). This is the current ad from my local dealer (http://home.quirkcars.com/wtf/k03-05h.jpg). I walked in and got all the rebates I was eligible for plus a "dealer" discount bringing the car down to $11,495. Ad cars are meant to bring people in to the dealership where savvy salesmen talk them into something else, or convince them that the car was a "misprint" or comes with dealer installed options not mentioned in the ad. Don't fall for this!!! Stay focused about only buying the "Ad Car". Currently Kia is offering a $2,000 instant rebate on 2006.5 optimas (same as 2007 model), a $400 recent grad rebate, and competitive edge rebate of $1,000. Use these to your advantage and make sure they are deducted from the bottom line. Also... Don't buy any extended warranties, LoJack, or anything aftermarket.
Settle for nothing less than 3.5k off the 2006.5 optima right now. Hurry up... they're going fast!
Hope this helps:)
But if a shopper does not have an ad like that to use the other method will get him a good deal too.
I apprecicate it!
I got another (and last) question.
just in case I get LX if I change the audio system (since I definitly need mp3 and aux jack) and let the bestbuy or circuit city people install it. would I still be able to use steering wheel audio control?
It's kind of funny, because I thought I couldn't live without my ipod, but now I find myself listening to "Left of Center" (the BEST Indie station) on Sirius all the time:)
Hope this helps!
-Z
What did the dealership do to fix your passenger airbag light? My light now stays on after somebody gets in.
