Differences between Chev C/k & Silverado.
too long of a post to explain it all..
go buy one
- Tim
Dean
I have a 99 new body style K2500 with a 6.0 under the hood. Its a Silverado LT (whatever that means)! oak
option packages (new vs old)
base=Cheyenne
LS= Silverado
LT=LT
Scottsdale? I think that was pre-C/K, wasn't it?????
but what about pop?
Scotsdale
Silverado
- Tim
We got; Ping
Slap
crack and
wobble
sounds like a hell of a breakfast cereal.
Ryan
HEHEHE
dohhh you should have seen it coming
Silverado, (which used to be the top of the line,)
They also used to make a Camper Special, and the Z-71 offroad option has been around for a long time as well, they just started writing it on the side of the pickup after 1988. Older ones used to have two shocks at each corner. As for the C/K designation, C means 2WD and K means 4WD, and they have always been around also, they do not just describe the 88-98 body style. The numbers are as follows: C-10, 1/2 ton 2WD, K-10, 1/2 ton 4WD, C-20, 3/4 ton 2WD, K-20, 3/4 ton 4WD, and so on the K-5 is a 4WD full size Blazer. After 88 they became 1500, 2500, 3500 and so on.
Now they are all Silverados(the fullsize trucks, that is), with a base, LS, and LT trim level option. Hopefully this helps clear up a few things.
I am a lifetime Chevy owner, with a 69 C-10, a 77 K-10 Silverado (fulltime 4WD), and a 98 LS ZR2 Blazer, also have owned a 69 C-50, a 2Wd 2-ton truck, a 67 C-60, a 2WD 2 1/2 ton truck, and an 83 K-20 Silverado with a 6.2 diesel, so I have a little experience with Chevrolet.
Truck has 14,000 miles on it. Had 17 miles when we picked it up. Developed problems, other than lack of power, at about 8,500 miles.
