exhaustsystem
lnhin2000lnhin2000 Member Posts: 1
dose any one know of a cat back system for
a 2000 nissan crewcab v6
  • mgdvhmanmgdvhman Member Posts: 4,157
    ....isn't that like Headers on a Chevette?....or slicks on a Yugo?
    - Tim
  • rrichf1rrichf1 Member Posts: 47
    Ohhhhh - a little sensitive are we?
    2,3 and 4? Oh man, they are doing it again...is this the works of the Tommyknockers?
    no.....but think about it!
    ....or like nitrous on a 10 speed!......what's the point!
    hehehee
    - Tim
    go zoom....might be interesting. Hey what ever happened to that vote Bush topic. Simply disappeared off the face of Edmunds....I guess it was politically incorrect.
    is not allowed here I guess?
    OOpsss....did I say that out loud?
    - Tim
    I tried to continue the free speech topic but our friend saw fit to erase the posts. The second post was just a single line stating that #3 was posted at a specific date and time.
    Seems that Meredith likes playing the role of censor!
    So, now what the supreme court referred to as the "Socially Redeming" stuff...
    My '99 Super Duty F-250 (That's a pickup truck.) with the 7.3L power stroke has a catalytic converter. (That's part of the exhaust system.) For purposes of power and mileage, does anybody know how to substitute a "Test Pipe" to insure that the converter isn't plugged? ;)
    Rich
    All you need is galvanized pipe and a mig welder...or a good friend who works at Midas.. ;)
    Thanks obyone. I was going to try it with my wire welder but the exhaust pipe is stainless. To weld it you must have the inert gas. And then the source for the ss pipe.
    JCW (The most creative automotive catalog) used to carry "Test Pipes" for catalytic converters. Unfortunately the Feds figured out that some of those tests were taking 50 or 60K miles for results. They gave JCW the choice of stop selling or court and lawyers.
    So woe is me. I'm trying to figure out if my catalytic converter is plugged and no test equipment with which to perform the test. ;)
    On the Midas deal I'll probably have to wait until I move to Nevada.
    Rich
  • oldharryoldharry Member Posts: 413
    If you can borrow a thermometer either contact or IR, check to see if the converter is substantially hotter at the back than the front, if so it is working. A working CAT is less likely to be clogged than a non-working one.
    Harry
  • kevinokevino Member Posts: 19
    paint a line down the cat.(then it would be a skunk...hehehe)
    seriously:
    paint a line down the cat then drive it for a day.
    where the cat is hottest the paint will be burning off. Thats a trick for choosing the exact spot to cut in your own H-pipe on dual exhausts.
    Actually guys, I want to "Test" for a "plugged" catalytic converter (for a few hundred K miles). ;););)
    Rich
  • pocahontaspocahontas Member Posts: 802
    Let's please continue this discussion in Accessories Topic 634, After Market Exhaust and/or Topic 593, Best intake, header, exhaust combo?. Use your copy/paste so you don't have to re-write your questions.
    This topic will be frozen to conserve on space. Happy Motoring. ;-)
    Pocahontas,
    Edmunds.com/Roving Host
