TOYOTA TACOMA vs FORD RANGER- Part XI
1424345474868
  • allknowingallknowing Member Posts: 866
    Actually I didn't mean to imply that anyone was being overly critical, and I wasn't trying to single you or anyone out. He just got several rebuttals right away and I thought he had some decent input, particularly his Vince/spoog comment. I agree with you that all makes have their faults and may I add, thanks for not trying to defend vince's (and spoog's) repetitive posts. As far as the 94 - 96 Mustang (and possibly the 97 -98 but to a lesser degree), you were lucky and, like all products, some people will not have problems with even a poor design. I personally don't know of anyone that owns a Mustang in that period that didn't have trouble with their plastic intake manifold or the air conditioning. Most have also had problems with their sway bar, check engine light coming on for no reason, etc. Ford sells a lot of vehicles, and many are great vehicles, but these would not be in that category. I've known too many with the same problems, the Ford dealer has confirmed that these years have a high probability to experience these problems, and many consumer publications like Consumer Reports list these as used cars to avoid. The newer Mustangs are supposed to better but, as I said, you were fortunate to not experience problems. They looked great and have plenty of power but I wouldn't own one.
  • modvptnlmodvptnl Member Posts: 1,352
    Actually, 94-95 were still the trusty 5.0 with aluminum intake. I do recall the plastic intake on '96 but the Cobra doesn't use it. Hang out at the Corral.net quite a bit and really don't see those complaints.(except our [non-permissible content removed] being handed to us by LS1 Cambirds)Friend did have leaky intake on '97(?) GT and Ford did fix it(something wrong with the threaded inserts, I'll agree)
    I do have direct knowledge of old toy starlets that are basically disposal because the carbs are unrebuildable and more expensive then the car. I digress, this isn't the coupe section. This is my only point: that there is no perfect mechanical appliance.
    I have fibbed just a little on the '97 Cobra. The black paint started to "leather check" (after 4 years in the Vegas sun) Ford is doing a COMPLETE strip and repaint on a car that's 4years old and has 40,000 miles. I'm driving a '01 Lincoln Town Car (either that or a Focus!!) So call it lucky but Ford has treated me well.
    Vince-Spoog?? C'mon, you know where I stand!!!
  • midnight_stangmidnight_stang Member Posts: 862
    Oil changes are pretty simple to accomplish. You can even do it yourself in about 20 minutes tops. All you need is a case of oil(see manual for viscosity and weight) two filters(Fram or Mobil 1 are good, just stay away from generics, and a oil pan. Slide under the truck, and remove the filter and drain plug in the oil pan and let it drain into the oil pan. When the oil stops dripping, put on new filter, and replace drain plug. Then fill up oil in crankcase via opening the oil cap. All this will cost you must less than 35 bucks, and is good for at least 2 oil changes.
    Discount oil places are OK, but they don't always use the exact recommended oil, or replace the crush washers(on the drain plug). Plus their filters can be iffy. Just watch them or ask first.
  • rickc5rickc5 Member Posts: 378
    First, let me say that since the Tacoma is built here in the US, this doesn't apply.
    From sometime in the late '70s until at least the 1988 model year, Toyota saved tons of money (on import taxes) by importing trucks that were not complete (additional assembly required). The trucks were missing their beds. The beds were made here in the US, painted here, and were installed at the POE (Port of Entry). The rusting probably has nothing to do with the quality of the steel, but is likely due to a lack of rust-proofing, or maybe some other "cost-saving" step.
    I didn't make this up. The owner of the Toyota dealership in Boulder, CO told me this in 1986, when I asked why the graphics decals on my new '86 SR5 were different on the bed from the cab. Even the decals on the beds were made here, not in Japan.
    Go ahead Jason, laugh if you want.
    Only pattern I see if your RPD.
    Plus I think I've posted a retort to just about everyone of your quotes, that you just ignore the ways I've discounted your sensational quotes. But here it all is again.
    Keep up the good work future Senator!
    Spoog has been this way for at least two years that I'm aware of. At one time or another, most of us have attempted to enlighten spoog, or at least get him to stop re-posting the same old quotes from ancient 4x4 magazines. Nothing has worked. He has NEVER responded to direct questions. Give it up and enjoy the other posts. This is a great forum, with lots of posters who are intelligent and open-minded (ok, somewhat open-minded).
    He must have a little text file on his desktop, so he can cut and paste it over and over again. I bet he's sitting in his underoo's right now, pretending to be a super hero fighting the evil force of Ford. Does anyone know the meaning of the word Spoog anyways? I do, but I will let others take a stab at it first...
  • indacurl2kindacurl2k Member Posts: 54
    Vince, you're a regular messiah I guess. Does your whole congregation worship the big blue oval or just you?
    Hey Vince, just for the record; please tell me again which truck is more reliable? The Tacoma is SLIGHTLY more reliable than the Ranger? Or should it read: "The Tacoma is slightly MORE RELIABLE than a Ranger."?
    The Ranger has more power, more this and more that and for less $$ too. But big deal. It's not like the Ranger has a far superior edge than the Tacoma in those areas either. I would say that the Ranger has a SLIGHT advantage in HP & torque, based on the numbers you've posted.
    I like how you tip the scales in favor of the Ranger to suit your preferences yet neglect to recognize how close the Tacoma stacks up in other areas.
    Maybe you should be a televangelist or something with that kind of enlightenment. Who knows, maybe you'll make enough money doing that to buy a new Tacoma!
    I think Vince has "Tacoma-Envy". I think he really wants a Tacoma and all of his posts are just a reflection of this. He has to justify unto himself that the Ranger is better so that he can fool himself into believing he made a "good" decision.
  • scape2scape2 Member Posts: 4,123
    Pity those who just can't stand Ranger owners who have had good reliability, quality out of thier Ford products. All Toyota owners are the same. I visit many other chats around the net and all have the same mentality that "Toyota is god" and noone can touch them as far as quality or reliability. When I point them to MSN or Edmunds they start to think a little differently....
    I have stated facts about how limited the TRD package is to the average truck user. The extra dollars spent are not worth it. This huge quality/reliability gap Toyota owners love to paint just does not exist.. These are point that you Toyota owners just hate to hear. You paid too much for a perceived huge advantage....
  • smgillessmgilles Member Posts: 252
    Thanks for the same old Banter and Rhetoric, I am starting to think you and Spoog are the same person with Bipolar disorder.
  • issisteelmanissisteelman Member Posts: 124
    That was a good one. However, I don't think Vincespoog will understand what you are talking about.
    That's cool, as long as every Ford problem from here on out is the suppliers fault, I'll go with it.
  • jrlawrence3jrlawrence3 Member Posts: 2
    Purchased my Tacoma about a month ago. So far I don't think much of it. No power - very sluggish! Terrible clunk shifting from 1st to 2nd. Engine is noisy, noisy, noisy! Cold start idle is 2000 rpm. Dealer says everything is normal(???). Am thinking about a Dodge Dakota...
    Once again...Vince refuses to see how close Toyota is in terms of performance. He won't accept it, yet he'll be the first one to point out that the Ranger is almost as good as the Tacoma from a reliability standpoint. What's more, Vince flat out HATES Toyotas. Why? Because he BELIEVES they're better and he can't accept it because he chose otherwise. It's a classic case of 'denial'. Look at the other Ranger owners on here. They state the facts without having to bash. Not Vince, he's too insecure about his Ranger.
    I don't think the Ranger is a bad truck and I have said this all along; that the Ranger and Tacoma are very close. Vince refuses to admit this. Instead he tries to paint a different picture. One that shows how powerful and mighty the Ranger is. He makes it sound like the Ranger will do mach-3 from a green light going uphill and towing a boat, traveling 1/4 mile before a Tacoma even gets out of first gear while accelerating at top speed from the same light. This simply is just not true and anyone with even half a brain knows this.
    Vince, I am left wondering if you're even old enough to have a driver's license as your childlike mentality shines through on every post you make here.
    No more childish is he than spoog though, that's for sure.
    "Vincespoog" ROFLMAO!!!
  • eagle63eagle63 Member Posts: 599
    did you test drive the vehicle before you bought it?
    A most interesting topic......
    Having worked as an engineer in the computer storage industry for my entire career, and having witnessed the finger-pointing that goes on when a hardware defect occurs in a finished product, I have reached the following conclusions as to the reason such defects occur:
    1) The specification sent to the supplier was either wrong, or incomplete. This means that the delivered component was a) built wrong (to a bad spec), or b) built using something that wasn't the intent of the contractor (not specified).
    2) The contractor tries to save money by using the cheapest materials available, and incoming inspection failed to discover that the defective part was NOT built to spec.
    3) The engineer who originally designed the part/component misunderstood the requirements, or failed to adequately test his/her design.
    The net result is that a high percentage of defective parts/components/materials can be traced to mistakes made by the contractor, not the vendor/supplier.
    Just like blaming computers rather than the operators for computing mistakes.
    Interesting, eh?
  • 96flea96flea Member Posts: 38
    I now own a 96 Ford Ranger Splash, reg. cab, auto w/2wheel drive w/ 4.0 v6. I am looking to get the Tacoma, preferably reg. cab 2.7 4 cylinder w/4wheel drive and auto. I noticed that the Tacoma has less torque and horsepower and weighs more but i have heard that it will out perform most of the Big3's v6's. Is this true? Also is the Tacoma a shift on the fly 4wheel drive? I like my Ranger but want 4wheel drive mainly due to ground clearance. I also heard of the TRD package and i don't think its available on reg. cab. Anyway how can TRD compare to actual 4wheel drive? I'm more than likely gonna need it for snow other than off roading. Any info would be appreciated.
    Reminds me of a story: An engineer for Microsoft was target shooting. After shooting countless rounds and missing the target every time he then put his hand in front of the barrel of the gun. After pulling the trigger and blowing a hole through his hand he proudly exclaims, "Must be a problem on YOUR end."
  • acf2001acf2001 Member Posts: 28
    I have changed oil before but it has been a pain in the [non-permissible content removed]. My civic and other small cars sit so low i got 'driveway scrape'. I've always used discount places to save the hassle, but now i think I will grit my teeth and do it myself on the truck to save $. After all, unemployment is on the up and up! Oh well... thanks AK and STANG for the advice. Goin to go watch Condit interview - should be interesting.
    Oil changes can be a bit of a pain on the Tacoma because of the lower engine cover. The filter can make a big mess if you're not careful. I push a small pan or a bowl into the hole on the side of the cover to catch the oil from the filter when it's removed. Some people go to the trouble of removing the cover. The location of the filter is not one of Toyota's best engineering accomplishments.
  • 1busman1busman Member Posts: 33
    I don't know where you are getting your info that a 4 cylinder will keep up with the V6's, but that's just totally untrue. I think you better drive one with a 4 banger and then try one with a V6. If you can take one up a hill, the 4 banger will run out of breath. By the way my 2001 Ranger XLT 4 Dr, runs great with the 4.0L V6. But I will tell you with 5 or 6 hundred pounds in the back and climbing a moderate grade it uses all 207 horsepower. My point is that if your not concerned about the better gas millage of the 4 banger and your willing to spend the extra money get the V6.
    no Tacoma reg. cab comes w/v6. It did w/ my old Ranger so why not the Tacoma? That sucks. I heard this joke on Arliss the other night.... what do you call a German tampon? Twatsticka.
    I will test drive Tacoma before buying it. As for where i'm getting the info its here on Edmunds. I went to specs for a 98 Tacoma and somethings not right. The Tacoma reg. cab 4x4 weighs more than the Ranger ext. cab 2wheel drive. The 2.7 claims 150hp at 177 torque and it gets worse mpg's than my 4.0v6. I admit i like smoking my tires at stop lights as for hauling stuff i don't really care. When i bought my Ranger i bought it cause Consumer Reports rated its reliability up there w/a Honda Civic, and it was only $9000 w/23000 miles, looked great (its black) and dirt cheap to insure. I had this vibration in the floorboard but found out that it was the plastic trim under the bumper flapping in the wind. Oh, and once in a while the wiper and washer comes on for no reason at all. It has 45000 miles and nothing has gone wrong yet. Hope to get 200,000 out of it.
    No v6 in a regular cab because Toyota wants you to pay for the extracab. But the reviews don't list "no v-6 in a regular cab" as a con, while Ranger always gets the "con: No v-8 available" blurb.
    Well folks I may not be getting a '01 or '02 ranger like I planned. The girlfriend is talking rings now, and boy are they going well over that 2 month salary range! I may have to settle for dropping a v-8 into my 93 ranger and save the money. Nothing wrong with my i-4 mind you, just am looking for more power and a fun, at the least expense. Guess that's another reason why I choose Ford.
  • cpousnrcpousnr Member Posts: 1,611
    The wiper issue you talk about is a repair that Ford SHOULD do when it comes in for service. The subcontractor that supplies stalk switches produced one that has a defect.
    Should be replaced for free, but you have to take it in to Ford. I would mention it to the Service Tech.
    I test drove a 98 Tacoma and i liked it. Good ride, nice road clearance, good power (for a 4cyl.) and steered nice. But it didn't have the torque of my old pushrod v6. The cabin was not as quite as the Ranger and the interior was no match to the Ranger either. Guess i'll have to go for a Xtra cab Tacoma but its a little pricey when your on a budget.
  • spoogspoog Member Posts: 1,224
    Well gang, Edmunds has compared the crew cabs from all the makers, and it has faired very very well.
    http://www.edmunds.com/reviews/comparison/articles/46966/article.html
    "The Tacoma was by far the most capable truck in this test when it came to off-highway performance. "
    -Edmunds.com, 2001 crew cab test
    Of course, we all knew this already, right?
    "Off-road, the Tacoma is simply awesome. The tightly controlled TRD-tuned suspension dispatched every obstacle with ease, and the high ground clearance made scaling large boulders a much less threatening affair than most of the other trucks in the test."
    - Edmunds.com 2001 crew cab comparison
    "This engine is the best of the bunch, hands down. It offers the best compromise between fuel economy and power. "
    Looks like Edmunds rates the Toyota v6 over the new ford v6
    -Edmunds.com 2001 crew cab comparison
    "In addition to its solid overall performance, the Tacoma also boasts Toyota's long-standing reliability record. One editor noted: "You could probably drive the hell out of this thing every day for 10 years, and it would still serve you well, asking only for gas and regular maintenance."
    -Edmunds.com 2001 crew cab comparisons
    "It was the general consensus that the Toyota was the most capable off-road of all the trucks. "
     The following quotes taken exactly from Edmunds.com-
    "There are certain areas that I think Ford could improve upon, however. Unloaded ride quality was poor; the truck was too bouncy and generally unpleasant to drive. Even more worrisome was the lackluster build quality found on our test truck. Interior trim pieces were loose and had large gaps. The driver-side window switch pod popped out easily, exposing the wires beneath. Our truck was also leaking transmission fluid during our test.
    Ford has been criticized recently about declining levels of quality. Maybe it's time to bring back the old Ford tagline. You know, where "Quality Is Job 1"?"
    " We voted the Expedition most likely to break"
    -Edmunds.com
    " The ranger rattled like a diamondback offroad"
    -Edmunds.com
    " the ranger center console broke off"
    -edmunds.com
    " If buying a used ranger, take one for a very,very long test drive"
    -Edmunds.com
    Anyone see a pattern here?
    Here is a COMPLETE list of the TSB's, Defect Investigations, and Safety Recalls for the Toyota pickup, Chevy s-10, Ford Ranger, and Dodge Dakota from the years 1989-2000. Enjoy.
    Defect Investigations 1989-2000
    Ford Ranger - 20
    Dodge Dakota- 14
    Chevy S10 - 51
    Toyota Tacoma - 2
    Safety Recalls 1989-2000
    Ford Ranger- 32
    Dodge Dakota - 28
    Chevyy S10 - 47
    Toyota Tacoma - 6
    Technical Service Bulletins 1989-2000
    Ford Ranger -2,279(yes, 2,279)
    Dodge Dakota- 940
    Chevy S10 -448
    Toyota Tacoma - 150
    So there you have it. All data is factual, and very telling. This is NOT "subjective".
    A trucks reliability and build quality is NOT "subjective".
    Not all trucks are built the same, as you can plainly see.
    Here is the hard link:
    http://www.nhtsa.dot.gov/cars/problems/
    National Highway Traffic Safety Administration
    http://msnbc.com/news/613144.asp
         \\ THE AGREEMENT ends years of litigation in which a California judge said the Detroit automaker was living in an “Alice in Wonderland” dreamland for denying ignition switches were defective. The proposed settlement, announced late Sunday, comes four months after Alameda County Superior Court Judge Michael E. Ballachey ordered as many as 2 million vehicles in California recalled as part of a statewide class-action suit in which the judge found that Ford concealed the shabby parts from government inspectors.\\
    Again, more concrete evidence of Ford overall lack of quality.
    FIVE million vehicles will be effected. Ford has already paid out hundreds of lawsuits thanks to the wrongful deaths caused by their cost-cutting, cheap switches.
    You buy garbage, garbage is what you get.
    What year Toyota do you drive? Is it 4 or 6 cylinder? Have you had those head gasket problems yet? I don't wanna buy anything below a 98 cause uh Consumer Reports had below par rating on the engines. Also what year did Toyota put shift on the fly? I laughed my [non-permissible content removed] of when i got out of that Toyota and it had manual locking hubs.
  • frey44frey44 Member Posts: 230
    the TRD i agree, other than looks, is not really all it's cracked up to be, so am am not going to get it when i order my new 2002 Tundra. i will order a 2x4, V8, limited slip extended cab with ABS. i can't wait to get rid of this 00 Ranger (i think i FINALLY have a buyer lined up, even though i will get killed on depreciation.....pray that i sell it) so i can get something that doesn't VIBRATE, LEAK, SHAKE, AND WHINE. good luck, all Ranger owners. hope you have a good experience with your trucks.
  • barlitzbarlitz Member Posts: 752
    again you post only what you want peole to read , go to www.alldata.com and the #'s are a lot closer on those tsb's , check out this pickup topic at edmunds problems posted- Tacoma 111, S-10 105. Just more proof that JD Powers is correct, The GM products are most relaible with the best in customer satisfaction.
    Good luck with that
    "Edmunds.com 2001 crew cab comparisons"
    Too bad the quotes are about the Explorer and this is a Ranger forum. Some simularity however, lots of differences.
    I went to alldata.com and it lists 2 things wrong w/my Ranger but what now? It just lists the problems but gives no answers on how to solve them. Useless web site.
    Not only does The Tacoma beat a GMC and two Chevy's in the 2001 pickup of the year, but Fourwheeler had this exact quote about it -
    " The Tacoma opened a can of whoop-a@@ on the other trucks. The Tacoma could simply go places the other trucks couldn't"
    -Fourhweeler.com
    Oh and check this out .....GMC most reliable? Keep dreaming. Here is the 5 year LONG TERM JD powers reiability tests which tests the vehicles for FIVE years. I mean, to find out if a vehicle is "reliable", you have to drive it for awhile, don't you?
    http://www.jdpa.com/studies/pressrelease.asp?StudyID=292&CatID=1
  • bessbess Member Posts: 972
    Thats the same post you had before where you claimed that Ford was below average..
    Do you agree that the site you post shows that both Ford and Toyota are above average in reliability? (remember this discussion is about the Ranger vs Tacoma, not the GM product).
    The meaning of spoog, which is slang or slander for, is male reproductive excrement. Something from the college days I remember.
    The other thing is he only posts on Ranger vs. Tacoma. There should be a "Ford is Evil" or "Jacques Nasser is the anticrist" forum for him to post his repetitive rants. He aparantly dislikes Ford to such a degree he scourges the internet for anything anti-ford. Rarely does he ever bring anything positive to light about the Taco, 'ma.
    why is it whenever a magazine writes something about ford gm its garbage, but whaen its toyota its gold. You're just jealous and you wish you bought a sonoma.
    this one:
    PLEASE accept this one:
    http://www.jdpa.com/studies/winners.asp?StudyID=286
    from J.D. Powers that lists 2 American nameplate, Dakota and F-150 (thats a Ford Right?) and no Tacoma trucks.
    and THIS one:
    http://www.jdpa.com/studies/winners.asp?StudyID=410
    http://www.jdpa.com/studies/pressrelease.asp?StudyID=410
    Which lists the following:
    Best Compact Pickup in Initial Quality Mazda B-Series
    Which is bacically a
    FORD RANGER!
    Soooo in this last press release, where did the Tacoma place? Behind Mazda/Ranger, GMC Sonoma, and Chevy S-10.
    That is NOT a compliment.
    8^)
    Your too easy to wack spoog!
    Ohhh tied with the Chevy S-10
    http://www.jdpa.com/studies/pressrelease.asp?StudyID=517&CatID=1
    Yeh all that may be true but, as the Ranger commercial used to say, Toyota still is a tougher sounding name.
    man the Edmunds server sure has been slow lately.
    My trucks name can beat up your trucks name. . .
    8^)~
    Safety Recalls
    TSB Number Issue Date TSB Title FIRESTONE SEP 00 Firestone Tire Recall
    00B40 APR 00 Recall - Multifunction Switch Replacement
    99S09 MAR 99 Recall - Speed Control Cable Replacement
    General Recalls
    TSB Number Issue Date TSB Title 98B34 FEB 99 Recall - Windshields Not Marked With AS1 Standard
    This what your looking at at Alldata?
    This is for my 99 Ranger. One applies, the multifunction switch. It has been done.
    I do not have Firestones, except the spare and my cruise is not factory and my windshield has AS1 markings, big deal, white markings on the windshield that says to not put any heavy tint below a certain line.
    What exactly is your question?
    8^)~
    The only thing that applied to my truck was the inflation misprint on the sticker inside the door panel. Didn't matter cause i replaced the Firestones w/Bridgestones. My question is with all that is listed on that tsb board are they all covered by a recall or something i should just be aware of. Do you drive a 4x4? If so, what kinda reliability are you having?
    The nature of a TSB or Technical Service Bulliten, is for the maker to communicate to servicing personnel the procedures or commonalities on repair techniques. As in one TSB (for Ranger) says an ash cup/tray is available, another says that if and when a 5 speed auto needs repair, to simply replace and send the malfunctioning transmission directly to Ford (Presumably to investigate the problem of their new transmission to prevent future problems). Spoog forgets that TSB's are good things, and can be very informative when service or repair is warranted. The lack of TSB's means the lack of knowledge or resources to fall back to when a vehicle is in the shop for repair. Some may say their vehicle is perfect and doesn't need TSB's, but others may say those people are living a pipe dream. I believe in the real world, where trucks get used and abused, and every TSB counts!
    So it's really just "something to be aware of", and a good source to fall back on when you have something that needs fixing.
    I agree with stang, TSB's are service tips, ways to work on things, such as glass glazing, etc. They are not generally anything you need to worry about.
    Yes, mine is a 99 4X4. The only problem I ever had was a disengagement of 4X4 high once coupled with the 2 4X4 lights flashing 6 times, then a rest, then flashing again. What it turned out to be was either the relays or fuses in the engine compartment electrical box had, from hard off-roading I suspect, popped up a bit. I removed and re-seated them and that was 37,000 miles and maybe 15 mountain passes ago. That is why whenever someone says they have the 4X4 lights flashing, I tell them to check the relays first. I also carry a spare relay, just in case one would fail while 4 wheeling. Relays, due to making and breaking connections, can build up carbon. Have a VW horn relay that is acting that way, gotta fix that this weekend.
    Things I do not like are, the short duration of the locked turn signal, the clear coat paint seems to scuff easy, not a flat surface at eye level in the interior to put a clinometer(shows pitch/roll deg.), stock shocks are too soft(put on Rancho RS500's like them) and the bumper seems to have some dark spots with the Mag. Chloride the spray on the road here in winter. Just minor dislikes.
    It has been a pretty good truck so far.
    I attended the "Stump the Hummer" competition in Northern NH this Sunday. It is a great offroad competition where drivers must negotiate through 10 very difficult obstacles including a mud pit, a rock climb, a hill climb, etc. As far as compact pick up trucks, there were several old Toyota pick up trucks entered into the contest and they all did pretty well. I also saw one Nissan Frontier and one Chevy S-10. Sorry to say Vince8, but there was not one Ranger entry. There were, however, a few full size Ford pick up entries. Anyhow, I just thought I'd let you all know that there wasn't a Ranger in site at the competition. Hey, maybe Spoog is onto something here regarding Tocoma offroading ability vs Ranger offroading ability. Take care.......Steelman.
    Nah, most of the Rangers from the Northeast were either in S. Jersey: http://geocities.com/twolo4u2c2/augpines01.html
    Or Kentucky:
    http://www.geocities.com/ummduh_1999/sparkz/driveway.html
    that weekend. . .
    Oh, there was no road here before the Ranger!:
    http://www.geocities.com/ummduh_1999/sparkz/bobbywalters.html
