GMC Sierra: Problems & Solutions
Neither one of these problems reared their ugly heads when I test drove the truck. However, they showed up after only 400 miles. Has anyone else had a similar experience?
Hunter
By the way, since I didn't have time to leave my truck at the dealership to have the clips put in the door, I had to pay 20 cents apiece and do it myself. I told the parts manager that he owed me a car wash since I was not only doing their warranty work for them, I was even paying for the parts!
Jim (in round rock)
I too notice the same thing on certain parts of the expressway where there are dips and such
The rear end is light unloaded so that has an effect like you stated you dont feel it as much when loaded.
I doubt there is or will ever be a fix for this. Honestly its something you have to deal with
Ryan
http://velvet-ride.com/index.html
costs about $200 and takes 15-20 minutes per shackel to install. Doesn't ride like a caddy but made an improvement similar to carrying a load all the time. Their website says may lower the rear of the truck by as much as 3". My truck lowered about 1" when measuring from ground to bottom of fenderwell.
cowboyjohn
Check out this sevice bullitin..
http://www.geocities.com/crackeregg/99-07-30-024.html
The dealer said that based on his VIN that the service bulletin was complied with at the factory and so he did not reprogram the computer.
I have spoken to one fella that said his was doing it and his dealer put a steering pump on it and it has seemed to fix the problem..
what do you think?
Also, instead of replacing the window for the air leak, they used a different screw on the frame by the latch. The wind noise is better, but not gone entirely. I have lots of warranty left on the vehicle, so I may give this one a little time and see if it is as good as it can be.
Oh, the pipe from the left bank converter has an OD 1/8" smaller than the pipe from the muffler it goes into. They cannot deform the pipe enough with a clamp to ensure a good seal, and since this is under the passengers compartment the whole thing will be replaced. Their decision, not mine, but I suspect that someone measured the pipe and determined it was not made correctly.
Jim
My gas mileage has been anywhere from 12.7 to 16.8 depending on use. I have noted it does better on 90-93 octane verses 87-89 octane. I'd like to see better, so far I've only acquired 2200 miles. I would hope better performance after the first 5000.
I use my truck as a truck. I use it for work and I tow various types of trailers with it. Seems I am always hauling something for myself or somebody. I have yet to experience any of the steering issues I have read about, or heard any of the strange noises. But then again it is still a new truck.
Future plans are to add accessories that are functional and practical. Bed caps are already in place to be followed by a liner of some type. Then a headache rack to keep the cargo from damaging that beautiful back window.
Jim
Tom
I have a noise that sounds like something is running kinda a high pitched hissing noise. It stops when i open the door.
Again, this is intermitant.
If you let it cool down after a session of this, it does not seem to do it again for a while, maybe even as long as a few months.
It is quite a hazard when we are driving on the Interstate! We are looking for any TSB's on this.
I don't think the TSB's for the fuel Throttle linkage control is the same. This is more like
a fuel pump or fuel injection problem.
Anyone else with this situation? Thanks!
Is there anyway to test the steering box if it is defective??? Has anyone heard about any Technical Service Bulletins for this yet???
Does anybody else hear and feel a clunking from the steering on right hand turns> this is unfortunately hard to recreate when a service tech is taking it for a ride.
I also hear a growling coming from the front end when in four wheel drive.
The problems just keep adding up.
easy fix takes 30-45 min
Ryan
This wandering all over the road is scarry as hell in heavy wind on the hwy. Thats why I going to an attny. to document in the event I get wasted on the road.
