GMC Sierra: Problems & Solutions
http://members6.clubphoto.com/ryan392464/
http://www.picturetrail.com/ryanbab
Mine fit with no modifications at all. Install and go. Also they are on my stock rims. Have had them for 7500 miles and all is fine
performance changes none really. I corrected the speedo with a hypertech programmer (HPIII)
MPG didnt change but + - 0.2. It may be a little slower in 0-60 (or whatever acceleration) but it can still outrun most.
I had the 265's for 10K miles crappy tires. THe 285's are so much better. Much better traction and handling.
Let me know if you have any other questions
Ryan
john
Peter
Jim
Ryan
Jim
http://www.hypertech-inc.com/programmer.html
Jim
-- Don
I've enjoyed the comradeship amongst truck owners. I have a '01 2500HD-8.1L 4x4 Crew cab, with 4.10 diff.
I've enjoyed every minute driving this truck. I even find places to go just to drive it. I'm getting about 9mpg city and 12mpg highway. I've just installed a Flow master on it with dual in/out that they just came out with for the 8.1, and it sounds great and is even performing better.
The reason I'm posting is to solicit the comments of anyone that is having problems with heavy vibrations on the concrete highways with vertical rain groves. It also rides much rougher than my '99 2500.
This is the only problem I've had with my truck other than on one occasion where the transmission seem to downshift to a lower gear at the wrong speed. I am taking it to the service kept tomorrow to have it checked out. Any comments would be greatly appreciated.
35 psi is for P(assenger) series tires, not for truck tires.
Mike L
My tires has 35 psi as max pressure....
Michelin LTX M/S 275/70R16
LT (Light Truck) tires are rated at 50 psi for 'C' range, 65 psi for 'D' range and 80 psi for 'E' range tires.
Mike L
I also told the rep that a couple of other truck owners that I knew had the same problems on their '99 and '00 2wd rados and if GM was going to let them know about the fix. I had no reply from the rep.
Mike L
When we used to mount mudders on a truck or 4x4, we had to hand tighten the lugs to try and ensure the best possible fit. It was truely a pain in the butt. To do otherwise with an impact gun would either warp the rim, have a bad fit, or both.
http://forums.pickuptruck.com/Forum11/HTML/004599.html
Some replacement filters do no have an anti-drainback valve, and let the oil drain out of the block and into the pan. Sort of like a dry start.
If you are using an AC-Delco PF-59, then I have no idea.
Mike L
