Looking for a good used truck
My husband and I are looking for a newer used
truck, 96 to 98 chevy or ford. I have been on
these boards and have found things from both
companies that typically go wrong on the K1500
4x4's and the f150 4x4's. Example, I have seen
that people have had a lot of problems with the 96
K1500 4x4 blowing transmissions around 55k miles.
I have seen that with the 97's and up that people
are experiencing problems with door cracks and
clunking in the differentials. It has been a while
since we have owned a truck and seeing that buying
these trucks are like a home mortgage, I wanted
some feedback from some truck experts and good
advise as to which brand of truck that we should
lean toward. I hope that I am not asking too much.
Pocahontas,
Edmunds.com/Roving Host
maintain them carefully ie use best plugs, oil, filters...
Good luck,
Regards
If all you are looking for is a 1/2 ton - you definitely should consider it.
http://www.jdpower.com/global/jdpaawards/releases/110200.html
Bad argument.
Harry
