Honda Insight Maintenance and Repair
If you're having an issue with your Insight, this is the place to ask your fellow owners. And if you've SOLVED a problem, be sure to check in here now and then to share your experience and knowledge!
Much thanks
___Autostop can happen at anything below 20 mph in an Insight 5-speed with fast work of the clutch and shifter. Unfortunately, what you are describing sounds different then that given you are in gear. You will not lose braking at any time as long as there is a vacuum and the Insight will hold vacuum for many hours when not in use and over many stops from a coast down without the ICE running at all.
___Good Luck
___Wayne R. Gerdes
When I apply brakes, as I approach full stop, ABS comes on and car coasts another car length or so. This is very dangerous, but I have been lucky so far and no one has been in the way. I suspect that culprit might be self shutting feature, that is somehow malfunctioning, and turning the engine off before it should.
Has there been anyone with similar problem?
The car bucks when going at normal speeds in 2nd and 3rd gear. any suggestions????
1. This is Minnesota. How does the Insight do in sub-zero temps that may last a couple of weeks in a row until it warms up to, oh say, +10 or +12 where it will stay for a month before it drops down again?
2. Since my driving is long range and constant high speed (60 - 75), will the electric motor ever really engage?
3. I understand the battery is an NiMH. My experience with NiMH batteries has been that they develop "memory". If the gas engine is doing about all of the work, the battery would be on charge almost all of the time. Does that compromise the available range under electric power? Worse yet, do I run the risk of damaging the battery because it's kept on charge so much more than it is actually used?
Thanks in advance for your replies.
Mile Guy
2. That is optimal way of using Insight, and best way to get high mileage.
Electric motor will engage on acceleration, and charging of the battery will take place on decceleration.
3. Partly explained in previous answer, just to add that there will always be some use of the battery, and charging as well.
Every time you start the vehicle, and get it going to cruising speed, electric motor gets used.
Two issues that you want to worry about are, do you live in mountainous region, and how much snow are you going to encounter?
If there is a regular and frequent use of Insight in snowy regions, you will need dedicated snow tires.
If you live in mountainous region, with steep up hills, I would forget about Insight altogether. Working it up the speed, on very steep hills would prove to be a frustrating experience.
Could it be that they don't trust us to replace our own fuel filter? My check engine light is "ON" and I thought I would start with the least expensive fix AFTER checking to be sure my fuel cap is turned more than three clicks tight...any other 'insights' ? :confuse: LOL
Thanks 2002insight
p.s. I got the service manual so I can better decide if I should take it to a professional or if it's something I can do myself.
You're correct, I'll have the dealer diagnose the code for the "CHECK ENGINE" light.
What's your experience been finding replacement tires for your '02 Insight?
Thanks so much, I trust your advice.
HAPPY HOLIDAYS
we also had problems with an antifreeze smell. we brought the car to three Honda dealers, Essex Honda in New Jersey, Miller Honda in Van Nuys , and auto park Honda in Cary, NC. Essex said the smell was from spilled antifreeze, Miller admitted there was antifreeze on the crossbar but said it was no problem. finally auto park realized the head gasket was blown. they had to remachine the head , a valve job, thermostat all very pricey. the day after we got the car back . it didn't start, somehow the starter battery went bad! a few days later , I noticed the and the freeze smell again. noticed the overflow was empty and brought it back. turns out that a Honda dealer installed an aftermarket cruise control , which rubbed a hole in a metal hose , which no one was curious enough to find themselves. all very frustrating. auto park was pretty decent and at least they found the problem eventually
I hope you find the reason for the check engine light. As for the replacement tires, I got a new set of Cooper "165/65 14 S" at 55,000 miles. The tire dealer in my area had to order them, since they only had two in stock, but it only took a couple of days to get them in. Just check that the installer put the rear skirts back on properly (I had to refit mine before I left the tire shop.) I think I made the mechanic grumpy when I asked for a screwdriver, and told him the reason I needed it.
Ho ho ho and Merry Christmas.
My local Honda dealer replaced the Oxygen sensor, but CHECK ENGINE light is still on. When I asked if there had been any recalls on my '02 Insight that I may have missed; they said they would research the issue and get back to me. :mad:
However, on the Insight Central website, several other owners claim they've received Recall Letters on the ECM replacement stating:
."Your vehicles main computer control module (the ECM) can misinterpret readings from various sensors. If this happens, the check engine light on the instrument panel may stay on."
Have you received a Recall Letter from American Honda in Torrence or are you still waiting for one like myself? :confuse:
Thanks for any info...HAPPY NEW YEAR !!!
Sorry to hear that your dealer didn't correct the problem before giving the car back to you -- and I bet they just scratched their heads and replaced the Oxygen sensor; scratched their heads again, and sent you home. I'll ask my dealer in Ohio if there's a recall on mine (John Hinderer Honda.) They're pretty good at customer service, so I'll let you know what they say after I talk to them.
Also had to replace driver side mirror due to a tornado sandblasting the car. dealer told me how to pop off the old one but to replace it is trickier. got it to pop onto the center but how do you get it on the side pcs? :confuse:
In regards to your post:
"My passenger seat belt is getting wet but I cannot see any water anywhere else or a physical leak, trail etc. Anyone know about this?"
Here is what I Know:
The leak is most likely coming in from the side panels that are above the doors. Sorry I’m not very mechanically inclined so this description might not be the best, but I've had water leaking into both the passenger and drivers seat belt.
I thought it was because of a bad job Safelite Auto did replacing my windshield (they have to remove the side panels above the doors to replace the windshield, in the process they broke the side panel clips, so the side panels didn't go back on right). Water began leaking in (a lot--my seatbelts are dripping with water) and so I am now in the process of having Safelite fix this--however there may be another problem.
Safelite replaced the side panels, and it Still leaks--they have a test where they spray water into the crevices above the doors (starting at the front and working all the way back to the hatchback) and if you remove the interior plastic moldings around the seatbelts you can watch the water trickle in. I’m trying to find out why this is happening—maybe a crack or something in the body, or a bad seal, or needs some new puddy?
I'll let you know what I find out—and if you or anyone else has more info on this PLEASE let me know because I’m sure this will be a big fight with Safelite Auto and my insurance company.
JB
There have been a few posts in here about leaks... yeah I have seen the guys in the shop with the garden hose out spraying on insights to duplicate the leak... and I am fairly certain that they find most of them... I'll talk to my service MGR to see if there are just a few "more common spots" or if it is all just random seals going bad.
Also, in case I cannot locate my manual soon, what important servicing must be done to the Insight at 55,000 and what should I be watching for in a car of that mileage?
1. Turn off the engine.
2. Press and hold the trip button in the instrument panel, then turn the ignition switch ON (II).
3. Hold the button until the indicator resets (approximately ten seconds).
Has anyone else encountered this problem? Any fixes known?
Did you ever get any answers on your water leak problem? Mine's doing it too!
Ian
good luck
jb
End result - my car runs like new. I lost no mpg when the repair was completed. In fact I actually gained back a couple that we had lost in the last few years. Steadily at 65 mpg. The dealership was great about using the used parts and said the unit looked new. Oh - the eBayer is LKQonline
ANY IDEAS????
THANK YOU
DO NOT GET ANY ON YOUR BRAKES! Just on the cable where it enters the sheath.
THANKS AGAIN
