2007 Ford Edge
1192022242528
  • srangersranger Member Posts: 106
    I basically like the Edge. I think it would be a great fit for the type of vehicle that I want. I think it is packaged well, but a little too pricy in my opinion for what it is. If I could get one at 2k off MSPR I would probably be willing to buy one. However, the braking performance is a deal breaker for me. Even if you have to cut corners on cost, you SHOULD NOT compramise the brakes...
    If Ford would fix the brakes, I would go ahead and buy one. I am just not willing to pay $3x,000 for a vehicle with questionable braking. I suspect that it would cost up to $2,000 in aftermarket parts to upgrade the brakes to a level where I would feel comfortable... ( more if you have to replace the tires ) However, I doubt Ford is going to be willing to knock 4K off of MSRP for me to justify buying one and fix the brakes myself....
    And for you guys who defend Ford on this issue, you will be happy to know that this will by my last post on the brakes... :)
  • akirbyakirby Member Posts: 8,062
    What we're saying is that while we may be slightly disappointed and the braking should be better, it's not a deal breaker for most of us. Now remember that promise....
  • lateralglateralg Member Posts: 929
    "It is there SOLELY to help you maintain directional control, allow you to provide stearing inputs if needed, and/or prevent under/overstearing during severe or hard braking where otherwise you might lose control due to brake induced lockup."
    Wrong again.
    Hmm... do I believe the guy who has an engineering degree and who made his living working on brake systems or the guy who can't spell "steering"?
    I'd go with the engineer - but only if he can spell the word "competitive."
    The import lovers just can't bring themselves to believe (or admit) that the domestics have competetive vehicles now. ( akirby, "2007 Ford Edge" #1090, 6 Feb 2007 10:38 am )
    Sorry - I just could not resist. ;)
    I can take it as well as I can dish it out. Touche!
    :P
  • frizz2112frizz2112 Member Posts: 84
    It brakes my heart to hear this.
    :P
    Back when I was in grade school, 47-55, steer was an animal and stear was a verb.
    Google for either, steer and stear are now used interchangably as a verb. On our MT ranch we raise Steers.
    "..you SHOULD NOT compramise (compromise) the brakes.."
    Sorry, the adoption of anti-lock braking is and always has been a compromise, compromising the braking capability versus the ability to stear, maintain directional control of the vehicle.
    Prior to ABS it behooved the driver to practice and learn how to apply hard or severe braking without actually bringing the wheels into lockup and thereby having the potential for loss of control.
    But being able to do that takes lots of practice. Additionally all that practice becomes needless if the roadbed in slippery, ice, snow, oil-slicked, etc.
    So no one questions, or should question, that like VSC and TC, ABS is a damn good aspect to have in many modern day vehicles.
    While braking hard or severely, if you could look out there ahead and see that upcoming patch of black ice, wouldn't you release some of that brake pressure as you reached that slippery area.
    But, neither you, nor the anti-lock system, can "see" that upcoming patch of black ice. But the anti-lock system can react quickly enough to release the brakes intermittently once the black ice patch starts affecting the rate at which the brakes are slowing the wheels.
    So, which would you rather rely upon, your own eyesight, your reaction time once the vehicle hits the ice and starts to wonder from your chosen "path", or an anti-lock system that almost instantly "unbrakes" the tires once they starting reaching the point of lock-up, REGARDLESS of traction conditions.
    Check this out: http://www.m-w.com/cgi-bin/dictionary?book=Dictionary&va=stear
    One last try, then I'm done with my attempts to counter the dangerous fiction presented in this thread.
    First, ABS came on the scene in the late 1970's, well before stability control & its relatives. The insurance companies provided reduced rates for vehicles so-equipped.
    Now, let's design a brake system. We need a few reasonable assumptions to work with. Here they are:
    1) "Our" vehicle, with 300# of driver & passenger in the front seats, has a static weight distribution of 60%F, 40%R.
    2) During a panic stop on an average dry road, the dynamic weight distribution becomes 70%F and 30% rear.
    3) Given the above, we apportion the braking power to 70%F and 30%R.
    Now we go on vacation, adding a rear seat passenger load of 300#, and 300# of "stuff" way back in the rear. Our static weight distribution now becomes ~50%F and 50%R.
    During a panic stop on the same average road, our dyanamic weight distribution becomes ~60%F and 40%R. At this point our design decision doesn't work very well. It's applying 70% of the braking power to the front wheels that can only handle 60% without locking up.
    Result: The front wheels lock up and we can't steer (stear?). So we let up on the brake pedal & soon realize that we're not going to stop in time. So we hit the pedal again, only to have them lock up again. We continue to do this "pumping" until the crash.
    Meanwhile, the rear brakes are loafing, doing nowhere near their share of the braking.
    I will wager every penny I have that the ABS-equipped vacation vehicle will have a significantly shorter stopping distance than the vehicle without ABS.
    One can argue with my weight distribution assumptions, and I don't care because the essence is correct.
    One could argue that a human could pump the brakes at a rate that would duplicate ABS. At this arguement, I would shake my head in disbelief.
    I ask anyone reading this: Would you disable the ABS on a car your wife, child, grandchild, eic. was about to drive in rainy, snowy, icy, or even dry condition?
    lateralg,
    Tell you what, I'll match you dollar for dollar at any level you wish to bet, you choose the 2007 vehicle with ABS, tires (no studs, no chains) of your choice, and find the ice skating rink, or a solidly frozen pond/lake, that will allow us to test your theory, and I'll be there to collect your money.
    PS: If you browse around the internet just a bit you will find the results of this test, already available.
    PSII: And what's this deal with the rear brakes? The fact that the rear brakes cannot be made to handle a higher level of braking is a matter of the laws of physics, the HARD laws of physics. The number I typically use is that ~80% of braking, especially hard or severe braking, occurs on the front brakes.
    " 3) Given the above, we apportion the braking power to 70%F and 30%R..."
    "We apportion..." ???
    NOT
    Brake apportioning will be primarily a result of the laws of physics. During a rapid stop inertia, momentum, results in the unloading of the rear tires and loading of the front tires. In the olden days we used a brake fluid proportioning valve to limit the brake fluid flow/pressure to the rear because absent doing so, sending equal brake pressure to both front and rear, would oftentimes result in rear lockup and skidding.
    These days we use EBD, Electronic Brakeforce Distribution, first. Dynamically allocating brake forces based on happenstance vehicle loading, tire wear, etc. If EBD still cannot prevent lockup that's when ABS activates.
  • atenza94546atenza94546 Member Posts: 6
    Well, is time for Freestyle to upgrade the engine than. The Edge (Fusion wagon) have better engine than the Freestyle(500 wagon). What is FORD thinking ???
    The quote that you took from my post was taken out of context. I was simply replying to another post were it was implied that Ford tried to save money by using an underpowered braking system. I did not say that I though this was statement was true. My Point was that the brakes should be one of the last systems on a car where any manufacture should try to save money.
    As for the rest of your post, all I can say is that it is some interesting fiction. I am not sure where you got you information, but you should really do a little more research on the subject.
    P.S. I ran this post through the spell checker to appease all of the spelling police.
    The Freestyle is dead, but the Taurus X will get the 3.5L engine in April.
  • passat_2002passat_2002 Member Posts: 468
    NOT dead.. just improved for '08.
    April? Ford is saying late Summer availability
    The author of the following has demonstrated in previous posts an impressive knowledge of physics and electronics.
    NOT
    Brake apportioning will be primarily a result of the laws of physics."
    The post also indicates the need for a refresher in brake design. Here is a simplified example of how nominal front to rear brake apportionment is accomplished in the design of the vehicle.
    * Assume we need 60%F, 40%R nominal brake apportionment.
    * Assume that during a panic stop, the master cylinder & booster produce 1,000 PSI hydraulic pressure.
    To achieve ~ 60-40 apportionment:
    The front caliper piston would have a diameter of ~3.5", resulting in an area of ~ 9.6 Sq. In. >> 9.6 sq. in * 1,000 PSI = 9,600# of force applied to the front brake pads, and in turn to the rotors.
    The rear caliper piston would have a diameter of ~2.8", resulting in an area of ~ 6.2 Sq. in. >> 6.2 sq. in * 1,000 PSI = 6,200# applied to the rear brake pads, and in turn to the rotors.
    We now have a total of 9,600 + 6,200 = 15,800# applied to the combined front and rear rotors. 9,600/15,800 = ~.61
    This accomplishes a 61%F 39%R brake apportionment.
    There are other ways of doing it, and none violate any laws of physics.
    Now two direct questions asking for yes or no answers:
    1) Would you disable the ABS on a vehicle that a loved one was driving in inclement weather?
    2) If you owned a recent model F-150 and occasionally drove it fully loaded, and occasionally empty, would you disable the ABS system?
    I meant the name was dead. The 08 Taurus/Five Hundred is due out in April - I just assumed the Freest...err...Taurus X would debut at the same time. Maybe not.
    1) No.
    I'm already on record several places on the internet having said that I would always disable ABS on my 85 and then my 92 Jeeps during the summer months.
    But to meet your question "head-on", yes, if there were a method wherein ABS could be easily disabled unless VSC detected that stearing input was required, skid, over/understear, then absolutely.
    2) As it happens I own a '93 Ford Ranger and just a few weeks ago during our ice storm I put 4 bags of rocks in the bed to improve rear "motive" traction, with nary a thought about the rear weight effect on braking. If I wanted to improve braking traction or capability I have enough common sense to know that should be addressed at the front first and foremost.
    Now I'm going to go off and start a discussion with this wall to the left of me....
    Now I'm going to go off and start an argument with this wall to the left of me....
    So if you start sliding down wall are you better off with or without your antilock socks? (Sorry - I couldn't resist!) :P
    Do you have an engineering background or experience with brake systems engineering or did you just stay at a Holiday Inn Express last night?
    Just trying to figure out why you think you know more than automotive engineers.
    I've NEVER pretented nor proposed that I know more than any automotive engineers with regard to ABS. And keep in mind that beancounters likely have more to do with implementation of state of the art automotive systems than do the engineers. Engineers only design these systems, beancounters, and in the end John/Jane Q Public, decide if they are cost effective.
    And most modern day owners manuals will provide you with a decription of ABS that co-insides with my own.
    "co-insides with my own"
    Now you're just messing with us. :D
  • heyjewelheyjewel Member Posts: 1,046
    How much engineering and spelling knowledge does a stear rancher need?
    Sigh...
    Whatever.
    He needs to no enuff to sine the reseats! ;)
    okay - back to topic!
    No, I just sign the checks for those that do the actual ranching. At the moment I'm sitting here in Waikea enjoying the sunsets and ocean breezes.
    "When you don't like the message, attack the messenger"('s spelling.
    Fine.
    When you don't like the message ...
    Of course, it could just be conceding the argument -- or, more likely, an attempt at humor. :)
    Or both...
    Well, ... perhaps the Edge wont be the saviour of the Ford motor company after all. Must not be selling well as they've already put a rebate on it.
    Oh well. Maybe they will rename it the Taurus E. That oughtta do it!
    That would be abbreviated T-E which kinda sounds like Tee-Hee! ;)
  • donl1donl1 Member Posts: 112
    Does anyone that purchased an Edge with the Camel interior have a problem with the reflection on the windshield? Very pronounced and distracting when I sat behind the wheel. Anybody else feel this way?
    Throw a blanket over it...
    Tee-hee.
  • mmccloskeymmccloskey Member Posts: 168
    Ford is offering a $500.00 rebate on the base SE models only. This is due to the unexpected demand for the SEL and SEL+ models. Those who seem to be interested in the Edge are going for the upper tier/loaded models, not the base/minimally optioned Edge.
    Regards -
    M. J. McCloskey
    It does sound strange but this rebate is a good sign. It means they can make and sell more expensive models going forward which will yield even more profit. The rebate is to move the base models that the dealers already have.
    Spin it anyway you want, but having to put a rebate on a vehicle after less than two months is NOT a good sign...
    It shows that the new has already worn off. After only one and 1/2 months there should be enough to pull through interest to move the lower models without rebates...
    It was some excellent spin though. Do you guys work in politics?
    Here is the actual article - not sure of the copyright issues, but I'm sure the forum moderator will take the necessary action if I'm out of bounds in posting this:
    Of course you can interpret the above info any way you wish. Ford miscalculated the model mix (among many other recent miscalculations) and are taking the action noted in the article. I'm not interested in buying an Edge (I am the very happy owner of a Freestyle), but if I were, I would want a very well equipped one.
    Regards -
    M. J. McCloskey
  • jasdmwjasdmw Member Posts: 118
    Was at the Toronto Auto Show last night. Very disapointed in the Edge. Looked very cheap, trim pieces didn't align, and these were show cars! Fit finish and quality of interior bits was sub-par. No less than 3 colours for the dash components. Joints and lines everwhere. What a mess! That tray on the top of the center stack was loose. Have a realative at the Oakville plant and feel sorry for those folks. I won't be buying one of these. Also had a quick look at the MKX. Same thing, and that rod to lift the rear tailgate; what's with that! Comparing this to the Lexus, Acura and others just can't be done. The GM Acadia, etc. are in the same boat as Ford. Not impressed at all. The constant vendor bashing and cost cuting is starting to show.
    I see a thread with the Santa Fe. I was very impressed with this one. Have been a major avoider of the Korean maker, but if I had to buy today, that would likely be the one. Have a Focus bought on the A plan and will not be buying another Ford. A good deal on a bad product is still a bad deal.
  • colecole Member Posts: 67
    Every auto show that I've been to has vehicles that have been banged on, sat in and just generally messed with by hundreds or thousands of the buying public. Saying that you wouldn't buy a vehicle based upon one that's had a lot of wear and tear on it seems odd to me.
    Absolutely!
    It's a simple matter for a Ford basher to insert an object in a trim joint, twist, and cause a gross misalignment.
    As a Ford fan (one who has purchased nothing but Fords since 1990) I have been eagerly awaiting my first sighting of the new Edge on the road. Seeing as how the car has been on sale for around 7 weeks, and seeing as how it has been very heavily advertised on TV, I would never have guessed it would have taken until today to see one. It was a Black SEL model parked in a grocery store parking lot. I walked on over to look at it, and to my horror saw the dreaded green Enterprise sticker on the back hatch. I couldn't believe it! Fleet sales already for the car that is supposed to help save the Ford Motor Company? Hello Dearborn? Are things really that bad?
    Is it true you can't disable the traction control on the Edge? In snow country it's something you need to be able to do. Hopefully it's not something Ford missed. :confuse:
  • driverdmdriverdm Member Posts: 505
    jasdmw, remember that the Edge for the autoshow, probably hasn't changed since the first autoshow it was unveiled at early last year. Also, remember that several reviews have said that the interior was well put together. Sometimes, one example does not speak for every product.
    To some degree, style is a personal matter. I actually like the color scheme. It makes the vehicle look modern and different to me. The seats also look very good. Take a look in a Land Rover (Range or RR Sport) and you'll something a little familiar with the Edge. The only part of the interior I do not care for is the center stack. It's livable, just not as nice as I'd like it.
    The Santa Fe looks beautiful in pictures but sitting in the interior, there are many areas where you see the cost cutting.
    By the way, I own a Mazda6, and am thinking about of buying a VW Passat (the reliability frightens me though) or a used STS so I am not a Ford Fanboy. I do love the Edge and Fusion. I hate the Taurus and Taurus X. Anyway back to topic.
  • ugmacugmac Member Posts: 4
    Of course you can disable the traction control.
    You're the only spin doctor here. If sales volume was an issue the rebate would apply to all models, not just the base models.
  • explorerx4explorerx4 Member Posts: 21,089
    i think it takes time for a vehicle to reach a 'critical mass' wher you see them on a regular basis. i still see very few '07 camry's, and we all know they selling well.
    ex4 - don't u live in the SF bay area? Like me? I see more 07 Camrys than - well, I dont want to use too large a hyperbole, but there are literally a zill ... well a lot of them around here. Each as ugly as the one before, but still, people are buying em like hotc... oh well, u get the drift.
    Friends bought a lime green one (talk about hitting the poor step daughter with an ugly stick - a lime green 07 Camry - blech) way back when they first came out. It's a hybrid. Added to their Prius in the garage. Yeah, they're real greenies. I'll tell ya though, gas is stll $3.00 a gallon here (premium) and I'm getting real tired of paying that much. To get a hybrid now is to screw back at the oil companies and I'm beginning to think that's a good thing. And now, Priuses are starting to become deals - 0%, maybe even rebates. Believe it or not, USED priuses are more expensive than new ones in some cases because there are no more car pool lane stickers for Prii so commuters will pay more for a used one with the sticker.
    Turns out it's not even a rebate - it's just dealer cash.
  • bdymentbdyment Member Posts: 573
    Ford spends a lot on advertising. They had better fire the agency that inserted the full page ad. in the latest issue of Time Canada. On the fifth page there is a full front view of the Edge with a hood that almost touches the left fender and has a big gap on the right side. I don't know if this shot appears in the U.S. edition. I hope it doesn't. It is dated Feb. 26.
    This has got to embarrassing for Ford. I am in Ford's corner, but gosh they had better get a handle on this.
