1983 Mazda B2000....HELP ME PLEASE!!!
                    Hi I own a 1983 Mazda B2000 Pickup truck and I am trying to restore and mod it. I have searched and searched but I can't seem to find a roll pan for it, so I was wondering if anyone knew of a roll pan that would fit it, like a roll pan for a different model? If you could please let me know as I am in dyer need of this info.
http://www.sirmichaels.com/
Ford's 2.3L Turbo engine should drop right in with very little modification.
The hard part would be doing all the wiring for the ECU, but you can try and locate an early blow-through carb' 2.3L Turbo engine usually found in '79-'81 Mustang Cobras, also some Mercury Zephyer XR-7's and early 80's Ford Thunderbirds as well.
Another option is to swap in a Ford 2.3L, give Esslinger a call and you can build up a hot 200-230hp Street 2.3L OHC engine.
I am far from a mechanic...I plan to buy the book and attempt to put this thing back together. Does anyone have any suggestions or things to watch out for? I will be replacing the timing belt, water pump and radiator. These are all off of the vehicle already. All parts are there, I just need to figure out where they go. I'm a newby at working on vehicles so I want to make sure there aren't any items that with a little experience I would know about and not mess this thing up.
jcwhittney.com
autopartswarehouse.com
ckresto.com
airbagit.com
godfathercustoms.com
sporttrucking.com
something you might be interested in though is that i heard a rumor that a kia spectra DOHC head will bolt right up to the block of the b2000 motor. thus making it easier to apply a turbo set-up! plus you get the added bonus of better gas milage, feul injetion, and more torque/hourse power. however i haven't been able to find what year kia the head should be pulled from. i'll keep looking and let you know what i find. e-mail me if you come up with any ideas or if you need tech help while your building at borderjumper21@msn.com
jcwhittney.com
ckresto.com
airbagit.com
sporttrucking.com
something you might be interested in though is that i heard a rumor that a kia spectra DOHC head will bolt right up to the block of the b2000 motor. thus making it easier to apply a turbo set-up! plus you get the added bonus of better gas milage, feul injetion, and more torque/horse power. however i haven't been able to find what year kia the head should be pulled from. i'll keep looking and let you know what i find. e-mail me if you come up with any ideas or if you need tech help while your building at borderjumper21@msn.com
I'd encourage you to take this on as a learning project but don't get over excited and start spending money too fast. Take it a step at a time. You can run an engine without a radiator or accessories for a short time with no harm (a few minutes).
Don't buy untested junk parts and work from the core of the car (the engine) out toward the accessories. Don't be buying fancy wheels or a radiator before you even get the engine assembled.
