Visitor Agreement.
If you had a choice of being hit by the 10 pound box or the 4000 pound box, which would you choose?
These are extreme examples of course, but do you see that the weight of the car does factor into the test if the car is moving?
If a "good" rated civic has a head-on crash with lower rated, but 1000 pound haevier car (eg Impala)...which will prove to be safer. I'm pretty sure it would be the Impala. Now what if the weight difference is only 500 pounds? Is an "acceptable" Fusion safer (based on frontal crash test results) than a "good" civic? I'd guess probably...but it is only a guess.
In a two vehicle accident the weight of both vehicles is a factor, because weight (actually mass
IIHS managed to come up with a moving sled for side impacts, not sure why something similar would not be done frontal. Design something mimicing the front end of 3000 or 3500 pound car (and/or truck/suv) and crash it into the front end of a moving test vehicle.
OK, then we are in agreement I think. If the IIHS were to implement a frontal test as you have suggested, where a moving car hits a moving barrier, then the tests could not be compared across weight classes. That was the original question we were discussing. The question was not whether the IIHS could design such a test and if it would be useful, but just whether the results could be compared across weight classes.
If they smashed a 3000 pound device into a Civic, the results would simulate what would happen in the real world if the civic were hit by a 3000 pound vehicle.
If they smashed the same 3000 pound device into an Impala, the results would be indicative of what would happen in the real world if the impala were hit by a 3000 pound vehicle.
Comparing them would tell you how one would do relative to other in a real world frontal collision with the same 3000 pound vehicle.
We weren't talking about smashing a device into a car. I thought you had proposed taking a moving device and smashing it into a moving car.
I'm done on this topic.
Yes, and this would mimic what would happen when a 3000 pound moving car smashes into the other moving (tested) car in the real world. Civics do not collide only with other Civics and Impalas with other Impalas in the real world.
What is wrong with the idea of a standardized test that mimics a 2 vehicle accident? The Civic owner is just as likely to collide with a 3000 pound vehicle as is the Impala owner.
Consider a head-on collision between a specific 4000-lb car and a specific 2000-lb car. The following different scenarios result in the same damage to the each of the cars, and in each case the crash accelerations will be twice as much to the smaller car.
1. 4000-lb car is stationary and is hit head-on by the 2000-lb car travelling at 40 mph
2. 2000-lb car is stationary and is hit head-on by the 2000-lb car travelling 40 mph
3. 4000-lb car travelling 20 mph and 2000-lb car travelling 20 mph collide head on.
The way to think of a vehicle collision, to a good first approximation, is to think of them as being out in space where there is no local frame of reference for speed.
2. 2000-lb car is stationary and is hit head-on by the 4000-lb car travelling 40 mph.
Addition: Remember that a 4000-lb car will in general be larger (and hence have a larger crush zone) and will in general be stronger (stiffer) than the 2000-lb car. This will reduce the likelihood of intrustions into the passenger space of the larger car.
The two vehicle will exert equal but opposite collision forces on each other, but since F = ma the resulting accelerations (or changes in velocity) caused by the crash will be different and will be inversely proportional to the masses. This means that unrestrained occupants of the 2000-lb car will experience twice the force if they contact the inside of their own car than unrestrained occupants of the larger car. Unless an occupant is wholly or partially ejected from their car what injures them is the collision of their body with the inside of their own car.
http://www.detroitnews.com/apps/pbcs.dll/article?AID=/20061121/AUTO01/611210365/- 1148/AUTO01
Rocky
P.S. It's all a buncha B.S. because some cars don't have ESC. :mad:
http://www.freep.com/apps/pbcs.dll/article?AID=/20061121/BUSINESS01/611210389/10- 14/BUSINESS01
Rocky
http://www.edmunds.com/insideline/do/News/articleId=117652
Rocky
Rocky
Oh boy....oh boy....Ford, sure is taking "bold moves" in it's advertising. :surprise:
Rocky
Not surprising to me.
After all, it's really not safe to be driving around in a Volkswagen :lemon: having no brake-lights
or turn-signals after the "affordable German engineering" electrical system shorts out.
Thanks in part to the IIHS, vehicle structural crash safety has greatly improved in recent years,
in contrast to the dismal results from a 40mph crash test of a Ford Tempo.
Reminds me of the tests of the late 90s F-150 extra cab that folded up like a pop can.
jeffyscott,
The IIHS offset crash test is designed to simulate an offset head-on crash between two vehicles of the same size and weight travelling at the same speed. This allows consumers and insurance companies to judge which vehicles will provide the best protection PER CLASS. It is assumed the car buyer has a specific vehicle type and class in mind when shopping, and will then look to see which model offers the best protection in that class. Better protection theoretically will translate into lower insurance premiums over time.
Consumers that place more trust in the "safety-of-size" may of course opt to purchase a class-size heavier, but this does not invalidate the categorical results of IIHS crash testing. One could also choose to travel at a slower speed in order to minimize potential injury in any potential collision. Or, one could simply stay home rather than venture-out into traffic at all. Because all of these human variable exist, crash-testing must make certain assumptions, using a "baseline", in order to make comparisons. You will hopefully learn more about these concepts in college physics.
It is not reasonable to expect any organization to crash test every weight\size against every weight\size. However, vehicle manufacturers often take it upon themselves to crash-test their own vehicles of different sizes. In fact, Honda's ACE Safety Structure is specifically designed to minimize damage from crashes involving vehicles of different sizes.
The current crash test simulates a single vehicle accident or one with a similar vehicle. An additional test, such as I suggest could be conducted to allow comparisons of a two vehicle collision across all vehicle classifications.
BTW, your attitude comes off as rather arrogant. I do know a bit of physics having gotten a degree in that subject about 25 years ago.
Why we Loved SUVs and Oh How Stupid It Was
According to Bradsher, internal industry market research concluded that S.U.V.s tend to be bought by people who are insecure, vain, self-centered, and self-absorbed, who are frequently nervous about their marriages, and who lack confidence in their driving skills. Ford's S.U.V. designers took their cues from seeing "fashionably dressed women wearing hiking boots or even work boots while walking through expensive malls. " Toyota's top marketing executive in the United States, Bradsher writes, loves to tell the story of how at a focus group in Los Angeles "an elegant woman in the group said that she needed her full-sized Lexus LX 470 to drive up over the curb and onto lawns to park at large parties in Beverly Hills. " One of Ford's senior marketing executives was even blunter: "The only time those S.U.V.s are going to be off-road is when they miss the driveway at 3 a. m. "
My old joke was always to the effect of "that thing will only go off road when it is in a shopping mall parking lot"...pretty much sums it up.
Um, you were wrong then and still wrong.
Crash Test Wars: 1959 Chevy Bel Air VS 2009 Chevy Malibu
