I have a 97 Accord with 260K, the climate control fan doesnt work anymore on any selected fan speed. No noises, just silence. My assumption is a blown blower motor. I already checked the 40amp fuse under the hood. There were a few days over the past 2-months that the blower motor wouldnt work, but it usually came back in an hour or if I opened and slammed the glove box. Oddly enough the blower motor was replaced at 160K after making annoying noises and then finally faily. Just wondering if this could be anything else than just a blower motor. Thanks
I have a '94 Honda Accord EX, 4 cylinder automatic with 90.8K miles on it. I just had the timing belt, water pump, component kit, along with several of the other belts changed. The engine seems to be running a bit louder now. Is that normal? Also the acceleration seems to be a bit depressed with the engine making more noise as the rpms go up. Do I need to go back and have them readjust the timing, or was I just so used to the car running the way it did that now that it has these new belts, it's just running a bit differently? Any advice or thoughts are welcome! Thanks
Hi All, I am having the same problem. 1994 Honda accord EX 4cycl.
Since it's pre-1996 Autozone won't scan it (OBDI not OBDII)
but it is the same problem, once it warms up.
See below post - Mine is a Vtec but has the same problem, however, I did replace the hitachi distributor with a non hitachi, still not sure if this is the problem Hello everyone, been reading the message back to last October and haven't found anything that matches the problem that I'm having. I have a 1995 Accord LX, I4, non-VTEC, automatic trans, with 200k miles.
On a cold engine, I can hit 4k+ RPM without problems. About 15 mins after I start the engine, the check engine light turns on and the car won't go over 3k RPM. I can drive fast, slow, or drive to the gas station and turn off the engine and it's almost always 15 mins after I first start the cold engine. When I hold the gas down steady, it will oscillate between 2.75 and 3.25k RPM and if I give it more gas, it will back fire periodically while oscillating.
Been meaning to go over to a friends to get the code but haven't been able to sync up with him. Anyone have any ideas what is going on? Am I completely hosed?
My girlfriend has a 97 honda accord that has been working great up till yesterday when the weather got down to -3. Now the idle bounces from 2500 to 6000 and back and forth. The heat and the defrost are not working now and the smell of burning oil is coming into the car. The check engine light just came on and i cant even locate the OBD plug so i can pull the code. any ideas please :sick:
Trhenning is correct about OBD!! connector location. behind ash tray You will need a scan tool. Autozone, Advance, ETC will scan for codes. Suspect -3 is your problem, something frozen, move it inside and let it thaw out if possibe.
I have a 94 accord ex. The electric cooling fan will not shut off. I disconnected the battery and waited over nite. When I re-connected the battery, the fan began to run again Any ideas?
Probable causes Temperature sensors or Fan relays. Down load this Service-Manual. look under the electrical tab. Fan controls, page 23-125. Diagrams and test procedure links. http://pdftown.com/Honda-Accord-1994-Service-Manual.html
I have a 96 Honda Accord EX sedan, 2.2L VTEC. I just had to replace a heater hose that comes out of the engine just below the distributor and goes down to what seems like something attached to the heater core. A friend and I get the hose replaced and filled the radiator back up with antifreeze, when I have the car started it is idoling at about 2,000 but when the temp gauge on the dash reachs the normal point, the idol begins to drop down and the shoot back up to about 2,000 repeatedly. I turned on the heater to see if it was blowing hot air and it was just blowing cold. I talked to another friend and he said that I should try getting a heater under the engine because it could be froze up a bit. Is this true or do I have another problem that I don't know about? It's about 28 degrees outside now but has been anywhere from -10-5 degrees on average for the week that it has been sitting. Any input will be helpful.
I have a question about my honda accord 96. It sometimes does not start at all when it is warm. It does do a little click though. I took it to the mechanic and he changed the started, but that did not resolve the problem. I am thinking it might be related to another problem that i have with the inside lighting system in the car, they do not work properly. The other day I park my car for 5 minutes, then tried to start it, but it would not start until I put some snow in the starter area and made it a bit cold. Any ideas?Thanks
I replaced the distributor on my 1997 Honda Accord. I am getting a spark, but the car will not start. Is this the timing? Not sure if I have the firing order correct...please help. Car has been down for over a week and we need the transportation.
I have almost the same problem with my 97 Honda accord. Four days ago, it was very cold (-5F), the car started but there was no heat, and the engine was also surging back and forth, I did not have the check engine light. Any idea what is the cause of this problem? I checked the antifreeze level, it was OK.
I have a 1997 Accord LE. I just started to notice smoke under the hood when the car stops. I'm not sure, but it seems as though the head gasket leaking. How can I verify this, and is this something that I can change myself. I am mechanically inclined, but not at all a gear head.
I think you are talking about the valve cover gasket. The head gasket would be under the exhaust. The valve cover gasket is easy to change, but there are a couple of hints I can give you. 1.) Don't forget to remove, then replace the ground wire that is bolted to the cover. 2.) DO NOT over-tighten the valve cover acorn nuts. The small studs break easily, (the nuts only torque to 7lbft.). If you don't have a torque wrench, use a nut driver so you will be less inclined to over-tighten them.
Thank you. Does that sound like the valve cover gasket to you? Is there a way to be sure. It looks as though it is seeping out near the nuts that hold down the cover.
I have a 95 Accord LX 4-dr sedan. I was out driving today. Near the beginning of this drive I heard a rattling noise up front. A few times after stopping at a sign and then speeding up again, the speedometer & tachometer would go down to zero for a few seconds, then go back up. After a while the noise disappeared and the gauges seemed to function normally. A half hour after returning home, I went back out to start up the car.
It started up immediately and strongly, but then almost instantaneously died (a second or two) as if something wasn't engaging (rather than sputtering or choking or stalling as if it wasn't getting fuel). It seemed like whatever the next stage in the starting process that was supposed to occur wasn't occuring. Did this a few times with same result.
Any suggestions/help/insightful thoughts would be appreciated.
Sounds like it could be the ignition switch. If you want to do some troubleshooting, here's a link that might help. Good luck. (the link is for 4th generation Accords, but hopefully the information still applies for a 95). http://techauto.awardspace.com/ignition.html
Thanks. I'll read that material over. None of the interior stuff (radio, signal lights, wipers, etc) that would normally be operable with the key in the on position will come on now. The headlights and rear brake lights do come on. The various warning lights that flash on start-up do so very briefly went I turn the key all the way now, but they don't remain on after the start-up fails, which I think they normally did on occasions in the past when, for whatever reason, the car didn't start on the first key turn. Does that bit of information add any perspective?
Sounds like the ignition switch. The head lights are not controlled by the switch, so they would not be affected. You probably need to change the electrical part of the switch, and not the lock cylinder (which would mean new keys). I've never done one, but I think you just have to remove a panel on the steering collum to get to the switch. The link I gave you should help in removing, and or testing it. Good luck
Installed a new ignition switch (with some difficulty, lol) and it works - thank you very much Elroy. Hopefully Ill have no further problems with this.
My 94 sunroof is stuck open. When you push the close button nothing happens(no motor sounds). Is this a common problem? Is there a way to test to see if it is the switch or the motor? I checked the fuse and it was good. I'd just like to get it closed so I can drive it.
There should be a little crank in the tire-tool kit that you can use to manually crank the moonroof closed, until you can get it working again. You should be able to find a plug in the headliner, that you can remove, to insert the crank. Test to see if the power is getting to the switch, then see if the switch gets the power to the motor. Good luck
There are two relays associated with the sunroof. The switch activates the open or close relays. They are in the kick panel fuse panel. A lot of the relays are the same and you can swap they around to trouble shot. There are relays for some things in the engine area power panel near the left fire wall. Just check the relay numbers.
my 97 honda accord has been inactive for 30 days. The battery is fully charged but only my horn works. I just recently replaced the battery cables. and tried to jump start it but nothing happens just the horn and brake light
The horn and the brake lights don't need the ignition switch to operate. Do the head lights work? Does anything come on (dash lights, etc.) when you turn the key? If not check the ignition switch (electrical part).
I have a 97 honda accord se. When I start my car it revs really high and then will start to rev up and down while im still in park. It tend to do the same thing when I sit at a red light longer than a minute. Im not able to put it in park or let it idle without it doing this. I already replaced one of the idling valves, got a new battery and cleaned out the valves. Any suggestions?!?
:mad: Great! After months of happy motoring in my accord, I noticed that I felt kinda blind sighted when I was driving in the night... Then when I pulled up to my house, I saw my headlights are WAAAAY off in vertical aim. Any tips for getting them to aim right and possibly a how too?
Oh and also, I actually got a chance to drive my sisters millenia at night. :surprise: I COULD SEE!!! :surprise: SO not only do I have off centered headlights, but they are quite dim now too. :sick: Any tips on brighter non xenon (H.I.D.) headlights?
Finally as a sort of update, I solved my antenna issue. I just got it to retract all the way and unplugged it. So no more up and down. Then came the poor reception. I ended up just pulling it up some (spoiler height) and Its great reception without being too high. I am also saving to get some LED replacement taillight bulbs to replace my current bulbs. What are you guys opinions on this? I was going to use superbrightleds.com for my purchase but I have no clue where I want to go with this.
My accord wsconsuming oil at one point in time too where i was puttin in a quart per tankfull of gas. it turned out to be me needing two new oil valve cover gaskets. Since the repacement, I'm adding oil regularly. Also, my mpg went up too.
hi im new to this so i dont know how to post an new blog i seen yours talking about 260k and i was wanting to know if you could help me out i have a 94 honda accord automatic 4 door and it starts a little when you start it up and over heated one time my dad said the car has 200k on it =-( but hondas are a good car for alot of miles the tranny has not gave a bit of proble and it only take 15 bucks to fill it up full of gas. is there anyway it would have a blown head gasket? it only smokes for a few mins wether it is below 60 or above 60 degrees. can you possibly let me know what would be wrong with it or respond me to someone on here that may know?
When valve seals leak, they will leak into the cylinders while the car sits (not running). Then, when you start the engine the accumulated oil will quickly burn off. The oil that drips through the seals while the engine is running will usually not produce enough smoke to be noticeable. It's not something that will really hurt the engine, but it will only get worse over time. I have no idea how much a shop would charge to change the valve seals, but it shouldn't be astronomical. How much oil does the engine burn through between oil changes? If it's more than a quart in 3000 miles, or if the smoking is really bad (fouling spark plugs), it should be fixed, IMO.
I am facing the same issue with my honda accord cigarette lighter. It's loose and coming out of the assembly. Please let me know how you had fixed it.. Thanks.
I am having the same issue with my honda Accord cigarette lighter assembly. It's loose and falling out of the assembly. Any ideas how to fix it? Thanks.
There is a way to do it. You have to remove the center console to access it. If you search on-line for instructions on how to replace the radio in a 1996 Honda, it's essentially the same steps.
It's very easy and should only take 15-20 minutes to do. I have almost no mechanical aptitude and I found it very easy.
For the last few days, the brakes feel kind of soft & "mushy"; that is, the resistance seems less than before. I haven't had to make any fast stops, but the brakes seem to work ok for the most part, even on steep downhills. Usually if you pump the pedal a couple of times the resistance seems to firm up, but even then, if you hold the brake down, you can sort of feel the pedal sinking under your foot, after an initial period of greater resistance.
I bought the car new nearly 15 years ago (about 160,000 miles), and this is the first time, I believe, that I've had this exact problem. In earlier life, when my at-that-time economic circumstances compelled me to drive a succession of used American- made beaters, this was a not uncommon problem for me, but with the passage of time and the availability of more reliable Japanese-made cars, I've kind of forgotten what the exact cause of it is, though I'm sure I must have known the answer at one time.
The first thing that popped into my mind was that the brake fluid must be low, but, as near as I could determine, the level seems to be ok. I know that in the full spectrum of automotive problems which can exist, this is a fairly common one, so I'm hoping that someone out there can jog my aging memory and tell me what's causing this symptom and what I could/should do about it.
Thanks in advance for any advice or input. I greatly appreciate anyone's insight into the nature of this problem.
Sounds like your master cylinder is leaking. Mine was replaced in my '96 LX I4 at around 175k miles. Brake fluid been changed regularly? I bet not. Water gets in the brake fluid and breaks down the seals. Was a $300 repair at the dealer.
No problems since, and I'm at 191k on mine. Amazingly, I've never replaced the rear brakes, and the fronts are still good after over 55k miles.
The honda master cylinders internal seals will fail and there will no external leak. The fluid by passes the internal piston seal. My honda had the same problem, changed the master cylinder and now have excellent brakes.
Thanks for that amazingly swift feedback. You guys both sound pretty certain about the nature of this problem. Are there any other obscure and perhaps less costly explanations for what I'm experiencing, or is the master brake cylinder the culprit with something approaching metaphysical certitude?
If I can't get around to a repair in the next couple of days, is it dangerous to drive this car - I mean, is there a possibility for a catastrophic brake failure?
While I wouldn't postpone the repair too long, I drove mine for weeks before realizing a problem existed. it'll just slowly get worse, in all likelihood.
And, that problem is fairly common, in many cars. It's easily diagnosed, typically. Catastrophic failure? Unlikely. The brake system is divided in half, I believe, so if one part goes (either Front Left and Rear Right, or Front Right, Rear Left) you should be left with the other portion.
If the brake pedal sinks, with steady pressure, either the master cylinder seals are leaking, or there is a fluid leak somewhere. If you don't see fluid leaking anywhere, you likely have a master cylinder problem. A spongy feeling brake pedal is a sign of air in the brake lines (need to bleed the air out). If the brake pedal seems to push back on your foot, that is a sign of vacuum/booster problems. Brakes are pretty simple, until you get into ABS, SC, etc.
I don't want a photobucket.com membership.
Sorry
So now, not only is the light not visible but you can't hear it either. :shades:
Thanks in advance for any help...
any ideas please
:sick:
Service Manual available at
http://pdftown.com/PDF-Honda-Accord-1994-1997-Service-Manual.html
Any ideas?
The manual reference in message 1333 is no longer available.
xxxhttp://pdftown.com/PDF-Honda-Accord-1994-1997-Service-Manual.htmlxxx
Check for 94-97 Honda Factory Service Manuals.
http://www.hondahookup.com/manuals
You will need to register to download. no big deal its free.
John
John
Download this F.S. Manual it has complete documentation on the sunroof Electrical and Mechanical.
except the horn and brake lights
$111 for parts and $80 for installation.
Mrbill
