Visitor Agreement.
I have a 2007 Tundra 5.7L and I tow my holiday camper. What is the ideal RPM for towing, along with a combination of transmission and tow haul mode?
I've read that the truck gets 401 foot pounds of torque at 3600rpms.
Over the last year I have tried a few things
When on Highways of speed limits of 100km I usually put it in Tow haul mode and in S mode on the transmission in 5th gear. This will give me 105-108 km/h at about 1900-2200rpm, pulling hills at 3000rpm
When on highways of speeds of 110 I usually put it in Tow haul mode and S mode on transmission in 6th gear. This will give me 110-115 km/h at about 2000-2500 rpm and pulling hills at 3500 rpms.
I use to drive truck in the bush and remember that the more you lug a Caterpillar and heat it up the better it pulls and a Cummings the more you rev it the better it pulls. I know you are talking about a Tundra with an aluminum block and a caterpillar with a iron block.
I came through the Rocky Mountains last week and had no problem pulling any hill but the main question I have is on the big hills do I pull at 3600rpm or do I lug it and pull it at 2500rpm?
Hope I could help.
also if you do landscaping snow plow cad be put on but only with the heavy front end bleive it`s a 4000 lb rating but check spec`s..
last time out a new Mighty Toyaoooata Trunda towing what i estamite to be around 7K trailer attempted to pass going up a hill.
My firt thoght was you have got to be kidding me???
I steped on my Powerstroke and the last time I look the Toy was looking at the rear of my rig......
Plus I get 20 MPG empty and 13 MPG towing.
Dont buy a trundraaaa for towing,
I own a Tundra 2007 And I tow a 5TH wheel weight of almost 11,000 lbs. Not to mention the heavy tongue weight. I did change the tires from the standard toyota provides to a michellin 10 ply. Other than that were on the road. Towed from flat Florida to the mountains of North Carolina. Averaged 65 mph and got 9.5 miles per Gal. I was very impressed as I believe you too will be. Towing was not a problem on the hills and I did pass the slower moving semi's with out a problem an with lots of power and torque. Braking was also very good.Don't let anyone tell you the Tundra is a light weight. It is far beyond its class. No telling what the next generation Tundra will do. LOOK OUT It well be a killer I'm Sure..
trans or you had it done through third party tran shop??
I know they will provide better sway contol and I'm sure they are more puncture resistant. I'm my opinion, the tires on 3/4 ton trucks are one of the main reasons they handle towing better.
I do expect a slightly stiffer ride and have no problems with that as long as it's reasonable and not bone jarring. Actually, I see no reason to run much over the door jamb recommended presures, even though the tires can go to 80 psi to take advantage of their full capacity but that's beyond what are trucks can safely handle anyway.
Question is... Has anyone done this and how did it work out. Ride? Tire wear? What pressures work best, empty, loaded and towing?
Check over this chart:
Bridgestone Load/Inflation Chart
LT275/65R18 is on the last page.
kcram - Pickups/Wagons Host
that weighs about 3000 lbs. Would like to take that with me on my next trip. The boat trailer has its own brakes. Any comments on this.
that solved it,I hooked up my camper to the 5th wheel,my bumper only dropped 2.5 in.the rubber stop had one inch clearance from the bracket,this is with 1665lbs tongue weigh.My question is do I need to install air bags or helper springs if so which one,and where do find them.
I'm thinking of buying a tundra to use for towing either 5th wheel or TT. Do you have advice for an old lady? I had a 99 ford 250 Lariat powerstroke for a 5th wheel. Traveling pal got sick so I sold them and got a 06 4Runner. The only truck for me now is a Tundra. Used but very well-kept. Until today, I thought they were too light but then I read that trailers have gotten lighter since my '94 Jayco. I value honest advice way above dealer blah, blah.
Jody in Colorado
Regards, BGood
Have a great day.
My question is this: I was told by the NC Toyota dealer to always tow in S-4 due to the 1:1 ratio (???). My gas milage going across country in S-4 all the way was between 5 - 7 mpg. When I arrived in Durango, I spoke w/ the a dealer here about the mph who said I should have driven it in D all the way except for mountains. I've read the manual that came w/ the truck, but it is not clear to me when I should be using the S-gears. Please advise.
Other than that... it towed like a dream... much better than my Pathfinder.
Any thoughts on whether I should add the camper or not?
Rich
