Chevy HHR: Problems & Solutions
On the LS it says head-curtain side-impact air bags are required while on the 1LT is only available in conjunction with OnStar.
Please post if you find out other information.
Your knocking noise?...do you fill up with Supreme only..2.4 liters only run on supreme
When i took it to the dealer they couldnt find anything.....
The dealer tried the A/C repair the first time I took it in. The second time, they found a hole in a front cowling that they covered. It rained all day today and when I went to my car after work there was water standing in the driver's side floor. The carpet was soaked and there was at least 1/2 inch of water on top of the carpets and floor mats. I took it straight to the dealer and they are keeping it to show to the "leak expert". They've given me a loaner HHR to use until they fix the problem. The loaner is bottom of the line with no XM, sunroof, or heated seats.
I'm really frustrated. I want my car, without a pond in the floor! Can anyone comment with possible fixes to this issue that I could suggest to my dealer?
I have my car back and now I'm waiting on the next rainstorm. I think it will end up back in repair before that as the gas mileage has dropped significantly since the dealer "fixed" the leaks. I think they disconnected soemthing and forgot to put it back, or else the plugging up of the leaks under the hood restricted air flow to my engine and it isn't running properly now.
I am also going to insist they replace the carpet due to discoloration.
Good luck with your car!!
Thanks in advance
Lucy
One thing I found that works wonders for removing some of the ground in dirt and grime from the plastic pieces (emergency brake handle, steering wheel, plastic panels in the cargo area, etc...) is the "Mr Clean Magic Eraser". You simply get it wet, ring out a lot of the excess water, and start wiping down interior pieces (no cleaning solution needed). You would have to actually try it yourself to see how well it works.
As a test of the Magic Eraser, I tried the following - There was some grime on the emergency brake handle. I took a terry cloth towel with a little cleaning solution and tried cleaning half of the handle. I scrubbed quite a bit with the towel, and made little progress. I then took the damp Magic Eraser, and after about 30 seconds of wiping (no exaggeration), it was spotless. After seeing how well it worked on the handle, I then used it on the rest of the plastic interior pieces that were dirty. When I was finished, all of the plastic interior pieces were spotless.
Regarding the carpet, my wife has an upright carpet cleaning machine we use for our carpets in our house (looks like an upright vacuum cleaner, but has a tank for hot water, and a second tank for cleaning solution). It also has a hose with and upholstery cleaning tool you can use to clean a sofa or chair. I found that using the standard cleaning solution (I think made by Bissell?), and cold water, I was able to get the carpets looking brand new using that hand upholstery tool.
As for those light colored seats, I have found the least amount of water/dampness used to clean spots the better. They seem to water spot easily. They had a couple of small dirty spos on their seats, and I started by using soft bristled brushes on the dirt spots. I finally took the aforementioned Magic Eraser, got it wet, rung it out, and wiped it over the dirt spots. That process seemed to pretty much get rid of the dirty spots.
I complaint, and i have a case number with chevrolet and the BETTER BUSINESS BUREAU, they are in it.I'm sure is goin to be a RECALL.KEEP ALERT FOR THOSE WHO HAS THIS SAME PROBLEM.BYE AND GOOD LUCK! :sick: :sick: :sick: :mad:
Lets look at the listing of defects of the HHR just on this site, (Edmunds).
Water on the floor when it rains
Check engine light on
Wind noise
Radio off "static"
Radio on loud crackling pop
Paint problems
Drive train vibration
Bad front rotors
Bad fuel pump
Growling / groaning noise from the engine when taking off from a traffic light
Engine knock on a cold start
Lower control arm snapped off while the vehicle was being driven
I think that this vehicle has some VERY serious operational problems.
At this point in time, I am looking at an Impala, Honda Accord, Ford 500, Toyota Camry, Chevrolet HHR, and the Honda CR-V. The Impala LT2 is a VERY nice vehicle.
QUESTION: Did General Motors forget how to design and manufacturer a vehicle? This is more than just "teething" on the part of the HHR. GM has a nice vehicle that could be making them some money, and they "dropped the ball" in terms of quality. I hope the 2007 HHR has more quality! --- Best regards. ----- Dwayne :confuse:
1-No power; you need to anticipate every hill and accelerate before it's too late.
2-Turning radius too large.
3-Huge blind spots.
4-Plastic cargo floor; everything slides around.
5-At highway speed, I smelled exhaust inside (I believe the rear hatch was not sealed properly).
6-Cup holders too hard to use without looking down away from the road.
7-No decent storage compartment.
8-Window controls are behind shifter and hard to use.
9-Can't open doors without pushing power unlock first.
10-With rear seats up, the headrests are in your rear view.
11-Poor quality radio/sound system.
It did ride nice, seats were comfortable, climate control more than adequate and mileage was good. Still.... NO Sale.
What about all of the other issues listed on this site. Does GM just get a "pass" on these issues???????????? -----Best regards. ---- Dwyane :confuse:
We're moving away from these large generic discussions, and setting up smaller more focused ones. This is a work in progress, so if you don't find a discussion that fits the issue you want to talk about, please feel free to create a new one and we can adjust things later if need be.
Thanks for your patience and assistance as we move the furniture around!
I'll be moving posts out of this discussion to help get the new ones rolling, so if you find that some posts seem to have disappeared, that's the explanation. Just check the discussion list for the group by clicking on the link in this post to find the appropriate discussion.
