Toyota Highlander
1132133135137138211
    is that kind of HP in an SUV good for?
    340HP normal, way excessive HP for the TT.
    why didn't they build a race truck out of the Cayenne? Forget all that offroad ability that supposedly nobody uses - this is porsche after all. Lower it, give it radical styling and street suspension or even track suspension. Make it the SUV version of something like F-150 Lightning, only blow lightning's performance out of the water.
    Folks in other threads have been saying that the new 4Runner and the highlander are polar opposites on the styling spectrum: 4Runner was a major gaffe, whereas highlander is one of the best-looking vehicles Toyota has ever sold...I tend to agree...care to comment?
    The HL looks even better than the RX IMHO. I can't develop any good vibes for the 4runner becuase it's so big and bulky with not enough addition interior space to justify that.
    My idea of an ideal SUV would be the HL, or the RX, with the 4runner torsen diff'l and the A-Trac.
    The 01 AWD RX's Trac system was supposed to do a lot of what the A-Trac system does but I have started to suspect the firmware is setup to not be as aggressive. Anyway it never seems to come into play in mine.
    I have had the VSC engage a few times, at least I think that's what happened, but never the Trac.
    I keep resisting moving to the X5 and right now I'll likely delay it again in hopes the Rx and the HL get some serious AWD firmware upgrades next spring. And maybe enough rear wheel clearance to use snowchains safely.
  • personna1personna1 Member Posts: 10
    Just wanted to get a bit of my HL testimony out there...
    I bought a 2001 HL Limited back in May of 2001. Since then I've put 40K miles on the vehicle and I can say that I am extremely pleased with the performance of it.
    In my 40K of driving, I've averaged 21.8 miles per gallon performing mostly highway driving in the Seattle area. (In case you don't know anything about the Seattle area, highway driving here is about 50% "stop and go" and 50% "go" depending on the time of day. I say this because highway driving in other areas of the country are much less "stop and go" and thusly gas mileage from those areas will probably be higher.)
    Interesting, after putting DuraLube in the engine, I had three tanks (within 3000 miles) where I hit between 24.1 and 24.8 MPG. After changing the oil two more times, the MPG went back to around 21.x. I guess you have to keep putting this stuff in from time to time.
    Anyway, I've only experienced four issues with my HL, all of which I consider minor. (Note: I consider it very good that I've only experienced four issues considering I bought the "first year" model of the vehicle. This is a good testimony of Toyota getting their quality issues right the first time.) The four issues... 1) Occasional reedy like wind noise through front doors during strong side winds. (This issue was resolved, by Toyota, by replacing the door seals. This was fixed under a TSB (Toyota Service Bulletin) and didn't cost me anything.) 2) Glove box rattles. (This issue was also resolved by Toyota via a TSB. It's amazine what some small pieces of felt will do. :) ) 3) Moonroof cracking/snapping noise during warmer weather and/or while driving over expansion joints on various bridges in the Seattle area. (This issue, again, was resolved by Toyota via a TSB. I think felt washers were used to correct the problem.) 4) Paint chips on hood caused by rocks/debris. This issue has not been resolved for me. I suspect the paint is not protected by a thick enough layer of that clearcoat material. Most of the chips are located 10-12 inches back from the rock deflector. I may end up having the hood repainted and a thicker clearcoat applied... It depends on whether I think the cost will worth it to me. However, I still consider this issue to be minor because it doesn't affect the overall performance of the vehicle.
    Other than these issues, my experience has been nothing but positive.
    On a related note: The tires on my HL are really starting to get worn, so based on the discussions I've seen here, I'll look into getting some Michelin CrossTrains for it shortly. Thanks for the recommendations!
  • banner1banner1 Member Posts: 14
    Have any other Highlander owners noticed a soft brake pedal: I know this was probably a topic before but I was wondering if there are any adjustments or bulletins.
    Are there any web sites that list service bulletins? Thank you.
    Technical service bulletins? Yeah, alldata.com, the NHTSA and us:
    The Edmunds Maintenance Guide.
    Between these 3, you can usually find most of them :-)
  • robert_carobert_ca Member Posts: 34
    I am in the market for an all-season tire for my Toyota Highlander and one of the tires I am considering is the Nokian WR.
    The description of the Nokian WR is as follows:
    "Only "4-Season" S.U.V. tire to earn the Severe Service Emblem (snowflake-on-mountain).
    All-weather silica compound provides excellent grip on wet surfaces while maintaining winter properties. The WR's arrowhead unidirectional tread pattern and unique tread positioning effectively expel water, snow and slush. WR features long service life and low driving noise on dry pavement with excellent off-road capabilities. Excellent handling and control in wet weather, while maintaining Nokian's "uncompromised" lateral grip on snow,
    ice and slush."
    http://www.nokiantires.com/indexen.html
    From the little info that I have been able to find on the web, the consensus seems to be that it is a winter tire. I'm confused, is it an all-season or winter tire? Anyone familiar with this tire?
  • lexus_addictedlexus_addicted Member Posts: 24
    This flaw isn't a mechanical one or the lack of third row seats. Rather a flaw in its aerodynamics.
    The rear windows are useless in anything above 40 miles per hour.
    Try to run at that speed with one or both of the rear windows open at about two inches, you will see what I am talking about.
    Your eardrums will pop when you have to endure that thunderous wind booming sound for anything longer than 5 minutes.
    However, one funny thing that I've tested out is that if I completely lower the rear windows, the eardrum shattering wind boom will disappear, the car will just be noisy with wind, but not to the point of pain in my ears.
  • toyotakentoyotaken Member Posts: 897
    If you look at other forums, you will see this is a common phenemon on most new vehicles today. If you have a sealed vehicle, and you increase preasure by opening an individual window (normally rear) it will reverberate. This happens at different speeds depending on which window is open, how much it is open, and what type of vehicle you are driving. SUV's are more prone to this issue because of the larger volume interiors and larger sheetmetal panels (such as roofs, etc.). This frequently pops up with any vehicle with a moonroof or sunroof. The easiest way to elimate the problem is if you open one window, at least crack open another and it relieves the preasure and/or allows a more fluid flow of air through the vehicle.
    I actually have bought a brand-new set of Nokian tires for my car for this winter. They have three different series of tires available. One is a set of snow tires with the mounting sites for studs. The second is a standard set of snow tires. The third are a more all-season rated set. Their all-season tires are brand new to the market this year. From what I have seen from people that have had the snows before this year, they hold up pretty well. One person I know has a Ford Windstar and he and his wife have 5 children. (lots of driving) They have used the Nokain snows year-round on their van for the past several years. They typically get about 35,000 miles to a set of tires. This is actually surprising if you've seen these tires in person. The tread seems VERY soft, but from what I have heard from people who have gone to some trainings on them, they are designed to have alot of flexibility but wear well. I would expect if their snows hold up as well as I've seen, the all-seasons should be even better.
    The other feedback that I have heard about the all-seasons from Nokian is that they were designed to acually be all four seasons. Meaning that they are designed to actually handle snow and ice on a regular basis in the winter. Where normal all-seasons are really primarily set up to have best performance on dry roads and give good performance on wet roads and adequate grip in very moderate snow conditions. That is one of the reasons they recomend that you use a snow-specific tire if you live in a snow-belt.
    Sorry to get so long winded, but I hope this helps.
    Not anything new at all.
    When you roll down your windows "at speed" you're simply converting it to a large replica of a kid toy whistle.
    Phenomena has been with us since cars went to closed passenger cabins. It can be avoided in vehicles that can lower the rear window, Ford station wagons, or open the rear quarter panel winglets, Chrysler T&C.
    What surprises me is that I've made comparisons with my 1996 4Runner with rear windows (one or both) partially opened, and the Highlander in the same circumstances is much much more deafening than the 4Runner.
    While the 4Runner is simply very noisy with rear windows opened, it isn't deafening, my ears can cope with the noise, but I can't do the same with the Highlander.
  • cmcardlecmcardle Member Posts: 71
    Interior might not be sealed as tight, or there may be a stronger "passive" air flow (through the ventilation system).
  • beachacebeachace Member Posts: 7
    I purchased my 2001 Highlander limited in Aug. of same year and have been very lucky with it. I love my Highlander but have just ordered a 2003 Sequoia. My dilemma is that this Limited has every Option except the Heated seats. and the dealer only wants to give me $24,500 on the trade. I have a great price on the Sequoia Limited with everything. Has anyone had any experience with trade-ins on Highlanders and is this price low since I still owe $25,500 and just want to break even?
    All help is appreciated!
  • m4ethm4eth Member Posts: 101
    Robert,
    I've got a set of Nokian's I use on my Toyota Echo here in Dayton Ohio...we get ice and snow mix on occasion...tires appear to work well and ride very nice compared to the Brigstone's orginally on the vehicle. I also have a 2002 4WD HL and replaced the Goodyears with Michelin Cross Terrain's...they are a bit stiffer than the Goodyears but I haven't had a chance to use yet in snow or ice...Tire Rack shows the ratings on this tire...appear to be good...too bad they don't show the Nokian's...
  • tfuzztfuzz Member Posts: 93
    Sounds as if it might be a reasonable deal to me. Edmunds "True Market Value" says 2001 HLs are worth around $21,707-22,344 as a trade-in, depending on equipment, condition, zip code, etc. Just two days ago I traded my 2001 HL Limited on a 2003 4Runner Limited. I figured I got about $22,000 for the HL--if I got about $1600 off the MSRP of the Runner.
    I just traded my '01 Highlander for an '03 4Runner. The new Runner has the same deafening wind noise with just the rear windows down as the Highlander. I personally didn't/don't find the noise to be that much of a problem. Adjusting other windows or the moonroof cancels the noise.
  • 93fsu193fsu1 Member Posts: 97
    My wife and I just completed a 5,000 mile, two week road trip in out 2002 HL Limited V6.
    It performed flawlessly from Florida heat to Canada cold weather. It was nimble in the streets of New York City battling a sea of yellow cabs. The horrible Boston streets jolted her a bit but less than most vehicles.
    The only thing I would change about this vehicle is that I would prefer to have some Nissan seats in it. And someone should invent a way to secure yourself with seatbelts while fully reclined.
  • carpeople1carpeople1 Member Posts: 13
    excuse me, my family and i are considering getting
    a midsize SUV. we need it for versitility and space, but also need a car-like ride. We are looking at the highlander, probably the only one that we are interested in( we looked at Rav4, Rendesvus, Pathfinder), but still not sure if this is the right one. If we buy it, it ill be the base, no limited, and probably get 4WD, but want to know what other competition can match the Highlander. The SUV can be slighly used, like 2000+, we really need help making this decision and would appreciate all the advice you can give us
    thank you for your help
    The king's new clothes...
    Like the Lexus RX300 AWD, the Toyota Highlander AWD system is no more capable than the FWD version.
    I really hate to suggest a Ford to anyone, but the Mazda Tribute or the Ford escape will out AWD either of these.
    If you think you will have times when you truly need AWD, wintertime ON-ROAD low traction conditions, then the HL is not your cup of tea!
    Explain to me and everyone else out here what your argument is that AWD in general and AWD versions of the Highlander are no better handling than FWD? You just make a blanket statement and don't give any supporting information.
    I've never made a "general" statement about AWD. Only that the HL and RX versions are not truly AWD, not even close.
    But now I will make a general statement about AWD that is predominantly FWD. On low traction surfaces it is predominantly unsafe! Just as unsafe as any FWD vehicle.
    Well, almost any. The newer FWD Cadillacs have an over-running clutch so lagging engine torque doesn't brake the front wheels. I suppose some other FWD vehicles also have this feature.
    With the HL and RX engine drive torque will be distributed evenly, 25% all around, as long as all four tires have approximately the same roadbed traction. The instant you encounter disparate traction is when you get into trouble.
    In a normal, or standard VC design, once there is a disparate rotational rate between the front and rear drivelines the VC will stiffen up within a few hundred milliseconds and "moderately" lock the two drivelines together.
    How quickly is usually a function of the size of the "gas bubble" within the fluid container, how moderately is a function of the formulation of the fluid itself. A viscous fluid with a high thermal expansion coefficient, once the gas bubble is fully compressed, will increase the coupling coefficient between the drivelines dramatically.
    Apparently the formulation for the viscous fluid in the HL/RX VC allows it to remain flaccid for many seconds and then once it does stiffen up the coupling coefficient is so low it can only route about 25% of the torque to the rear.
    You can try it out for yourself.
    Drive the HL or RX in a circle continuously with the power on but at a safe level. Once the VC stiffens up the drivelines should begin to be stressed just as they would with a locked center diff'l on dry pavement. You should begin to "feel" that driveline stress as feedback, push-back, against your steering inputs.
    Now try the same trick in a "true" AWD vehicle like the Jeep Cherokee Limited, or even teh Chrysler T&C. But be sure and keep your thumbs and fingers clear for when the steering wheel jerks out of your hands.
    The speed differential between the front and rear drive shafts resulting from driving in a circle aren't going to be sufficient to make a significant difference in the viscosity of the clutch pack in the center differential. The idea behind the viscious coupling is that if the front or rear wheels start to spin (meaning they have no traction and they are spinning very fast and the opposite drive shaft isn't spinning at all) the speed difference in the drive shafts cause the viscous coupling to start transferring power to the opposite set of wheels. This is a progressive system, so if there isn't enough power going to the other end of the vehicle to move it yet and that wheel is still spinning, it will progressively send more power to the other drive shaft until it has enough power to move. This system is even more effective with the LSD (limited slip differential) in the rear. Your other examples are of a different type of AWD system from another manufacturer. The tolerences are different. And when I say different, you notice that I don't say better or worse.
    For on-road situations, the AWD system on the Highlander can be very effective. It is not fool-proof, just as any 4wd or AWD system can be defeated, but it does give additional traction and stability in slippery situations. For getting through a parking lot or driveway that hasn't been plowed yet, or snow-filled roads, it will make it much less likely that you will end up stuck.
    And if you get the VSC, it will be proactive to prevent you from getting into a situation you can't get out of. If you're going around a turn and you oversteer (start fishtailing), it will apply the brake to the appropriate wheel to help keep you pointed in the right direction. If you're going around a turn and you're understeering (plowing through the turn) it will do the same thing to assist you in turning. And lastly, with the TRAC traction control, if you're spinning a particular wheel, it will apply brakes to the appropriate wheel to direct power to the opposite wheel. These three situations will all involve some engine throttle control as needed as well to maximize effectiveness.
  • 03bluestone03bluestone Member Posts: 47
    I previously owned a 1998 RAV4 AWD and it went well off-road in mud and on-road through 21 inches of snow. I hope my AWD Highlander does as well and I think it will as I am told the AWD systems are very similar. Does anyone have a techncial comparison between the RAV4 and the Highlander AWD systems ? (My HL has TSC too.)
  • brad_22brad_22 Member Posts: 154
    Who did you buy your spacers from? I've checked out some brands on the 'net but none are Highlander-specific. Thanks.
  • candyman85233candyman85233 Member Posts: 43
    We have a 2001 Highlander Limited (Indigo Ink with Gold) that has 30,000 miles on it.
    Anyone have more than that? Just want to know what to look forward to and if there have been any additional problems.
    I checked out the 2002 with the console and that is pretty cool. Too bad can't retrofit it into the 2001 easily.
    Last week I traded our '01 HL Limited (Silver) with 31201 miles for a new 4Runner. The HL was a great vehicle and I hated to part with it, but I needed the capabilities of the Runner. No problems with the HL (once the wind noise was fixed), except the tires (Bridgestone Duelers) were wearing a bit quickly I thought.
  • landdriverlanddriver Member Posts: 607
    Detailed discussion about AWD aside, the Highlander is a great vehicle and almost all who have purchased it are very happy with it, as previous posts to this discussion attest. It has a smooth, quiet car-like ride and its reliability is great. Definitely go for it!
    From my understanding, the layout of the two systems are pretty similar. The biggest difference between the two is the size. Size meaning that the highlander has bigger engines both 4 and 6 cyl. with more power. The Vehicle itself is bigger, so needs a beefier drive-train. The electronics on the Highlander are a bit more sophisticated as well. With ABS standard equipment, TRAC traction control, VSC (vehicle skid control), and a limited slip rear differential all available, it all adds up to all of the benefits that you found with your RAV-4 along with a bit more electronics aiding you if you do happen to overstep the limitations of the vehicle.
  • gwleonggwleong Member Posts: 36
    This has probably been addressed before so I apologize in advance.
    I'm planning to take my '01 H/L 'base', V6 2WD in the snow this winter. I have the stock Goodyear Integrity tires and will only drive 'on-road'. Possibly w/chains. Will I have any problems? Never driven in the snow before.
    I know the transmission has a "SNOW MODE" button on the shifter....never used it...does it help?
    If anyone had some experience with this situation, please advise.....or refer me to previous posts.
    Thanks in advance!
    Gary
    The basic priciple of the VC is that if the two sets of interspersed clutch plates have differing rotational rates that will create turbulence in the viscous fluid thereby heating it and causing it to expand in accordance with its formulation.
    Since the VC case is sealed as it expands it pressurizes the case thereby increasing the coupling coefficient between the two sets of clutch plates.
    And yes, you can "quickly" increase the expansion rate with a HIGHLY disparate rotational rate between the two drivelines, but you can also cause the fluid to heat with a slower but continuous disparate rotational rate.
    At least you can do that on an VC implementation of AWD that is truly designed at the factory to be a capable AWD system.
    Don't know about the HL for sure, but LSD cannot be purchased on an AWD RX with VSC/Trac. As you stated Trac should perform the functionality of an LSD.
    I can readily understand why Trac might not work on the front, but it doesn't work on my RX even on the rear.
    VSC. Can someone tell me why I can't accomplish exactly the same effect by going to tires with a little extra contact patch?
    with snowchains on the front of a FWD vehicle nor an AWD with FWD bias like the HL and RX, and I NEVER would want to gain any!
    Going downhill on a slippery roadbed with higher traction on the front than the back can easily lead to loss of control of the vehicle, even with an extremely experienced driver.
    If you test drive an HL or an RX notice that in the last moments of slowing or stopping, the 3 to 5MPH speed just before you come to a stop, the transmission will seemingly "upshift", reducing the engine braking to the drive wheels.
    Newer Cadillac FWD drive vehicles have an over-running clutch to prevent engine braking altogether.
    FWD vehicles, and AWD vehicles with predominant FWD torque bias, can be extremely DANGEROUS during operations on low traction conditions. Most everyone, your Toyota or Lexus owners manual included, will advise you that it is NEVER a good idea to have more traction on the front than the rear in wintertime condition.
    Becuase of the weight bias FWD vehicles ALWAYS have more traction on the front than the rear, so your're starting out handicapped from the get-go.
    Snowchains cannot be installed on the rear of the HL nor the RX, so whatever you do, assuming you value your life and that of your passengers, don't install snowchains ONLY on the front as Toyota and Lexus recommends.
    A couple of bits of information for you. The VSC does things that you just can't do individually. It uses a combination of the wheel speed sensors from the ABS system to compare individual wheel speeds and compares them to a yaw control sensor to sense if the vehicle is either over or understeering. These are all taken into account before the system kicks in. When it kicks in, there are things that it does that are impossible to do individually. Here are a couple of examples.
    Example one: Vehicle is going around a curve and is understeering. (plowing straight instead of turning due to lack of traction in front) What the VSC does in this situation is to engage the brake on the inside rear tire to help turn the vehicle in while reducing throttle to help the front tires regain grip and start steering again.
    Example two: Vehicle is going around a curve and it is oversteering. (back end is kicking out - start of a fish-tail) What the VSC does in this situation is to apply the brake to the wheel on side of the vehicle that is on the outside of the kick-out. At the same time it will allow the throttle to continue and as needed apply the brake appropriate in the rear.
    The AWD system in the Highlander is front-wheel biased in general. So if I remember correctly, something like 60% front and 40% rear power distribution is normal for regular driving. If, however it starts to spin one set of axles, it will transfer power. With this built-in bias, it may be that it isn't as sensitive to the situation you're trying.
  • awchan13awchan13 Member Posts: 44
    In my experience, I've never had a problem with or without chains on FWD vehicles or the AWD highlander in low-traction conditions. I've never spun out or had a problem going down hill. As far as I'm concerned, FWD vehicles can handle low-traction conditions much better than RWD. As far as rear-wheel drive vehicles, I've been in a few situations (1 with me driving, the others with friends driving) where the vehicle has spun out going uphill or on a level grade. In my experience, a rear-wheel drive vehicle is much more dangerous or can be just as DANGEROUS during operations in low-traction conditions. But that's my experience. I've learned how to handle a FWD vehicle, and have never had a problem...even living through 6 utah winters. What it boils down to is that the driver must learn how to handle his own vehicle (FWD/RWD/AWD) and learn the vehicle's limitations. In any event, if you find yourself in low-traction conditions (ie winter driving), always be careful no matter what type of vehicle.
    What wwest said is definately true. DO NOT PUT CHAINS ON THE FRONT WHEELS. Now you didn't describe what part of the country you live in, so I don't know how much snow you're talking about. It sounds as though you have lived in a warmer climate and have just moved into an area that gets snow. However, for most parts of the country other than those that can see 1 or more feet of snow in a one day period on a regular basis, the best advice I can give you is to get a good set of snow-specific tires. For most areas of the country, a relatively new set of all-seasons is adequate for most winter driving. However, when you have anywhere from 4" or more all-seasons do not have enough traction because the tread is not deep enough and doesn't have enough surface area to do the job adequately.
    A good set of snow tires gives you more traction, more depth of tread and more surface area than a regular all-season tire. The two that I am most familiar with and know are relatively good brands are Blizzak and Nokian. If you go out and look at either brand of tire, you will see what I am talking about in terms of tread depth and surface area. These two tires also use a softer rubber compound as well.
    With the best tires and the best vehicle on earth, there are situations where you may still get stuck. I would also recomend having a winter weather "kit" that you keep in your vehicle in general for when you're out in inclement weather. This should include a folding shovel, blanket, flasher or flares, extra pair of gloves and an extra bottle of washer fluid. Other than this, use your head. If you aren't comfortable or think that you can't handle the conditions, don't go out. Practice how your vehicle handles a few times in an open parking lot after the first snowfall, and you'll do fine.
    You may not realize it, but when speaking to me of VSC you're sorta standing in the choir loft speaking to the preacher.
    I am an absolute advocate of VSC, PSM, stability control systems. One correction on your dessertation. The Toyota HL and the Lexus RX VSC system brakes BOTH rear wheels on detection of understeer.
    But my point is this:
    If the VSC doesn't give me some sort of "heads up" when it activates how am I too learn where the "limits" are? Without the VSC having a "training" mode, how am I to learn where the limits are? In that case why wouldn't more roadbed "sticktion" be as much an advantage as VSC?
    Now I know there is an indicator on the dash, but by the time I look it seems to have extinguished.
    Think of the value of a "stick shaker" warning of an impending stall in a commercial aircraft, or even an audible stall warning indication in a private airplane. Both of these provide a "learning" means.
    With VSC, or PSM, absent some way to put the driver in the loop we just get braver and braver until we finally exceed even the VSC's recovery limits, not unlike exceeding the roadbed adhesion limits of a greater contact patch.
    I often think of that early fly-by-wire Airbus crash. It was later determined that the pilot could have flown the aircraft out of the situation had not the "firmware" designers decided to not allow the pilot to have control inputs which might over-stress the airframe.
    Had they not done that then those people would likely still be alive today and the airframe in some graveyard as a result of being over-stressed.
    Before you step in and take over control of my car, or even "as" you step in, give me some input as to what I'm doing wrong so maybe I won't make the same mistake the next time.
    Maybe something has changed recently, but the last time I took any Toyota out with VSC and it engaged (I do check to see what the limits are) along with the dash warning light, there is an audible warning tone. As I said, I can't really say on earlier models because I wasn't really paying attention, but the ones now do have a warning tone.
    My own experience has been that I often only needed snowchains to get to a plowed or already "packed", well travelled, roadbed.
    In those instances, short distances, VERY low speeds, no steep, or long downhill runs, VERY conservative driving, snowchains ONLY on the front can be okay.
    My suggestion would be that if you MUST use snowchains ONLY on the front then put the transmission in 1st gear and leave it there to help you remember to keep your speed LOW for the entire duration of the use of snowchains.
    But the bottom line is NEVER use chains or studs, or any traction device that will give you a substantially higher traction level on the front than on the rear except as an absolute necessity. AND go back to equalized traction just as soon as possible.
    The snow button on the console for the highlander that is labeled snow under "ECT" is for VERY slippery situations. It doesn't do anything while you're driving normally. However, when you come to a complete stop, instead of initiating movement in first gear, it starts the transmission in second. This is to reduce the amount of torque to the wheels to minimize wheel spin.
    And you knew, immediately, what corrective action to take?
    The "normal" corrective action for over-steering is to steer into the "skid" and get off the gas. That latter action does not apply if you're driving a FWD vehicle or a Porsche with rear weight bias.
    For understeering, if you have RWD, "your" choice is to lift your foot from the gas pedal while decreasing the turn radius slightly. If you have FWD, or FWD biased AWD, then you should decrease your turn radius slightly and then start praying unless you can lift the gas pedal so moderately or deftly as to match the engine speed perfectly with the "natural" speed of the front wheels, no driving nor lagging torque.
    I've done that on my FWD minivans. Haven't needed to do it since moving south, but I carry chains just in case. The need for conservative driving is almost an understatement. And sometimes chains can be handy for getting out of a ditch if you can get to the wheels.
    Not so sure about the HL or the RX but on the GS it modifies the entire transmission shift range and pattern and limits the engine torque output throughout the RPM range.
    A downshift into a lower gear at high engine torque output on snow or ice can be even more dangerous, and deadlier, than spinning out from a stop.
    Actually, it will not help the system to take the normal actions when the vehicle is out of line. Keep the wheel pointed in the direction that you want to go and don't exacerbate the situation by making huge steering inputs and it takes care of itself. It isn't foolproof (fools always find a way of getting around everything *LOL*) but it works pretty well. And it normally takes effect before the vehicle gets to the point that you can really sense it, so if its doing its job right, you shouldn't need to do much. However, just like any vehicle that you haven't driven in snow before, take it out where you can toss it around withought danger like a parking lot and try it out. See what it does and how it reacts to what you do. Other than that, just be reasonable and prudent when you're driving.
    Be rather stupid to unlearn the normal reactions and implicitly trust the VSC to get the job done?
    What if the circumstance I am about to enter, am "entering", turns out to be beyond the recovery capabilities of the VSC?
    No thanks.
    As I said, all of the electronic wizardry can't prevent someone who is determined to go beyond a vehicle's capabilities. And the first and most important thing that will prevent any situation is prudence and good judgement. Just because you have ABS does that mean that you wait to the last second to pounce on the brakes? I know I don't. The same applies to all of these electronic assists. If you push a bit too far while still being prudent, it will help you keep it in line. If you're just being an idiot, then you're on your own.
    Just as a side note, it's nice to actually have a discussion/debate with someone on the board without either party ending up flaming and making stupid remarks. Thank you.
    But first let me acknowledge that toyotaken is perfectly correct. In most instances the VSC will step in and take corrective action before your seat-of-the-pants sensor is even aware that something is out of kilter, over, or under steering.
    But that's actually the basis of my complaint. How does it differ then, from simply adding more contact patch?
    ABS...
    "Just because you have ABS does that mean you wait to the last second to pounce on the brakes?"
    In that one statement is wrapped almost the entire problem of all of the electronic gizzits and whizzits.
    From the very beginning there has been a public misunderstanding about ABS.
    Anti-lock brakes were not implemented in automotive vehicles to provide for shorter stopping distances. Anti-lock brake systems are there primarily to help you maintain directional control of your vehicle during severe or PANIC braking.
    And yes, there are some instances wherein ABS will allow you to stop quicker, but in many cases, maybe even most, the stopping distance is elongated with the use of ABS.
    One of these days in the very near future some bright automotive engineer will finally realize that the VSC system can be coupled to the ABS and then the ABS will not activate at all unless the VSC senses that loss of directional control is impending.
    "Back" to the Future...
    Between people thinking that they will stop on a dime with ABS and those who get startled when they hear the grinding noise and feel the kick-back, ABS has had its share of people who don't know how to use their vehicles. As you stated, in most instances, ABS will not stop you any quicker, and in many cases it takes longer to stop if they engage. But being able to steer while braking fully is a great advantage.
    In relation to your other question, about adding more contact patch, that is perfect in the right situation, but in others, it doesn't help. For example, a wider tire with a larger contact patch on wet surfaces is fine, unless you don't have enough water being directed away from the contact patch. In snow, wider tires can actually be a detriment. The wider tires on some cars actually hinder in that they act more like a snow shoe and don't dig down to the pavement, so exacerbate the situation as well. The other drawbacks to a wider contact patch are that a larger contact patch means more rolling friction, so lower fuel economy. Also wider tires tend to be more expensive, which not all consumers are willing to accept.
    But what I was asking was what is the advantage of VSC over a wider contact patch? Wouldn't they both "simply" give me a wider margin of error with my own "inputs".
    ABS.
    What if, what is important in this particular instance is stopping distance, there is no threat of loss of control nor is there any need for steering inputs? How many accidents could have been avoided over the years had it not been for ABS needlessly elongating the stopping distance in the above circumstance?
    I'm planning on getting some wheel spacers for my HL. The closest match I could find are 30mm H&R ones made for the RAV4 (60.1mm ctr. bore, 5/114.3 bolt pattern). Do you guys think this would work?
