Visitor Agreement.
This hesitation doesn't happen on our 2003 V6 FWD.
You input will be appreciated.
Give this a try and hopefully this will help.
Ken
Does Toyota/Lexus have some method of detecting IMPENDING wheelspin?
If so then that would explain a lot of this.
I wonder...
Turning heard during acceleration the outside front wheel will turn faster than the inside wheel. ECU thinks outside wheel is slipping?
Or a secret way to alleviate torque stear??
So far all car reviews only test the V6 Highlander, which is about 8 + seconds. I found no information about the 4 Cyl. HL
The OEM Bridgestone Dueler H/T have died. They showed excessive signs of wear on the left hand side - outside shoulder. The rest of the tread was 1/8" deep. Could have been due to entering / exiting freeways (right hand turn - car leans to the left). I replaced the tires with Michelin LTX M/S. Wow - what a difference. The cornering is much better. The ride is great. They are also quiet, yet the tread is aggressive enough to venture into snow and gravel.
On another note - I contacted my dealer about my front mud flaps tearing (like many others have experienced). I explained it was due to the wind pressure - which caused the flap to tear. The service manager was great - he told the service writer to order new ones under warranty. The service writer came over and looked very skeptical at the flaps - he felt the bottom edge to see if I had hit something. He treated me like I was a liar. There was some road dirt that had splashed up on the side of the front door. The service writer rubbed his fingers through the dirt (which I was annoyed about - as he was scuffing my paint). Again - he was trying to find some excuse to blame me for the issue.
Cutting a long story short - when the flaps came in - I demanded to put them on myself - as I didn't want them to "work" my vehicle over.
Not sure how much longer these ones will last - as they seem to be made identical to the last pair - same design, same material. If they last another 29,000 it will cost me about $50 each to replace (on-line parts specials).
And finally - I installed a Toyota Hitch (class II). It was about $330 with the mount and 2" ball. Fits and looks great.
There are ways to minimize it, step on the the gas slightly for a second or so trying before trying to accelerate a lot, to force the tranny to pick a high gear (if you step on it too hard, if shifts too low). Also pay attention to the RPMs before trying to accelerate...
But I do hope they can fix it in firmware...
This sounds like the hesitation of the RAV4, '01 and later, that many experienced.
I had it ('01 RAV A/T), but it only happened sporadically, about 4 times in the first 4,000 miles, and not since. Almost like it sorted itself out. Maybe it has to do with fuzzy logic.
But in your case, at 9,000 miles, and your being able to create the condition at will, it sounds like a more serious problem.
-ss4
Cross terrains - although they may be a better tire - I didn't want raised white letters (they don't option black lettering) even if the white lettering was mounted on the inside.
Bridgestone - well - I emailed their corporate office about 8 times requesting information. They never replied. Based on the lack of response and the lack of performance with the Dueler H/T's - I wasn't going to give them repeat business.
I choose the LTX M/S because there was a lot of good reports "tirerack.com" and millions of miles logged. The tire came in black lettering (which is what I wanted). The tread depth is 13/32 vs the CT SUV's 11/32. The tread width is wider than the equivalent Dueler H/T's.
The tread on the shoulder of the LTX is open (ie blocks) I like this feature - as it provides better handling in poor weather (water can be directed away from the contact patch).
I am completely happy with the tires.
My only worry when getting new tires is the tire shop mounting the wheel on my car. I don't let them near it. I take the wheels off in the parking lot and roll them 2 at a time into their shop. I never have to worry about my wheels being bent from air wrenches or my nuts being cross threaded.
I would suggest that you specify "Road Force Balancing" They index the heavy spot on the rim opposite the heavy side of the tire. It minimizes the weight on the rim.
The first time the tire shop balanced my LTX's - they didn't do that. I ended up with 80 g weights (4" long) on the outside rim and they still weren't balanced. I had to take them off again and they fixed the issue. Now all the weights are 30 g or less and I have perfect balancing.
They are excellent in the snow and quiet in the summer - a good combination for the HL. They also have a 65,000 mile tread life guarantee that the LTX M/S does not offer.
I'm not knocking the LTX's - I had a set on a Jeep and like them quite a bit. However, for the HL I wanted a less aggressive tread pattern for quite rides during the spring/summer/fall.
I'm looking for the best winter traction possible,( I only have FWD), while not sacrificing comfort and quite ride. I personally prefer an open shoulder tire, I think they give better snow tracion. Both tires have full depth sipping for good rain and snow traction. Consumer Reports rate the LTX as good in snow and good in ride comfort and noise levels but only fair in wet cornering. CR will have a new SUV all-season tire report out in this November's issue. I hope they review the CT and the Nokian WR.
Thanks again
The interior fit and finish on the HL is much better than that of the Accord. It reminds me of my 94 Camry, which was a quality car in every way.
Now I'm adapting my driving habits to SUV characteristics and probably becoming a more cautious driver than I was in the Accord. No more jackrabbit lane changes or impromptu speed spurts.
Overall, I think the HL LTD is a great mix of luxury and practicality and I look forward to many years with it. I only traded the Accord so soon because of first-year redesign issues.
I don't want to get into all the problems right now. The Highlander has almost been fault free and I have had no hesitation problems that some other owners have noted.
Welcome aboard. I think you will really enjoy your Highlander
It was built like a tank and over engineered. If three bolts would secure a part Toyota would use four. The 98 was decontented by comparison.
Then I heard the siren call of side-curtain airbags and decided I needed something newer and safer, hence the Dis-ccord.
Could you provide a link to the 05 toyota pricing? Thanks
http://pressroom.toyota.com/photo_library/display_release.html?id- =20040823
I own a Highlander with just over 30k on it; and it's not quite 1.5 yrs. old. I drive extensively for my job, need the reliability and the safety I FEEL I get from my Highlander....because I drive so much I generally trade my SUV in every 1-2 years. However, the '04 Highlanders have the third seat now and I don't need that option. I have been considering buying a low mileage '03 or, waiting until a good deal comes up on an '04.. or do I wait until the '05s? I've looked at other SUV's that suit my needs (good size engine, 4wd or AWD for bad weather, not flashy (don't wanna be car-jacked or have it stolen), stuff like that. I've checked Edmunds site and the town halls for Jeep Liberty, Hyundai Sante Fe, Honda Element (Pilot wayy too big and too expensive for a swollen CRV).. there's not alot out there that can compare to the Highlander, so, I want to keep my purchase around 27k or less and it must be a six cylinder (was hoping for Toyota to put in a 280-320 hsp engine for the size ) I'm not quite sure which direction to go as far as my next purchase. Any ideas?
As an alternative to a V6 engine, you could try the Turbo Subaru Forester XT. It would be fast, reliable in bad weather, and probably not likely to be carjacked
Thanks for any input
OldStyle
I have test driven a Highlander FWD with 4 Cyl. auto trans. The engine to me seemed to be working a little hard both to accelerate and at cruise (3,000 RPMs at 70). Granted I'm used to driving a 6 cyl Olds, 205 HP engine that zooms (yes the car's a piece of junk but it does haul if you step on it).
Do you think: 1. the Highlander 4 cyl will last working that hard? Also, generally what's the feeling about its performance (I know this is subjective)?
What's a good price to pay for a base FWD 4 CYL. and how much more should I expect to pay for a 6 cyl?
-Ken
You can look up TMV and invoice prices on Edmunds. I think good deals are available now on all 2004 models as well as rebates and/or low interest financing.
-Ken
