Visitor Agreement.
HL mileage is marginal to me
BMW recommends turning off the DSC, Dynamic Stability Control, during maneuvers such rocking back and forth to get unstuck in a mud "wallow". Turning it off prevents the dethrottling of the engine so one might actually get out of that mud.
On the other hand it also says that in this mode, DSC off, the brake modulation for left/right torque apportioning might result in an automatic "masking out" of the brake application capability to prevent brake overheating due to allowing high rates of wheelspin.
Next year's "feature" for Toyota/Lexus AWD systems?
I did a search and didn't find anything on this subject
has anyone installed an aftermarket 9006 HID Kit?
I believe you need to disable the DRL first right ?
Can the DRL be disbled simply by pulling the
fuse #48 (according to owner's manual) in the engine compartment ?
Thanks in advance for any help.
I searched the HL forums here and did not find where the issue has been previously reported.
Thanks for any assistance,
brgsmith
Can any of you who have switched from the Goodyears to the Yokohamas (or the Michelins Cross terrains, for that matter) please comment on the noise level you noticed after the change of tires? A quiet ride is important to me, but so is safety...
The Tirerack web site seems to indicate that the Goodyears are the quietest, and the Yokohamas and Michelins are more noisey, bit I would like some real world comments, if you all have a minute to reply, I would be appreciative.
BTW, I am in the desert-southwest, (read: little rain) and I never go offroad or in the snow.
Thanks so much
Jeff
"Late this summer, after 3 flats had to be fixed on three different OEM duelers, I replaced the tires on my RX... only do about 7.5K miles a year, all on road and long trips. Tried to do my homework on TireRack... everybody seemed to love the Yoko Geolanders, with a few dissenters that said they rode hard and were hard to balance. So I went with those, even special ordering them from a local tire shop that had never heard of them.
Man, have I been disappointed. Have had them balanced three times, and can't get the tire hop or slight vibrations out of them. (Most recent shop really tried to do a good job, and even tried to find the tire hop problem, which they couldn't) Handling is marginally better, but the ride really suffers. Now I feel kind of stuck with them... they weren't forced on me, I chose 'em over dealer recommendation of Michelin LTX/MS (which I had on my old Jeep and loved). Subsequently, Consumer Reports came out and trashed them... (although they also didn't like Michelin CT's and LTX's and liked stuff we never heard of)
I'd advise others to stay away from the Geos... and anybody have any ideas on what I can do with these?"
minus: Balance needed every 5K, bumpy ride and noisy on rough surface
If I had to do it over I would spend few $$ more on LTX,s
do they ride quiet / hard/ what?
http://www.paspeedo.com/calculator.htm
the speedometer would read just a little low.. at and indicated 70MPH, I would be actually going 71.35MPH. I can live with that. I assume from other's posts, that the 235 tires will fit...Right?
Jeff
I have been following the various replacement tire discussions but have not seen any mention of Toyo Observe's. Has anyone out there tried them on a an AWD Highlander? I am interested because they are 'extreme weather' certified, which in Oregon qualifies them as a traction device (like a studded snow tire) on the passes when it is snowing. Thanks!
http://www.nokiantires.com/newsite/tires_popup.cfm?id=17&size- =225/70R16
thanks for you help.
In two weeks I will be taking a road trip from the SoCal up to SF, and back through the Sierra Nevada mountains (Yosemite, Kings Canyon, Sequoia Ntl Parks). I'm expecting some snow, but mostly the road should be scraped.
Do I need chains on my 04 AWD HL ? If so, only for the front, or the back as well ? I remember wwest's correspondence with Toyota that said the rear wheels do not have enough spacing for chains (I plan to use the "z" cable and bead type). I'm using the stock Michelin 225/65/17 tires.
Along those lines, what are the down side of spacers ? Why do they not factory fit them, if it allows me more options, better handling, better looks etc. ? Only cost ? Will the warrantee be voided in any way ?
Thanks !
hlfan
Front or rear.....??
Just keep in mind that with snowchains on the front ONLY when you want to slow the vehicle for any reason (downhill...??) you need to remember Humprey Bogart's statement in the "Afican Queen".
If you throw the anchor from the front of the boat you can expect to swing around it before it has any effect!
180 degree spin and then stop!
Personally I don't give a damn about warranttee issues, my life is worth more than that.
If you must use chains on the front ONLY then please drive VERY slowly and cautiously, especially downhill, as you are now in the twilight zone.
Minimum Chain Requirements
On the approach to Mt Bachelor in a 4WD Jeep Cherokee I have often been told I cannot proceed without all four chains, and/or move the chains on the front to the rear, etc.
I don't know of any time in Oregon that I was able to proceed, even in 4WD, without chains when they were required.
Never argue with "THE MAN".
or
What is color code for Sonora Gold Pearl?
I have 2004 model.
My new Highlander is driving wonderfully except for 1. Downshifting after a slow down takes forever. It is as if it has to think a long time before finally slaming it in lower gear. Not safe I think. 2. I drive as if I have an egg under my foot and the mileage is still only 16 mpg at best. How are your experiences???
Happy Thanksgiving
http://www.scc-chain.com/Pages%20Traction/Traction%20products/sz6- .html
That's way the owners manual for the RX and HL, and I think the Sienna, says to never use snowchains on the rear. I'm surprised that you did and they never got caught on the strut.
In the very same manuals it states that excessive traction on the front vs the rear on adverse roadbed conditions can too easily led to loss of control, in their case they use winter tires on the front vs the rear as an example.
Ask any tire should to install studs on only the front of your FWD vehicle and they will refuse for the very same reasons.
Think about tire chains on the front and now the rear while going downhill and needing to stop quickly, the rear will very likely suddenly end up being the "front".
Like throwing an anchor from the bow of a speeding boat.....
Another way to go, I purchased a set of mudguards for my Camry off of Ebay (a Toyota dealer in Florida) for 50% of what TRDparts.com listed.
http://www.truckperformance.com/
It is a conicceli toyota in PA. They offer 25% off.
As it happens, I went over Donner Pass on I-80 yesterday during a morning snowstorm (tons of fresh snow on the ground). All cars except those with 4WD and snow tires were required to have chains. We were in my sister's Grand Cherokee at the time, but I saw several AWD Highlanders (without chains) and a FWD Highlander (with front chains) that were doing just fine.
It can't hurt to keep some in your car just in case, though.
