Can't get Trooper Battery to take a charge! ECM?
I'm having a problem getting the battery to charge. I have replaced it, as well as the alt, twice. cleaned alt ground, replaced batt connections and even followed the wires back to ecm. It shows that their is power going in to the ecm. Where do I look from here?
The charing system usually consists of the alternator and a regulator. Sometimes the regulator is inside the alternator, sometimes it is external. Do you know where your regulator is?
Some charging systems need a signal to go ahead and start charging, this signal can come from a switch or a relay. I think the purpose is to not energize the field winding of the alternator unless it is turing and so can generate more power to prevent the field winding from draining the battery. You need an electrical diagram showing the connections on the alternator, if it has an enable input, follow the wiring diagram to see what eneble comes from.
Sorry, I don't have a Trooper manual to look this stuff up. I read about the enable signal when looking at aftermarket alternators for potentially replacing an alternator on another vehicle with a higher capacity version. Here is some online stuff I just searched for:
http://www.car-stuff.com/isuzualternator.htm
These people might be able to talk alternator tech very well to help: http://www.alternatorparts.com/contact_info.htm
While you're talking with them ask what model fits the Isuzu Trooper and how high an output can be fitted into a Trooper as a bolt in replacement.
Try the Dodge/Plymouth Neon discussion. Good luck!
I have posted a picture at :
http://www.carspace.com/atfdmike/.59a5c88f!v=
good luck.
-mike
plus the izuzu rodeo and the honda passport are almost exactly the same car, same owners (and haynes) manual and same components
I noticed on my last trip down-island, that her power was down. It hasn't gotten any worse, and she still pulls 75mph (about 120Km/hr) on the flats without any problem, but as soon as there is any uphill grade, she sucks. Can't figure it out, and I've mentioned the problem to several mechanics, and they can't figure it out either.
Do I smell an engine overhaul or rebuild?
Please help!!
Thank you so much.
Paul, Alert Bay, BC, Canada
The battery is not getting a charge. I had the auto sparky go over it and he reckons the problem is around the relay area from a possible ignition feed. The alt is working fine, the battery is fine as tried and tested at the workshop, the alt was even removed from the car and tested independently. When I run the meter over the battery only 11.35 volts and under load 11.29 volts. Clearly not enough. The car starts second turn of the engine when the battery is charged. I had some rewiring done to the fan and an ignition feed was created as the original was no good.
