Visitor Agreement.
If you engine is indeed sludged, be prepared to prove that you've met the maintenance requirements of the engine by showing every receipt for every oil change since the car was new.
Good luck and keep us posted.
Best Regards,
Shipo
Regarding a DIY job on your engine, it might actually make for an interesting line of work (or maybe a sideline). I spent some time a couple of months back browsing the net for 1.8T overhaul parts, and no matter how I added things up, I never exceeded $2,000 for the parts. Figure maybe 40-50 hours of labor (once you've done a few maybe even less), and you can sell the engine for between $6,000 and $8,000. Hmmm...
Personally I've actually toyed with the idea of snooping through the bone yards for a couple of long block 1.8Ts, doing a nice thorough rebuild and seeing what the market will bear. Good luck and keep us posted of you decide to dive in. ;-)
Best Regards,
Shipo
Leading causes are:
1) Incorrect oil - using non-synthetic is reeeallly bad. Using incorrect spec synth is bad.
2) Incorrect oil change interval - If you carefully read the later owner's manuals from the B5.5 Passat (2001.5 model and newer), you'll realize that the 5,000 mile oil change sited is the maximum distance VWoA recommends. There is some small print about severe use (which they leave completely undefined) may require more frequent changes. Unlike other manuals that specify what severe use and what the recommended OCI should be under severe use, VW's manual is silent on both.
3) Incorrect volume of oil: VWoA issued an addendum to their owner's manual that recommends/requires the use of a larger oil filter than originally spec'd for the car. Aftermarket filter cross reference manuals haven't caught up with this change (the last time I checked). The new filter is actually an older filter that VW used on their older diesel engines. The larger filter increase the total oil volume in the engine.
4) Driving Style: Running the engine hard and then shutting down on a hot turbo contributes to the coking issue. I live at the top of a long hill that I take at about 45 mile per hour - I always let the engine run at idle for at least two minutes to cool down the turbo. Why that amount of time? One night I pulled in and immediately popped the hood - the turbo was subtly glowing red. It took at least two minutes at idle for the glow to dissipate.
So. What to do? Run synthetic oil that meets at least VW spec 502.00, preferably the higher, newer specs. Use the larger filter. Watch the oil level like a hawk and keep it up to the upper fill mark. Change your oil within the 5,000 mile OCI, possibly well within it. Let the turbo cool down after running it hard. Follow these rules like an ancient religious text and you should be able to avoid sludging the 1.8T.
They are quite a few high mileage (>100K) 1.8T Passats with owners on other dedicated Passat forums. Some follow these rules more closely than others.
I have 93K miles, 2003 GLS, 1.8T.
I got my 06 passat with 2.0T FSI engine in Nov'05. Up until about a week ago I had no problems with oil consumption. I would need to add a quart about once every 10K miles.
Last week my oil pressure warning came on while entering the highway on-ramp. The light went off as soon as I got off the ramp. When I got home, I found that my oil was 2.5 qts low! This morning, I checked my oil again and found that I was 1.5 qts low. I had only driven ~500 miles.
There are no signs of any external leaks or smoke from the tail pipe. Does anyone know why I should be using so much oil all of a sudden?
Oil Change service:
at 5000 miles (8000km)
and then at 15,000 miles, 25,000 miles, 35,000 miles, etc.
This is demonstrably a 10,000 mile interval and could be what led to a lot of these problems as VW dealers were only changing the oil under the "Free for Three" program that was part of the sale of 01.5 Passats, wherein the dealer provided free oil changes for the first three years (with dino oil) but ONLY at specified intervals. :lemon:
The engine code for the 2001.5 1.8T and my 2003 model is the same...AWM. In Booklet 1.1, in my owner's manual, it plainly shows a maximum oil change interval every 5,000 miles, both in the detailed service maintenance schedule and in the abbreviated version at the front of the section.
This is confirmed in the Bentley Service Manual and VW's website for the maintenance schedule:
http://www.vw.com/dealer/MaintenanceSchedulesQuery.do?year=2001&engineCode=1.8T&carModel=PASSAT&TEMPLATENAME=maintenanceComplete&output=print
Said another way, true, your manual may show a 10,000 mile OCI, but it really should be 5,000 per the change. FWIW, what does you manual show for the oil requirements? Does it specify 502.00? Does it specify a weight (i.e. 5W-30)?
Best Regards,
Shipo
But I recall when my first oil change was due in early '03, once I read through all of the requirements, I bought 5w-40 synthetic for the change (actually used Valvoline Synpower 5w-40). But the manual is phrased poorly. I'll see if I can post a scan of it.
Best Regards,
Shipo
I got your back on this one, Shipo... :shades:
I own a pair of 2003 1.8Ts. I followed the VW 502.00 spec, and change intervals to a T. And you know what happened? NOTHING. No problems, both cars are still running like a top (just by properly driving and maintaining them - IMAGINE THAT!!).
My experience with synthetic oil goes back to the early 1980s when I was a C-141 (cargo aircraft) crew chief in the Air Force. The first maintenance item performed once these birds hit the ground was to check the oil on the Pratt & Whitney TF-33-P7 turbofan engines. Back then the synthetic oil came in the old-school quart cans.
Since then, I've applied the Air Force maintenance discipline to every automobile I've owned - and it has paid dividends in vehicle longevity....
"Back then the synthetic oil came in the old-school quart cans."
Too funny. Over the last week or so I've been doing the head gaskets on our old van and was rummaging deep within one of my tool boxes and came across a late 1970s vintage chrome plated self-skewering oil spout for those old quart cans. ;-)
Best Regards,
Shipo
Abbreviated Service Schedule
Original Oil Specifications
Oh, and I found VW's definition of severe use: "Under some circumstances the engine oil should be changed more often if you drive mostly short distances, operate the vehicle in dusty areas or under predominantly stop-and-go traffic conditions, or have your vehicle where temperatures remain below freezing for extended periods."
Basically, I fall into two of those categories and this is why I aim for a 4,000 mile OCI.
Supplement Page 1
Supplement Page 2
I don't know why VWoA took down the "sludge" pamphlet and the list of approved oils from their website. It's not doing the consumer any favors....
That is a question that will give a headache to some of the greatest sages, philosophers, and thinkers throughout history... :sick:
This is the first time I've ever seen a recommendation for 503.01 for anything other than the "W" engines or the high strung four banger Audi TT engines. Hmmmm...
Best Regards,
Shipo
Krzys
If I change my own oil with say Mobile1 & filters from germanfilters.com, will I void the warrantee? If i document the oil changes on a log I keep, will that hold up in court if I have a warrantee issue?
I can't believe that if i buy a Passat, I'll have to stand over the mechanic to make sure they pour the right stuff in!
I have a 2001.5 Passat 1.8L and a poster above asserted the oil change intervals specified for this car are 5000 miles. While I agree this is prudent, the manual actually reads:
Oil Change service:
I've seen a scan of the 2000 model year manual - it clearly states a 5,000 mile OCI - and I've been told that the 2001 (pre-facelift) is identical.
So either VW changed from 5K in 2000 & 2001 to 10K in 2001.5 and then back again by 2003 (always possible, since many of us have come to understand that VW stands for Varies Widely), or you're reading the schedule for another engine and/or model. It's possible - my manual lists an abbreviated schedule for Golfs, Jettas and New Beetles (no idea why!) in the beginning of Section 1.1 in my manual. The transverse engines, with their larger oil sumps, apparaently got the a longer OCI. The longitudinal engines with their marginal sumps (under 4 quarts in OEM trim) were inadequate for that distance.
1) does anyone know the entire procedure to perform this repair- i.e what would be done by a dealer?
2) would you buy one of these cars right after the procedure has been performed- this passat is a 2001 1/2 model year with 64k miles on it- new pads/ rotors front and rear and 4 new Michelins- all for $8200.
Thoughts?
Better spend a couple of hundred to have the car put under a microscope before you buy than to have to dump another $8,000 on a new engine after you buy.
Best Regards,
Shipo
If it's caught very late, then the engine is trashed.
It's not easy to pull the oil pan on the 1.8T in the Passat application. The longitudinal layout results in a subframe being located under the pan. You need to lift/support the engine to pull the pan. So it won't be cheap to have inspection Shipo recommends (doesn' negate the value of the suggestion, though).
Personally, I don't think I'd be that interested in that car without some sort of warranty.
Dunno what the code would be on the former, but if it was the latter, it's the low oil pressure warning.
# 2 Adhering to the manual's 10k oil service interval (too long)
# 3: 3.5 qts. oil capacity.
Taken together, they are the perfect storm.
:sick:
Did you see my posts (#126 and #133) in this thread? I'm not sure where the 10K interval came from that you mentioned. Any chance you could scan the portion of your manual showing a 10K interval? It would be really helpful to show VW's vascillation on their OCI policy.
1) Being down a half of a quart after 5000 miles is EXCELENT oil mileage.
2) Engines MUST use some oil to properly lubricate themselves. If they don't, engine longevity will be sacrificed.
3) Please tell me that you aren't using Jiffy Lube for your car. The chances of them using the proper oil and filter for your engine are somewhere between slim and none.
4) PLEASE read through the posts in this discussion: pat, "Volkswagen Passat Oil Changes & Issues" #1, 13 Mar 2006 12:52 pm
Best Regards,
Shipo
I'd prefer to go to VW for oil changes but they make me leave my car with them all day which is ridiculous for an oil change.
'Cause if you meant the bottom of the hashmarks, it's maybe a quart or less to get to the top of the hashmarks. I don't know what the sump capacity is for the 2.0T engine, but do the math, if you have that figure.
And given that you got the report from Jiffy Lube and they simply open the sump into a catch basin, how did they establish with any degree of certainty that there was 0.5 quarts left in the engine?
Do yourself a favor -
1) Don't go to Iffy Lube anymore with this car - they'll not give it the TLC it requires.
2) Do check your oil more frequently.
3) Read up and use the correct oil. I'm pretty sure, but not positive, that 5w-30 Synth is not meeting VW's spec for this engine.
4) Read you owner's manual - that will save you an enormous amount of grief in dealing with your Dub.
PASSAT Vehicle Maintenance Schedule
Year: 2006 Engine: 2.0FSI
Miles (in Thousands) 5 10 15 20 25 30 35 40 45 50 55 60 65 70 75 80 85 90 95 100
Kilometers (in Thousands) 8 16 24 32 40 48 56 64 72 80 89 97 105 113 121 129 137 145 153 161
Engine Oil - change x x x x x x x x x x x
Engine Filter - change x x x x x x x x x x x
Wow that came out like crap, anyways look it up on vw.com and it does state every 10k miles
Oil Change service:
While I haven't been able to view a scan of the 2001.5 owner's manual, I have provided scans of the other owner's manuals that clearly say the 1.8T has a 5,000 mile maximum OCI. Assuming that Joemama is in the USA or Canada, the 1.8 in the Passat is a turbo.
The newer 2.0T is a different story. I'm familiar with the 1.8T and its needs - I don't have, and probably won't ever have, the 2.0T. The OCI you are quoting from VW's website is for the 2.0T.
it wasn't the absolute bottom. when i checked the oil right before the change (after 5k miles), oil was at the bottom of the hashmarks, covering the bottom (MIN) portion of the dipstick completely. i'm just trying to figure out how much oil loss that is and how much damage, if any, it could have done to the car.
I still think Iffy Lube was talking out of their, ummm, exhaust pipe when they said only 0.5 quarts in the engine. With only 1/2 a quart, the oil light would have been on for a long time. Heh, probably the check engine light, too, becasue the engine would have seized!
Best Regards,
Shipo
