I've had 2 VW's in the past 20 yrs and had some problems with them.
Also had Honda's and Toyota's and no problems. Audi's are nice, but do you want the possible expense and headaches that might come with it. Good Luck.
You might want to check your Owner's Manual to confirm that. Assuming that 10,000 miles is in fact the number, then yes, you would probably be well served by keeping a spare quart of oil in your car to be used to top-off the oil should it get low, and then just change it on a yearly basis.
Best Regards,
Shipo
My car uses a quart of oil every 1,000 miles!
VW says that is "Normal" (for a VW?) so I would expect you would need at least 8 quarts to make to your next oil change (assuming a 10K mile interval).
BTW, anyone interested in buying a used 2006 Passat?!
It's got ~30K miles on it and has only been Service by the Dealer. I have a stack of Service Tickets to prove it!
I've read plenty of posts on plenty of boards where VW and Audi 1.8T and 2.0T owners have had their engines replaced by VW because when the consumption rate hits a quart per thousand miles, it meets VW's threshold for a new engine.
Have you had your dealer perform a consumption test yet?
Best Regards,
Shipo
When the time comes, that's the oil I'll be using.
Best Regards,
Shipo
Also found something on another forum but not about oil. My transmission had gone into sort of a limp mode and every 3d or 4th time I started it up all the lights (PRD2)..etc would light up...and I'd have to restart it for it to go away.
Well, battery was getting old so I put a new one in it and it has not done it since. ..Read in the forum that this can be caused when the battery goes bad or is old...mine was at least 5 years old...Hopefully, that was the cure for the limp mode.
So far so good, hasn't happened in about a month.
I need to buy a couple of bottles of oil to add between services. In Walmart there is Mobil fully synthetic oil 0W-40 meeting VW 502.00 standard. But it's not the 5W-40 suggested on the manual. The other close one is 5W-30 but it does not show it meets the VW 502.00 sandard. I don't think I can use the 5W-30 even though the manual said the 5W-30 can be used if 5W-40 is not available. Is the 0W-40 OK? btw I live in Florida because the weather plays a role.
If/when I end up with a 2.0T in my garage (an A3 2.0T is on my short list), the only oils I'll use are the two 503.01 certified oils that I listed above.
If you're really interested in what all of the oil specifications that VW's published, and what you should be using in your car, go back to the first post of this discussion and read all of the posts. By the time you get back here to the end, you'll be an expert.
Best Regards,
Shipo
I am not sure which brand oil was used by the manufacturer and dealer. Ideally we should use the same brand but we don't know. Adding a little of different brand won't hurt.
Regarding "make-up" oil, any 502.00 or 503.01 oil will do, they're all compatible.
Best Regards,
Shipo
I wasn't sure of the capacity but I didn't think 4 qts woudl sink us (manual states a 4.3 qt capacity). Went to drain some nice new oil out ....guess what?
No oil coming out of drain pan. So I'm looking around for the hidden camera and, seeing none, decide to run the engine for a few minutes. Went around the block and the engine warmed up (wife says she thinks its shifting jerky now ...no, I know where the oil filler opening is), then when I checked it again the level was STILL as high as before.
I'm dumbfounded. I drained quite a bit of oil out (going to go back and check the volume), car was level when drained and filled, everything came out of and went into the proper holes.
How is it possible that after filling the engine with 4 qts of oil I can get nothing to drain?
First, STOP driving the car before you fry the transmission.
Second, have the car towed to the dealer to have the transmission refilled.
Third, have them completely drain the overfilled oil and properly refill the engine. Don't run the engine any more until this is done - you'll kill the catalytic converter or worse.
Fourth, come up with a good story to tell your wife....
Bunches of lessons learned:
1. Just because I've been changing oil for nearly 40 years doesn't mean I shouldn't stop to question something that just does not make sense;
2. 8 months ago my son drained the tranny fluid in my Tundra (his first time on an oil change) when he thought he was draining the oil. I asked him what color it was and when he said "red" I threw a fit. I am now appologizing;
3. Tranny oil does not have to be red;
4. All the clues were there - oil level ridiculously high, oil not draining after filling, a crush washer that did not fit the drain plug;
5. My wife kept asking me "Are you SURE that wasn't the transmission fluid?"
Man have I got some splainin' to do.
Luckily, did not drive it for more than 200 yards after first tranny drain - real slow, didn't feel right. Don't think I had a chance of hurting the catalytic since it was such a short distance.
Drained the excess oil, closed everything up, and AAA will be there bright and early tomorrow.
As for the story to tell the wife, I'm afraid she was there for the whole ordeal. We're beyond words now - it's greenbacks time.
As far as my Wolfsburg Jetta 1.8T is concerned, I'm partial to the Group IV European Synthetics such as Motul or Elf Excellium (the only other Group IV 502.00 spec oils available in the U.S. besides Mobil 1 0w-40 European formula and the aformentioned Castrol Syntec 0w-30) - which is used by a famous East Coast VW Tuner that I take the car to for service...:)
alen
Best Regards,
Shipo
alen
1) By far and away, your biggest issue is the short distances that you drive. The truth of the matter is that engines (especially gasoline engines) run real rich until they're warmed up, and your engine is just getting warmed up just about the time you shut if off.
2) Driving style: Keep your foot out of it.
3) Automatic transmission: I'm thinking one or two miles per gallon due to that alone.
4) Tire pressure:While I don't know that your Owner's Manual (or the decal on your car) suggests for tire pressure, my bet is that it's somewhere closer to 36 than it is 30. Said another way, put some more air in your tires.
5) The specifications for your car are to use Premium fuel, anything less than that will negatively affect your fuel economy.
All in all, based upon what you've written, my guess is that you're probably getting somewhere between 18 and 21 mpg. Yes, no? :shades:
Best Regards,
Shipo
I keep them at 30.
Krzys
Best Regards,
Shipo
http://lnengineering.blogspot.com/
If this is true, It looks like Castrol Syntec 0w-30 is the 503.01 oil to use....
Best Regards,
Shipo
Me? I'd change that stuff out right now.
Best Regards,
Shipo
Couldn't figure out why the oil level was too high. Tried to run it thinking perhaps there was some sort of check valve. Had the same sort of lurching in the gears. Turns out, you can drain more tranny fluid if you run the engine and then let it sit for a bit.
Finally, a light bulb went off.
Luckily I didn't try driving on the street, Expensive repair, though. VW has to do the fluid replacement and they get you good.
'Cause everything you've written so far is indicative that the transmission fluid was drained and that the engine has been overfilled with oil.
It's not an uncommon occurrence. Is this the first time you've changed to oil on your Passat? What kind of tool did you need to use to remove the oil drain plug? If' it was anything other than a regular wrench...well, see post 299.
I'd stop driving this car until you are absolutely positive that the transmission fluid is at an okay level.
Google this: "drained the transmission passat"
You'll find a lot of useful information there.
Out of curiosity, how many miles ago was your last oil change? The oil change on the new Passats is 10,000 miles after the first two oil changes at 5,000 miles and then 10,000 miles, isn't it?
10,000 miles is a long time to go. I'd get into the habit of regularly checking the oil.
While I'm not 100% sure about the V6, I'm quite sure that the 1.8T ABSOLUTELY REQUIRES synthetic oil that meets at the very least the VW 502.00 oil specification (and it would be smart to use that oil in the V6 as well). The three most commonly available oils that meet this oil spec are as follows:
Castrol Syntec 5W-40 (meets 502.00)
Castrol Syntec 0W-30 (meets 502.00 and 503.01)
Mobil 1 0W-40 (meets 502.00 and 503.01)
Were I in your shoes, I'd change the oil immediately and get that oil out of there, doubly so if you have the 1.8T engine. Why? The 1.8T is a known sludge producer if absolutely the best oils aren't used. That and the turbocharger bearing has a tendency to turn low quality oils into a white dust called "coke", and once that process starts, a new turbocharger won't be far off.
Best Regards,
Shipo
Keep us posted.
Best regards,
Shipo
Can you elaborate on how PCV operation can impact oil consumption?
Greg
Best regards,
Shipo
