Mazda CX-7 Towing
Anyone know about the towing capabilities of the CX-7?
It's really tough to find accurate information on the CX-9 right now. All that is really known is that it will be replacing the MPV in 2007 as a 2008 model. The prototype vehicle has yet to be shown at any event yet. It's a possibility it may be shown at the NY auto show in the spring, as was the MX-Crossport concept last spring (now the production CX-7).
I spoke with my rep at Mazda, and he didn't really have much to say on the matter, because Mazda is very tight-lipped about things like this.
As for the size, it will probably be close to the size of the Chrysler Pacifica/Ford Freestyle. It will be a 7 passenger vehicle. As for the engine, it's rumored to have the new 3.5L Duratec engine by Ford that produces 250hp. It may have more HP, but like I said, that's all a rumor.
There really is NO official information on this vehicle yet. All that is truly known is that a 7 passenger vehicle, called the CX-9, will be built by Mazda.
I wonder what percentage of SUVs/Crossovers ever tow anything?
Exactly! Asking a crossover to tow is ludicrous.
People buy corossovers because they want 1 v ehicle that can do a LOT of things for them. A reasonable tow rating is not too much to expect.
The towing capacity of the CX-7 is 2000lbs.
We've never used them for anything other than receiver-type bike racks.
Think there might be a correlation - the more expensive the SUV, the less likely it is ever used to tow anything?
As for the list of comments on towing from other posters, I would suspect that a number of people do like me and purchase aftermarket towing equipment for their SUV's. In my part of the country most every SUV I see has a tow hitch of some form and they use them for towing all sorts of things from boats to travel trailers to snowmobile trailers. The current Tribute is rated to 3500lbs for towing, so expecting any SUV to be able to tow a certain amount would not be unreasonable. I tow about 2500lbs and it is handling it with no problems. Having said that, I now understand that the CX-7 is not intended for being such a workhorse and that is fine. Some people do not need the towing capacity and that is fine also. If it was not for my towing needs I would be looking further at the CX-7 as it seems to be a dynamic package. :shades:
Interestingly enough, U-Haul won't rent trailers to anyone with an Explorer - too many claims.
Interestingly enough, I have rented U-Haul trailers of various sizes and at several locations to pull behind my Explorer on numerous occasions. My Explorer has a 5000+ pound towing capacity and seems to handle the load just fine. Of course, now I purchased my own 18' trailer, so U-Haul won't be seeing me as often. But your "information" is absolutely wrong.
I formerly owned a Mazda Navajo (Explorer clone), and looked into renting a U-Haul trailer - same response.
Go to the U-Haul web site, enter vehicle info for an Explorer to tow a U-Haul trailer, and see what you get.
Even better, go to a search, and enter "Ford Explorer U-haul."
This is from the U-Haul site:
Ford Explorer owners: U-Haul has chosen not to rent behind this tow vehicle based on our history of excessive costs in defending lawsuits involving Ford Explorer towing combinations. This policy is not related to safety issues. This is an unusual circumstance for U-Haul – we have built our success for over 59 years by saying "yes" to our customers, and do not like saying "no" instead. We apologize for any inconvenience this may cause and are committed to working with our customers to find alternative options to help with their move. Please contact 1-800-GO-UHAUL (1-800-468-4285) for assistance with alternative options.
As far as the U-Haul/Explorer towing thing, what's funny is that U-Haul doesn't say anything about renting to Mountaineer owners. About the only difference from the Explorer is the trim and badges.
Just interested, for future reference.
Thanks, Vince
-c92
Seems the Home Depot option is less messy and certainly a lot cheaper!
Vince.
Michael
There is no towing prep package for the CX-7 and the hitches are port/dealer/customer installed. The installation instructions make no mention about a PCM update either so I'm not sure how you came up with this.
Anyway, almost every car should be able to tow 2,000 lbs. My CX-7, like the Mazda5 before it, has no trouble with my small utility trailer loaded with motorcycles or a weekend project.
I second that. I meant to post the exact same thing but you beat me to it. :shades:
Even if there were a software upgrade, it usually means harsher shifts via less clutch slippage, which means LONGER transmission life under the same conditions...
I haul a small sailboat with my CX-7. Total weight including boat, trailer, etc. is around 2000 lbs. The CX-7 handles it with no problem. I have hauled the same boat with a friend's Sport Trac and it felt like I was dragging a one ton boulder behind me.
It's likely that the CX-7 has a low 2000 lb. towing capacity because it's a lighter vehicle with a shorter wheelbase. It has nothing to do with motor performance.
I tow our 2 motorcycles 2 or 3 times per year. The bikes weigh around 600lbs each, plus the weight of the trailer. Trailer weight is unknown as I borrow one every time (sometimes its is an enclosed trailer, sometimes it is an open deck trailer).
Is the Cx-7 capable of towing this?
While the system was likely designed to handle double that amount, all the risk becomes yours...not to mention the fine if you get caught.
I called several Mazda dealerships about ordering parts and getting this done, they've been giving me some rather inconsistent information.
[Service center 1]
You have a class II hitch, you need:
0000-8E-M04 (Main harness kit) $154
0000-8E-M03 (Jumper Harness) $20
Labor $70
The Harness kit comes with some sort of power adapter..
[service center 2]
You don't have a tow hitch, you have just a bike hitch.
Wait, maybe you have a tow hitch, but since you have power seats,
you don't need the Jumper Harness.
[service center 3]
You have the wiring, it says "w/o wiring harness" because you don't need it.
You should be able to plug in the trailer's break lights. If something is missing, then bring the car in and we'll fix it.. it's under warranty.
I didn't realize it was going to be this much of a hassle. I just want to be able to pull a small trailer.. and have working brake lights.
Has anyone been able to successfully get wiring installed on their 2007 CX-7 GT?
thanks,
ws46
The GT does not require a jumper harness so service center 1 is out. Service center 2's final thoughts are correct but that all depends on what your dealer invoice looks like. If you don't have your invoice, your best bet is to call Mazda's 800# and find out how the vehicle was originally equipped.
Yes, it is the factory hitch. It has "Mazda" written on it.
The wording on the invoice is: Trailer hitch w/o wiring harness
My wild guess is, what they meant was that since my CX-7 is a GT (means it has power seats), that it doesn't require the jumper harness. Not "Wiring and the connector for the trailer's turning/braking lights are sold separately."
I do see the socket for the 4-way flat electrical connector right next to the hitch on the CX-7. So I'll stop by a Uhaul and see if I can connect to a trailer there and make sure that trailer brake lights work.
Well that's all you need. That connector is nearly universal for any small trailer without electric brakes or aux. power.
I had requested the Service Center 1 guy to order the parts (before I posted on this forum), after he told me that I needed those two parts. The guy looked up my VIN and the info on my car (this is the dealership that I bought the car from) so I thought he knew what he was talking about..
Well, now they are asking me to pay 10% parts return fee. What a headache!
If I had been a little smarter, I would have avoided all this mess.. arghhh.
thanks so much for the help
