Ford F-Series Axle and Ratio Questions
What difference would one experience with a 3.55 rear end as opposed to a 3.73?
I'm looking at a XLT with the 5.4L. I'm not doing any towing. Mainly just alot of camping gear in the bed and driving over mountain passes to our favorite camping spots.
T. Krueger
When I called a Ford service dept, they told me they could only check back to 2000, but the H9 indicated a 3.55 axle ratio. I checked the owners manual and couldn't find anything. Can anyone verify the H9 is a 3.55 for a 1999?
The reason I'm asking is depending on what the axle ratio is help determine how big of a travel trailer we can buy.
Should break it down to tell you what all the numbers mean along with the axle ratio:
Ford VIN Decoder
thx,
-g
Mark.
B124 D
3.55 10 2 2C02
I've found a junk F250 with the floating rear end (8 lugs) same as my current rear end but markings on the end of the hub are different. The axle markings are:
S125 P
3.55 10 2 7F23
Hub markings for old and new axle are:
old: 5T8 CA / A55 MW
new: 5T8 CA / DO DF
Measurements from backing plate to backing plate and leaf spring center to leaf spring center are the same.
It appears the gear ratios are the same. Does anyone know if this axle will work?
I'm needing to put the highest differential gear ratio in this truck.
Does anyone know the highest ratio available for them. I'd like as close to 3. as I can. Putting a low max rpm, high torque motor in front of it. No heavy use on it tho, just hiway use, with light loads.
Cayoterun
Because of different axle widths and bearing diameters I'm not sure if any would be interchangable with my axle tube..
