Does you know any specifics as far as what is changing in the 2008 model?
If you have Nero, try making an Audio CD and add audio files. Once added, view the properties of the music file, it will indicate the Title and Audio title that will be written onto the CD.
The "navigation package" was the intern package until the power lift gate became available.
I have an issue with the AutoLamp ... comes on too late, and the sensor is housed with the wiper sensor.
Although I prefer the Nav. system to that in my '06 Mountaineer, I have two issues with it: 1- Voice recognition is awful! It has voice recognition training, but I've been unable to find the phrases it asks me to speak. The dealer is sure to have them ... right? 2- The screen is too dim when headlights are on, which is how I had to run during the daytime due to the heavy overcast & rain. I put it in Day Mode, and maxed the brightness ... still too dim.
I'll run the fuel economy numbers after we finish unpacking.
We drove through Greenburg, Kansas two days before the tornado hit. I guess timing is almost everything.
Hey, I've been down there a few times golfing - Canoa Ranch, San Ignacio, Tubac (cow pasture), Rio Rico, Arizona National, etc. Nice area. My only complaint is that it shuts down at 8 PM.
b) To turn the brightness back up when the lights turn on, press the dimmer knob. Press it, don't just turn it. It's the left knob in the instrument panel. The right one resets the trip odometer.
c) Apparently Mazda dealers can adjust light sensor sensitivity. Talk to them.
Lexx
a) I plan to keep trying. The voice recognition on this car is far inferior to the Denso units I had in a 2001 Lexus GS, and 2003 Lincoln LS.
Is Bluetooth available on vehicles that do not have the navigation system? If so, that pretty much confirms the inability to train Nav. system voice recognition. Dang! As it is, voice commands are nearly worthless.
b) That's great news! It also, as you probably know, resumes the brightness of all the instruments.
c) I'll poke around in the area by the mirror to see if I can pop a cover & find an adjustment screw. (Marking & recording as-found, of course) If all else fails, I'll try the dealer.
I don't think Bluetooth is available without Nav, I think it's packaged into a single package for model year 2007 both in US and Canada. However, it is completely clear that the Bluetooth voice recognition is a completely different and independent system from the Nav voice recognition. Bluetooth recognition actually works quite well. Nav voice recognition is complete trash.
Lexx
Best BT experience I've had.
Plus...my wife likes the "regular" fuel as opposed to our Millenia's "premium" requirement.
say Accord EX V-6 (2003 model) or an Odyssey EX?
I would expect somewhere in between the two, but was wondering for those who may have driven it and the Accord or Odyssey.
Is there a break-in period for the mileage, where I'll see an increase in a few months? I have just under 1000 miles right now.
B.
2) Every time you apply the brakes, you are reducing your MPG. So, if you find that you're often applying them in order to avoid running over the vehicle in front of you, this is worth considering.
Actually, braking does not reduce your mpg but we know what you meant since pressing the brake pedal is usually followed by pressing the gas pedal.
SUVs and Smart Shopper
Consider a 300 mile trip on an expressway, where we attempt to run at 70 MPH.
During that 300 miles, I never apply the brakes. This is the norm for my driving.
Driver X is the impatient tailgater that frequently applies his brakes to avoid hitting the vehicle that's not going fast enough for him. Every application converts kinetic energy (reducing speed) to heat. To regain 70 MPH, more fuel is required than if the brakes hadn't been applied.
I will get better fuel economy, & he has wasted fuel.
Absolutely!
The highway surprised me though. I had the cruise locked at 75 most of the way. Maybe I am subconsciously over-accelerating because it's just so much fun to do that
Good Luck!
I've just spoken (again) to a rep about this... and have been told... that though it's not (yet) listed as functional for the CX-9... but it does work for the CX-9. Unfortunately I dont have one here to test... but that's what I know right now.
