Chrysler Town & Country Interior Issues
willcheryl
Member Posts: 4
in Chrysler
Has anyone purchased a good back support? I have a new Town and Country and find the drivers seat very uncomfortable. I have tried everything to help my aching back and am now looking into a padded back support of some kind. I am looking for something with mid/upper support as well as lumbar support. Any feedback would be greatly appreciated. Has anyone ever tried the Moller back support?? Thanks!!
By comparison, my son's 2001 Ody EX and my 2006 Sienna LE have an almost perfect seat for lower back comfort.
Just called dealership and they said about $380 to install IF they had to drill holes - they don't know if holes are "factory" or not.
Any suggestions? I think this is an outrageous amount for what is most likely a 1 hr. job for them.
TIA,
Deb
Norm
The mirror connection is located immediately behind (toward the rear of the car) from the speaker. You can also reach it (barely) by prying off the cover piece located at the end of the dashboard (the piece that you can access only if you open the door). You have to work your hand deep in to get to the connector.
Note, this is on a 2003 T&C LXi
Stow-n-Go
Our Front Driver seat electrical power buttons have stopped working.
Passenter seat works. Both seat heaters work. All dash lights work correctly. All plugs underneath seat seem to be plugged in solid and properly seated.
We do not have an owner's manual (stolen).
Please tell me which fuse to check and where it is located.
I would really appreciate an eMail diagram of fuse box layout descriptions to david_manpearl_at_hotmail_dot_com if anyone can easily scan the appropriate page of the Owner's Manual.
Does anyone know why the power seat buttons may have stopped working?
- Thanks, David Manpearl
Also does the front seat belts lock when braking hard, or when pulling the front seat belts themselves real fast when seating in the seats?
My front seat belts on my 1999 Grand Caravan will lock up if braking hard or if I pull the belt real fast when sitting in the seat.
Frank
Steven
To make the seat belt lock up, mine requires a very fast pull on the shoulder belt to make it lock up. I have also noticed when going about 25-30 MPH on a very bumpy road that they can lock up easily with a mild pull on the shoulder belt.
Frank
I get between 17 and 24.3 MPG...along the lines that have been advertised.
As for the mileage, give it a couple thousand miles to see if it increases dramatically. After 300 miles, that is just the first tank! All the moving the van does before it gets to you is extremely low mileage jaunts, and that can drag down the rest of the average for the tank.
We are getting roughly 25 mpg local driving with a little highway, finger crossed we have 500 miles with no issues or electrical failures so far.
Doug
I know where I can get some decent OEM bucket seats. Does anyone know if its possible to replace the bench with buckets in a 07 Grand Caravan and what it takes to get it done?
The belt does not lock when I give it a quick tug. It works in the front seats but not the back 2 rows. This did not make me feel comfortable. Needless to say I put back the original car seat and called the dealer.
I was told the seat will lock after I apply the breaks which I will test tonight.
Anyone else go through this? I'm not too confident about the brake test. Are seatbelts a lifetime warranty thing? Any thoughts would be appreciated.
Wasn't assessible to me, so took it in to dealer. Luckily it was only a $59 charge.
