Ford Ranger Owner Experiences
I just got an 04 ranger with a 3 liter 11000 miles
and was wondering if anyone has one with lots of miles. would like to know if u noticed a power drop or anything like that. i run this one hard like 5 and 6 rpm and it feels like it has hurt the motor. thanks
:confuse:
kcram - Pickups Host
To offer a more informed opinion, knowing such things as price, maintenence/maintenence records, type of driving done by the owner, was it a northern or Arizona car, 4 cylinder vs. 6, etc. would help. For instance, given the mileage and age alone without knowing anything else, I would say not to buy it. However, if the truck was driven primarily cross country through the southwest, meticulously maintained, and going for $500, I might still question it because of the low price makes it look like the owner is trying to get rid of it fast.
Thus, not only do you have to consider many variables, but also how much weight to give each variable-high mileage might not necessarily be bad versus a truck with 30k miles that was driven only in stop and go traffic and only for 5 miles at a time even though both trucks are the same age.
What are your driving habits? Maybe the pre 1998 models did only get around 14 mpg. I'm puzzled. :confuse:
I have a '92, 2x4, 5 spd, 3.0, super cab w/ 350k miles that needs to be brought back to zero time w/up-graded parts.
I'll have to change my trans, gears, A/C, maybe a 3.0 to a 4.0, turbo, part time 4x4, and interior.
Q. I understd there is an American made transmission for a 92
super cab? I've gone through three already and I understd the
Japanese companies stopped manufacturing 92
transmissions. My second and third trans were used.
Q. What do you think of the 4.0, compared to 3.0? My gas
milage has been at 16 to18 mpg, even w/ dual exhausts.
Q. Anyone with a part time 4x4, what do you think of your unit_
gas milage? Is it worth getting it?
Thanks for the help. I hope to run my Ranger for another 17 yrs.
FACTS:
1995 Ford Ranger XLT
4X4 Automatic Transmission
4.0L V6
137,000 Miles
$3,750.00 asking price.
THE GOOD:
Interior looks like a new truck.
Exterior in good condition.
Engine clean and looks great.
I can tell it has been well-cared for.
One-owner.
All service records were kept and are available.
Overall, it's a nice looking truck that seems to be well cared for.
THE BAD (potentially)...
1. After driving for a long period of time (1-2 hours) in high outdoor temperatures (above 85), the owner says that the transmission slips when shifting from 2nd into 3rd. He says it doesn't do it in the winter, and not very often in the summer. The owner says it's been doing this for the last 60,000 miles, and that I shouldn't worry about it.
2. Once again, after driving for a long period of time (1-2 hours) in high outdoor temperatures (above 85), the owner says that when you come to a stop, like at a convenience store, that the truck will not idle at low speeds. It sputters and dies. Once the truck cools, everything is fine again. And once again, the owner says it's been doing this for the last 60,000 miles, and that I shouldn't worry about it.
3. When I took it for a test drive, I noticed a "clunk" in the back when coming to a complete stop, and then again when starting again. It kinda feels like there something in the bed that's rolling around.
Well, that's about it. I'm worried about buying the truck because of the problems listed above. What do you guys think. It's a good-looking truck at a fair price - just not sure what to do. Any help would be greatly appreciated!
The bed of a pickup can be loaded with weight (Bags of gravel, sand, etc from the local home store. I recommend at least 200 pounds.) which will help.
But I think the average teenager can easily slide a Ranger off the road, with any amount of weight, under any road conditions.
Ok, being a little less smart-a**, the worse vehicle I've ever driven was my father's 1966 Ford pickup. I got it stuck on almost level ground in wet, slick grass. When Dad was no longer able to drive, I took it. I put all-weather tires on it, not Mud/Snow knobbies, and loaded it in the winter with two rows of firewood across the rear tires in the bed. This took me to work for several years, sometimes in the worse freezing drizzle Oklahoma weather could throw at me. My drive was on mostly level ground, but light rain at about 30 degrees produces a road surface akin to a skating rink, and this old truck got me through it.
I traded up to a 94 Ranger with a fiberglass cap which weighed at least 100 pounds. I loaded the rear with about 150 pounds of gravel bags, and it also got me to work ok. I did stick it trying to make a turn onto a country driveway in about 8 inches of snow.
So, with weight in the bed, a pickup can be a somewhat reliable vehicle in snow, etc. Tires with good tread also make a big different.
The second worse car was a 1979 Chevy Malibu with V8 motor in front. I stuck in on almost level ground on packed snow in a parking lot. Third worse, was my 1972 Corvette. I drove it unknowingly out into freezing drizzle. It wasn't frozen when I started, but one mile away on a hill it was freezing. I almost lost it over a huge embankment before I got it turned around. That car, on a slick street, would crab sideways while in gear, stopped, idling. It might have actually been the worse than the Malibu, but most of its years, after getting married and having another car available, I made every effort to never drive it on slick roads.
You really don't know about vehicles until you try them in bad weather. A 84 Olds Tornado, a front wheel drive tank, would 'go' good, but when stopping, the rear disk brakes always locked up and would throw the back of the car into the adjoining lane of traffic.
I'm used to getting far more than this out of a vehicle. Yes, this truck has been used as a truck, but are Rangers really at death's door at 156k miles? The engine is strong and has no problems. Its just the body that's falling apart. The blue book on it (as a poor condition vehicle) is around $2k.
Would you put (likely) $2k into repairs or just look for a new vehicle? My biggest issue is that I need a reliable vehicle that will get me through snow, etc, etc. for work.
Oh, and MPG sucks on it @ 11MPG. So I am looking at some Hondas. But I'm still amazed that a Ford dealership would say the truck is on its last tires. I'm wondering if they weren't just trying to sell a car off the lot or something.
Why doesn't he call FORD company , to do an advertisement on that . If he said he does not know how to then sell the Ranger (with 412000) to me , so I will do it .
BTW what year is that Ranger ??????????
A shaft in the heater 'door' breaks, and dash must be removed to fix.
I don't know anything about 4x4, but there is a LOT of complaints about the RAnger one not working. Grease hardens up and will not shift?
That's a base truck. No extended cab. Is it at least an XLT? Is it in great shape inside and outside? Does it have a lot of options? Otherewise, it seems a little high. Almost 15 year old truck.
