Nissan Frontier Maintenance and Repair
Just bought a 2006 frontier w/the 4.0 v6 and would love to change out the oil(after break in) to synthetic. What oil would be suitable and at what point should it be changed?
where do you see in the manual say that Frontier recommend "mineral oil" I dont see it. What is mineral oil anyway? I been using 5w30. Is it ok? Please advise. thanks
I hardly think you want to use mineral oil in your vehicle.
This will void your warranty quicker than using synthetics.
I've had car and truck engines go 100k + on regular motor oil.The important thing is to change it regular 3-5k miles and you'll be fine.
kcram - Pickups Host
As you said though it could very well be a mix up.
I was taken back by even the use of mineral oil in any auto application.
As far as synthetics, they're fine. However, I always get 200,000 Miles+ on our vehicles using only dino oil and oil burn has never been a problem, so I'll stick with the old stuff and save a buck. Dino works for me.
is related to the engine idle speed, being either too high or too low. I have ordered a much more expensive diagnostic reader. In the manual for the truck it points to the idle adjustment screw on the drivers side of the engine below the egr valve. There is a black plastic screw next to another cavity that is covered with melted plastic covering on it. On my previous frontier (4 cyl) the adjustment screw was under the plastic covering. Could I be looking at the wrong screw?
Aside from the set screw, idle speed is adjusted automatically on many vehicles by an _ Idle Speed Controller (ISC) when headlights or the A/C is turned on and engine load changes. ISCs often get dirtied up over the years and they fail to perform causing erratic idle. In the case of my Mitsu, it throws an ISC code. Not wanting to pay near $300 for a new one (when cleaning it failed), I just unplugged it when the idle speed was stable and I've been fine. Perhaps you could try the same and at least isolate the problem?
Ryan82
Good Luck!
I second that. I put Monroe struts on my '92 Mitsu six months ago and the improvement in handling is phenominal. It's not a bad d-i-y job and I'm nothing more than an amateur weekend wrench. I "rented" spring compressors (for free) at Advance Auto. I also have the factory service manual and it was a help.
I'm assuming that the springs are up to specification? They might be weak. I recall seeing an entire assembled strut/spring package ready for installation, perhaps made by Monroe. This'd make the job VERY easy and would give you new springs too.
needed helwig springs and Rancho RS9000 shocks to fix the problem. So, Ryan what kind of truck to you have?
I would appreciate suggestions for troubleshooting or perhaps a wiring guide. Anything that might help is appreciated.
1. check the connection from the wiring harness to the main instrument cluster. I have seen the ribbon wiring wear and lose connectivity.
2. Would you happen to have an aftermarket stereo installed in the dash? I hate to think that an installer would use the first power wire that they came across, but........I think you know where this is going.
Any nick in the insulation of the wiring can and will cause a short anytime that it touches metal.
However, I happen to have the entire wiring diagram for my 2004 desert runner that I bought online. It is extremely accurate, and I would be happy to email it to you if you like. I really think that you are going to need a good multi meter and a lot of time to find the problem. Let me know if you would like the electrical schematics, I will be happy to send them to you free of charge.
Recently, my 4 x 4 frontier electrics went wonky. The fuse for the dome and interior lights kept blowing, and now the Door Open sign is on ALL the time. The inside lights still don't work. I am woried that at some point, all my electrics will short out. Any ideas, anyone? Thanks
Toby
surtoby@gmail.com
I assume it's the alignment: there is a persistent shimmy in the steering wheel between 35 & 55 mph.
Anyone know of chronic probs on 01 Frontier w/ front end? What else can I check?
TIA,
Thad
By the way mine does it daily after I turn the key off-- just sit in it for a couple of minutes after you turn it off you will see what I mean!
Example: when I pull the handle the tailgate opens, but then the mechanism inside does not return to its proper place so, the next time I pull the latch, the mechanism is not in place for the latch to press down on, and so release the gate.
Does anyone know how to fix this problem? It seems relatively simple, but I can't figure it out.
The speedometer in my '98 Frontier is not working. It would register for awhile and show 45 mph when I was driving 60 mph. Now it's just sitting there dead. Check engine light is on as well. I just put a new transmission in, used but only 70,000 miles but the speedometer was acting up before the transmission was installed. Radio, lights...all other electronics working. Any thoughts?
The tailgate handle on my 2003 frontier XE broke today
Thanks all!
I am looking to buy an 06 SE V6 2wd. I could go either way on the tranny, but I think I would like the 6 spd because of the mileage. Anyway, what are the first things that usually go on this truck and what should I look for when I go to buy as far as common problems?
Did you ever track down a 2003 Frontier tailgate handle? I'm in the same situation - finding the same pre 2000, post 2004 model search results...no luck on the 2003 year. A local Nissan dealer wanted $66 for the 2003 handle, but earlier handle models online were $12-16 (??) What did you find?
A word of warning getting that back plastic off, it's not fun. There are a ton of little plastic clip back there to get off and you can't really do it unless you take the entire tailgate apart because of how much room you have to maneuver. Once they're off the back plastic comes off easily. What I did instead of taking the tailgate apart was I got a lighter with a long stem and melted them off/pulled them off. Worked great. I didn't replace them either, there are 2 or 3 bolts/screws that will keep the piece in place just fine.
Hope this helps.
NISSAN IS RECALLING 242,720 MY 2005-2009 PATHFINDER, FRONTIER AND XTERRA VEHICLES ORIGINALLY SOLD IN OR CURRENTLY REGISTERED IN THE STATES OF CONNECTICUT, DELAWARE, ILLINOIS, INDIANA, IOWA, MAINE, MARYLAND, MASSACHUSETTS, MICHIGAN, MINNESOTA, MISSOURI, NEW HAMPSHIRE, NEW JERSEY, NEW YORK, OHIO, PENNSYLVANIA, RHODE ISLAND, VERMONT, WEST VIRGINIA, WISCONSIN, AND THE DISTRICT OF COLUMBIA. IN THOSE AREAS OF THE COUNTRY WHICH USE HEAVY CONCENTRATIONS OF ROAD SALT IN THE WINTER, A MIXTURE OF SNOW/WATER AND SALT CAN ENTER INTO THE FRONT CRASH ZONE SENSOR (CZS) HOUSING. IF THIS OCCURS, THE CZS MAY INTERNALLY RUST RESULTING IN A SIGNAL INTERRUPTION. IF THIS HAPPENS, THE RED AIR BAG WARNING LIGHT WILL ILLUMINATE TO ALERT THE VEHICLE OPERATOR.
Consequences
THIS ISSUE COULD RESULT IN THE NON-DEPLOYMENT OF THE DRIVER AND PASSENGER FRONT AIR BAGS IN A CRASH, INCREASING THE RISK OF PERSONAL INJURY.
Remedy
DEALERS WILL REPLACE THE FRONT CZS WITH A REDESIGNED SENSOR. THE MANUFACTURER HAS NOT YET PROVIDED AN OWNER NOTIFICATION SCHEDULE FOR THIS CAMPAIGN. OWNERS IN THE OTHER STATES WILL RECEIVE EXTENDED WARRANTY COVERAGE FOR THE SENSOR TO 10 YEARS. THESE OWNERS WILL BE NOTIFIED OF THE WARRANTY EXTENSION BY MAIL AND WILL RECEIVE A STICKER TO PLACE IN THEIR WARRANTY BOOKLET EXPLAINING THE EXTENDED WARRANTY COVERAGE. OWNERS MAY CONTACT NISSAN AT 1-800-647-7261.
Notes
CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV
__________________
Thanks for your assistance. Scott
And has someone been able to solve the problem or at least minimize the shaking/vibration? I'd appreciate any info or suggestions.
Maybe you don't either.
