Isuzu Sunroof Problems
 i_luv_my_rodeo
                    Member Posts: 5
i_luv_my_rodeo
                    Member Posts: 5
                    I just recently got a 95 Isuzu Rodeo, with a sunroof. The sunroof lining from the cover that slides back and forth is hanging down...and I was wondering if anyone could tell me the best and easiest way to fix that. Is there a way that I can pull that piece out? or do I have to take out the whole thing? (It is a factory sunroof...)
I just got the front loose and then applied the adhesive and then worked my way from back to front pressing them together. Probably the best way would be to remove the entire panel and reapply the adhesive, I just did not want to go to that much trouble, but this method did fine for me. Hope it helps you make up your mind.
Just in case...Do you know how I would go about removing the panel? I was thinking that if I let the sunroof back, the sunroof would go back and the panel would pull forward and out of the track?
Thanks again.
I have an acura integra gsr. I observed that when I open my the sunroof, the car seems to be running smoother, especially at higher speeds. Has somebody else felt this too or am I smoking crack?
The Acura Integra GSR - Customizing & Modifying discussion may be of interest too.
:surprise:
p.s. I like this 4x4 its very comfortable to operate
Jeff
