Mazda3 Accessories and Modifications
Hi, I am in the process of reading everything I can, getting multiple quotes, etc in order to purchase a Mazda3 in about a month.
I am wondering about getting an aftermarket moonroof vs trying to find a vehicle with a factory installed configuration.What would a ballpark price be? The online quotes seem to suggest about 890 for factory installed.
Also, what is the difference between the i and s series? I am planning to buy and hold my car (I currently drive a 97 protege)for several years, I am looking for the best vehicle for Northeast US weather/road conditions. I am planning on buying a 4 dr sedan with automatic transmission , do not want the wagon or sportier models. Don't need bells and whistles, just air and an am/fm with a cd.
Eric
2005 Mazda 3i
Outings Inc
05 Mazda 3s
No, it does not set off any CEL lights.
Hope this helps.
Daryl
Micah
Proud owner of a 2007 S Touring. I did a quick search for CAI kits and came up with some ebay $40 jobs on one end and the official Mazdaspeed kit for $300. Have also seen other kits for $200 or so. Why such a big difference? I'm guessing that not all are acceptable within the warranty period, but other than that....Any comments? Help me decide!
-Jicbulk
Did you make any other modifications?
How is the K&N air filter supposed to be maintained?
Actually, colder air is MORE dense. I doubt that getting too MUCH air flow is the problem.
Is it possible that you've got some blockage in the system restricting airflow?
you have to clean the k&n cold air intake filter occasionaly to keep the filter working as it should. there's a cleaner and degreaser available at k&n's website that will dissolve the dirt buildup. there's also an aerosol kit that restores the efficiency of the filters. check it out here
This is where I get all my stuff and also the other forum people get al there stuff from here. Devin is his name.
Hope this helps.
I am considering an after market perfomance product called "Next Level Performance - G-Box (Gold Series). I love the performance of my Mazda 3 GT, but I am being seduced by the possibility of adding more power to the car. Has anyone used this product on their Mazda 3 or 3 GT? If so what have been your results. Any drawbacks to this product?
In addition, I have also looked at a KN cold air intake system. Anyone had experience with this or a similar product on their Mazda 3. Does it help out fuel economy?
this product that you mentioned...what does it do/enhance exactly? The 3 has a very small aftermarket, and its usually limited to dealer installed bolt ons, or visual upgrades. Unfortunately this is true for the speed 3 as well, since its pushing so much boost, you'd do better buying a bigger turbo for it; and thus just getting a regular 3 and buying a turbo.
I think Mazda heard you and came up with the Mazdaspeed. After all, after you install the turbo, you'll likely need to adjust the suspension, exhaust and will go for bigger tires ... all of which adds up to the Mazdaspeed3.
http://www.mazda.ca/files/2007_mazda3_accBro_en.pdf
or in Australia:
http://www.mazda.com.au/accessories_pl.asp?id=74&x=14&y=8
I contacted Mazda USA with this info, they said they had no plans to import this item. You can get it in Canada if you want it.
Anyone have a suggestion?
The GT with Nav costs about 3400-3800 more than a Sport. I think I've priced out an AVIC D3 (GPS HU), good speakers [aka better than Bose], amps, and installation for less than 3000.
Has anyone else tried this approach? If so, were you able to have it integrated with the steering controlls, and did you lose anything? (LCD clock?)
And more importantly, was it worth the time and effort?
This is what SEMA is all about. I've seen all kinds of customized cars. You'd probably need a different steering wheel with all the buttons on it and integrating it with everything would probably cost some real time and money.
Why everything has to be integrated is beyond me. A Portable Nav system is almost as good and a world cheaper and audio systems have a lot of aftermarket options. I'm not into audio at all I use the stock CD player since I prefer to listen to my car.
But aftermarket is possible, steering wheel is another matter, possibly doable but expensive.
If it's what you really want then just do it.
Anyone tried these yet (or found a cheaper alternative:)
Mazda sells individual wheels- as does every auto maker I am familiar with. I'd check out Online Mazda Parts, AKA Montgomery Mazda in NC. They sell OEM parts at decent prices. And of course there is always eBay. Regardless, I'd expect to pay $300-$450 per wheel from a dealer. www.mazdas247.com has a classified section; you may find some take-offs there.
Do you think they would care if i purchased somewhere else & had them install it? (of course i would have to pay a work fee). The only other thing too would be having to lug it there.
**wait, just found a coupon fr. Mazda for accessories; a wheel/ rim is an accessory right? Or would it count as a part?
