Subaru Forester MPG-Real World Numbers
in Subaru
With the price of gas being what it is, your real world mileage is becoming more important than the estimates on the sticker. This is the place to talk about your real world on the road results!
My average improved by about +3mpg after a year or so, that would put you in the low 20s at least.
-juice
Stop racing those CRVs :P
Let's define "in the city," first -- are you talking about going 95%+ of a tankful driving on actual city streets? You know, stoplights at every intersection, rarely traveling above 30 mph, lots of idling?
If that's the case, I'd actually be pretty happy with 18 mpg. I live in New York City, and on those occasions where we go a whole tankful w/o ever leaving the city limits, driving exclusively on local surface streets (no intracity jaunts on the highway), I've gotten as low as 15-16 mpg in the summer (AC).
I have a 2004 Forester, which lacks throttle-by-wire and a couple of other refinements that yours has, so I wouldn't imagine you'd ever end up that low. But if you're talking about extreme conditions like the ones I outlined above, then 18 mpg doesn't shock me.
FWIW, I get about 27-28 on all-highway driving (rare for us) and 23-25 on "mixed" (almost every tankful we drive will be at least 50% hard-core urban mileage). I had one tankful just over 30 mpg, driving 45-55 on rural back roads in Ohio. EPA for my model is 22/28.
Hope that helps. I'm not thrilled with my urban mileage, either, but I think it's got more to do with the conditions than with the car.
I think an engine should be fully broken in within 2-3000 miles, really there isn't that much lapping/wear-in happening. I'm not unhappy with the 20-21, was just hoping for 25ish with careful driving.
Two real-life examples:
I have a commute that occasionally goes 28 miles one-way. In my prior car (an old BMW), I could see the difference in economy by watching the range (miles to empty) number during the commute. This number would drop steadily over the first 10-12 miles, then start holding steady and then increase slowly over the second half of the trip.
Wife has a Prius with an LCD display with MPG charting capability. It shows the MPG in a bar chart. Each five minutes another bar pops up with the previous 5-minutes measurement, and so after 30 minutes you'll see 6 bars showing the MPG for each 5 minutes during that span. The first bar always shows about 25 MPG, the next one is about 40 MPG, then each succeeding bar shows 45-55 mpg depending on the terrain. Should it be any surprise that said wife gets under 40mpg for her 2-mile commute when I get 50 or better on weekend jaunts over longer distances? (EPA for '02 Prius - 52 city/48 hiway). Granted, the Prius is an extreme example since the gas engine doesn't run all the time, so it should take a bit longer to get to maximum operating efficiency. (It runs for a minute or two at startup to heat up the cat converter, then it runs as needed afterwards.)
Bottom line, you really need to be driving longer distances in order to see MPG numbers approaching the published EPA numbers. Say, 15-30 miles at a time, not 6 miles.
Break-in. 10,000 to 15,000 miles is a more realistic break-in period. You'll see a gradual rise over that time, I'd say about 1-2mpg, eveything else being equal.
I love this car, it just feels unusually solid and smooth. When your biggest gripe is that the radio blanks for a half second coming off "scan", I'm really having to stretch to find anything to not like :-)
The big moonroof, feel like I'm just a notch down from a convertible.
First few days with the new Forester, had this weird feeling that I could almost forget that it needed to be driven. The old 92 Loyale never felt that way, kept me on my toes.
Do boxers minimize thermal mass, standing coolant in the engine? Warm up time is amazingly fast, the old Loyale was great that way too.
The car it replaced (old Beemer 525i) took an extra 2 miles to get to the same point. Dunno why, I'm thinking the Beemer had a bigger radiator. 2.5 liter engines in both.
-juice
-Frank
It's a Tuesday, how could I be bored???
-Frank
Peak of 30.4 mpg on a trip.
Low of 17.3 mpg while towing a 1500 lb trailer the entire time.
-juice
October thru April - 28 mpg
May thru September - 30+ mpg
(difference due to seasonal temp variation (eastern Pennsylvania) and winter gas additive changeover at refineries)
Best mpg - 32.3 on 440 miles (same tank of gas) mostly long distance. Last month.
Worst - first tank, at 24.5
-juice
best: 26 mpg (all highway at 75 mph)
worst: 18 mpg (winter)
average: 21 mpg
Average mpg up until this past winter was 1 mpg better than my Outback. Partial thanks to winter fuel, no doubt.
-Brian
Averaged 26 miles per day, or about 9,500 miles per year. 87 octane from Super America. Reformulated fuels and winter blends both with 10% ethanol.
best: 28 mpg (highway trip)
worst: 17 mpg (again, winter)
average: 22 mpg
-Brian
- 80 miles per day 95% highway.
- - Use 87 octane, with that lousy ethanol.
- - Tried all brands of gas - no difference.
Tried Octane booster to a tank of gas, new special, copper plugs - drove 65-70mph - 20 mpg.
Winter milage is even worse.
My '92 Legacy LS Wagon got 25 and it's >= 400 lbs heavier.
( It's still on the road BTW )
How are you achieving those type of numbers?
Dom
-Brian
Filled up, then took it down to exactly the first quarter tank mark. 108 miles without AC.(It was just cool enough to run with windows closed.)
Upon next fill up, I did it again, but ran the AC on number 2 setting. 86 miles to the quarter mark. Pretty significant, I say.
Joe
Try a full tank, and even then, just one tank isn't really significant.
I track my mileage, and I've found that in the summer my average dips about 1 mpg, likely due to the A/C. But...in the winter, my average dips about 2mpg, due to having to warm it up longer is my guess. So the A/C puts less of a burden overall than having to warm up from freezing temps.
-juice
I did notice that mileage improve markedly after ~7500 miles or so.
Not by driving 85mph. Speed kills gas mileage. The sweet spot seems to be about 45-55 MPH for most cars.
The FXS isn't going to win any prizes for minimum air resistance either.
It's too bad the EPA doesn't do an experiment with the MPG test by doing the standard test for highway speed, and then repeating the test at a higher speed, say 80-85 mpg. It would be interesting indeed to see the MPG difference.
The air resistance is proportional to the speed cubed so it rises strongly with increasing speed. But this doesn't mean that the proportionality factor is 1. Link.
That's actually the power required to balance the force of air drag - which varies as the square of the speed.
That third power bothered me, but I didn't think it out. In the past the usual reference has been to the retarding "force" of air resistance, which for simple physics problems I thought was proportional to speed, so power (speed times retarding force)should be proportional to the second power of speed. But in air, and with turbulence, etc. the retarding force must be proportional to the square of the speed in order to give a third power dependence of the power. As I recall the old statement was that the "air resistance" at 70 mph was twice that at 50 mph, which fits with the force being proportional to the square of the speed since (70/50)^2 = 1.4^2 = 2.0.
The power (metric unit of power is the Watt, where 1000 W = 1 kW = 1.34 HP) is the energy consumed per unit time, but what we usually want to know is energy consumed per unit distance travelled. In Europe this is the litres of fuel consumed per 100 km travelled, but in the US we use the reciprocal, that is, distance travelled per unit of fuel consumed (mi/galUS or simply "mpg"). FYI the conversion between the European and US measures of fuel economy is y mpgUS is related to the equivalent z L/100km by yz = 235. That is, you divide whichever one you have into 235 to get the other one.
But the point is that to get the extra vol of fuel consumed per unit of distance caused by driving faster we should divide the vol of fuel consumed per unit time by the speed (distance/unit time). So it would seem that the extra fuel per unit distance required to go faster would be proportional to the square of the speed, or maybe proportional to the square of the increment in speed, or maybe proportional to the difference in the squares of the speeds. You'd need to do some algebra to get it exactly straight. But as I said the proportionality factor is presumably much less than one. The formula given in the link could be used to calculate the factor for a given vehicle.
But for any given vehicle, the best way to determine this would be driving different steady speeds (40 mph, 50 mph, . . .80 mph) and recording the instantaneous mpg values (or L/100 km values) shown on the fuel mileage computer display. I think these are pretty accurate, aren't they? Then you would just subtract to get the benefit from driving slower and the penalty from driving faster than the posted speed. To get the actual fuel and money saved you'd express the fuel use as gal/mi not mi/gal as we usually do in the US.
Speed(mph)..mi/galUS.....galUS/100mi....Fuel-Std 70mph*
45..........35...........2.86...........-0.71 gal/100mi
50..........35...........2.86...........-0.71
55..........34...........2.94...........-0.63
60..........32...........3.13...........-0.44
65..........30...........3.33...........-0.24
70..........28...........3.57............0.00
75..........26...........3.85............0.28
80..........23...........4.35............0.78
85..........19...........5.26............1.69
So if you want to know how much fuel you'd save on a 500 mi trip at 65 mph as opposed to 80 mph,
Fuel saved = (0.78-(-0.24)) x 500/100 = 1.02 x 5 = 5.1 gal
It would be much better to use the average mpg function of the computer, if it can be reset. The one computer I have seen in action is in my nephew's Jeep Grand Cherokee Ltd. As I recall the instantaneous mpg display is to the nearest mpg which is not really good enough precision. The ave mpg though is reported to the nearest tenth of a mpg. So you would estblish a constant speed and set the cruise control. Then reset the average mpg and then read it after a minute or two. Then go to the next speed, reset the ave mpg and read it after a minute or two, etc.
-juice
I tow an 18 to 1900 lb pop up and have generally been at 21 mpg for three 3000 mile trips and almost 24 for one trip. Don't ask me. These are virtually all highway miles. I do know that the first three were through states where we were getting 10% ethanol for probably 2/3 of the gas.
The last trip we also did a lot of driving without the pop up trailing behind.
Not bad for these days.
-juice
The only issue was the mechanics who changed my oil didn't know that the o ring should be replaced when an oil change is done. It is in the book but I never read it! I had a small leak until I called Subaru and they made me aware of this.
The low of 20.27 MPG came about when it was 100% short city trips. The high of 28.46 MPG was a 100% cruise-set 55 to 65 mph driving.
Any cheap "real world" advice out there?
For city driving, the non-turbo certainly doesn't lack power, and I also do a fair amount of mountain driving with it, from Reno to Lake Tahoe, a 40 minute trip. And it uses regular unleaded.
I test drove both models yesterday and yes I was very impressed with the power on the XS. My previous 4 cylinder experiences include Ford Bronco II & Ford Pintos (ok stop laughing) ... so I was curious to see how far the 4 cylinders of today have come. Today's 4 cylinders are not those of the mid 80s for sure. But then I drove the XT and oh my gawwwwwd (I used to have a Turbo Trans AM as well) it was extremely impressive and I've seen its 0-60 ratings at around 6 seconds. I'm trading in a 6 cyl Grand Cherokee for a Forester and like I mentioned before, Massachusetts drivers are known as Massholes (sorry) for a reason ... they don't let you merge onto the highway ... you have to earn your way onto the road or :sick: else.
Thanks again!
Shifts on the MT are most always at 3k or so rpm
For reference, the same work commute and other driving conditions in my '00 Outback yielded 22mpg overall.
-Brian
So, hopefully the 173 horses under the hood of my XS will suffice for merging onto the highways around Boston!
Thanks again for the various comments!
Much appreciated.
Do you mean you bought the 2.5 X? I don't know what the XS designation means.....
Family just loves the huge moonroof ... I'm a weather nut ... love the WB (weather band) on the radio. Agggh it's the little pleasures in life that get us by. :-)
Enjoy it and keep us posted!
-juice
Sheesh, you won't wear that puppy out until about the middle of the century...
-Brian
Date.............Miles.....Gallons.....MPG....Cumulative MPG
5/15/2006......335.7....13.522......24.8
5/27/2006......268.4....11.954......22.5......23.7
6/17/2006......235.4....10.984......21.4......23.0
6/19/2006......274.3.....9.270......29.6......24.4
6/21/2006......318.2....10.688......29.8......25.4
6/30/2006......273.3....12.210......22.4......24.8
7/14/2006......330.9....13.817......23.9......24.7
7/16/2006......337.1....12.488......27.0......25.0
7/18/2006......299.8....11.662......25.7......25.1
7/18/2006......221.1.....7.571......29.2......25.4
7/18/2006......282.6.....8.656......32.6......25.9
7/20/2006......178.1.....8.394......21.2......25.6
7/21/2006......174.2.....4.883......35.7......25.9
7/21/2006......234.5.....8.479......27.7......26.0
7/21/2006......168.0.....7.449......22.6......25.9
7/21/2006......247.8....10.105......24.5......25.8
8/9/2006........368.7....11.794......31.3......26.1
8/9/2006........264.8.....9.893......26.8......26.2
8/10/2006......334.5....11.500......29.1......26.4
8/10/2006......402.9....12.979......31.0......26.6
8/11/2006......307.8....10.326......29.8......26.8
8/11/2006......187.0.....5.681......32.9......27.0
8/13/2006......342.4....10.546......32.5......27.2
8/13/2006......287.3.....9.832......29.2......27.3
8/17/2006......204.2.....8.365......24.4......27.2
8/18/2006......289.2.....9.820......29.5......27.4
8/21/2006......233.3.....8.516......27.4......27.4
9/17/2006......253.0....11.226......22.5......27.2
