1994 Trooper
I have 2 problems:
number 1, my sunroof does not work anymore, the switch had been tested with an o-meter and seems to be ok (or at least i think that's how it was tested and was told it was ok), my questions on this are the following: Could it be a fuse? The power windows still work but I thought maybe the fuse is just not good enough to work both or maybe there was another fuse to try? Secondly on this subject, where is the motor for the sunroof and how do I get to it?
My other problem is the air conditioning does not work, I got the air recharged (with freon and that) but that doesn't seem to fix the problem so it must be the condenser or the compressor i'm guesssing? which of the two usually go- hoping someone can help me with one or both of my problems, thanks
and this is wiring: http://www.carspace.com/atfdmike/.59a5d907!v=
It seems likely that you should know if the limit switches are working right before assuming that the motor is bad. THe sunroof is installed as an assembly before the headliner is installed, so you would have to remove the headliner to gain access to the various mechanisms. The sunroof motor is part of this assembly.
On your AC question, was your ac system work done by a professional, who evacuated and then recharged the system? The reason I ask is that your system should have been leak checked at that time, and any leaks fixed before adding refrigerant. If the system is not leaking, then you should see the compressor turn on when you turn on the ac. If it does not, then there it could be several things wrong ...ie; low pressure, electrical, and several other things. If the compressor is engaging, then you really need guages to tell you how the system is working. Good luck.
also my heated seats quit working a while ago any ideas on what to check
thank you
I have found the speedo burnt inside, there were multiple fuses blown. Ign. Fuel pump. Front and rear wipers. (don't know if they were on at the time)
The battery is only a few months old and holds a12 volt charge. When I hook it up, there is only 6.5 to 7 volts anywhere I can get power. I replaced the ign. switch but still there is power to and from switch but there is no power to the engine or starter. Oh I did replace the fuses. and checked the big main fuses in the engine bay. There aren't any burnt wires visible in the dash or the engine compartment.
We did a clutch on this thing last week if that tells anyone any thing.
I'm sure I can figure it out sooner or later but I'm outside and expecting snow. Thanks.
