Lexus ES 350 XM and Sirius
Talk about XM and Sirius in the ES 350 here.
They installed it as a small antenna that is on the right edge of my trunk line....very low profile. All ES radios can be adapted for XM. The signal would likely be a bit stronger if it was roof mounted, as in my other car, but it works great none the less.
zekeman1
I picked up my car yesterday without the XM option installed since I got the car out of their inventory. I've had XM in my last 4 cars, the latest being an 05 Avalon LTD, but it was ordered that way.
Dealer is quoting me approx $850 total; he said it takes about 4 hours, blah, blah, pull lots of dash, blah, blah, wiring. Seems on the high side but we really haven't gotten down to business talking.
Anyone have one installed yet?
zekeman1
Do you have navigation on your vehicle? My salesman told me that I would be able to see this information on the nav screen.
Can someone with nav and someone without nav that has satellite tell us if the name of the song and the artist is being displayed!
That's BS. Mine is on the inside of the car on the rear package deck and it works just fine. In fact, my dealer told me they put ALL of the antennas there, for aftermarket install.
zekeman1
As for the display, I have a non-navi car, and you can see station name, artist, or song title. What is disappointing, however, is the amount of real estate on the display that you have to see that. Since the preset information takes up so much of the space on the left of the LCD, you see at best 8 or so characters. My wife's Honda is much better, and gives you the length of the display to see the XM info.
Love the car though....
On my Avalon it was so big and ugly I had it removed (easy too, just let it sit in the sun and pull it off - it's held on by 3M tape and/or magnet and no, it won't damage the paint), bought a micro mini Terk XM antenna (about the size of a quarter) disconnected the antenna with the kit, threw it away and plugged the mini antenna into the receiver and ran the antenna inside the car (concealed) and mounted it on the dash next to the defroster vent....worked fine.
On the L, it's mounted inside the car on the rear package deck next to the 3rd eye (middle brake light)...it's so small it's almost invisible.
Sounds like your dealer is a BS artist. I'd find another dealer if I could.
zekeman1
Totally agreed!
The dealer can do pretty much anything you ask him too. His job is merely to advise you, not dictate to you. He's there to serve the customer! An apparently novel concept that some salespeople are not too well aware of (hate ending sentences with a preposition but, oh well).
This guy should ask to speak to the sales manager ( I assume he's now committed to that particular dealership) and simply review what has transpired to date and demand that the antenna be put wherever the hell he wants it! If he wants it mounted on the middle of the damn hood, then that's where it should be put.
Period!
Case closed.
They placed the antenna (black) on the back right side of the trunk lid. Size is about 1/2 inch high, 3/4 inches wide and 1 inch long. With the Ruby Red it is barely noticeable and the reception is fine.
Is the XM or SIRIUS installed in the trunk or where is it installed and is the car prewired for satellite radio?
Please answer part or all that you know. Thanks
First let me say I have XM installed.
Steering wheel controls preset station seek within the satellite presets. You can have 3 sets of 6 presets. They are referred to as SAT1, SAT2, and SAT3. With the LCD touch display you can seek/scan within a music type and also seek for specific type of music category. Unlike some of the other touch screen functions that are not accessible when the car is in drive, the satellite functions are always available via the touch screen.
Is the AUX adapter in the center console disabled when XM or SIRIUS is installed?
No.
It is prewired. The unit is installed out of sight in the trunk area behind the covering of the trunk area. I had the antenna installed on the rear deck and have had absolutely no problems with reception.
Overall, IMHO this is a very easy to use system.
Detailed operational instructions can be found in the navigation users manual for those that have already purchased the ES350.
Can you please post picture of where the antenna is installed?
Pic1
Pic2
The dealer that I spoke to told me that it "HAS" to be installed externally. I don't think he knows what he was talking about. :mad:
Color is Tungsten Pearl. Lighting was not very good when I took the pictures as the care was in the garage.
Not sure about the antenna having to be outside. My dealer had no issue whatsoever putting it in the rear deck. I have read on other boards of the antenna also being placed on the front dash. Like I said I have had no signal problems other than under bridges, some enclosed parking garages, and downtown among the tall buildings. This is normal from what I understand regardless of where the antenna is placed.
The problem I have is sound level. The volume has to be adjusted differently for the XM versus the FM. I'm going to talk to the dealer about fixing the problem. I know there is a device available to correct sound levels on add-on devices such as the XM, MP3 and CD changers, etc.
Is anyone else experiencing the differences in sound levels and having to adjust volumes for different inputs?
Mounting the antenna inside the car at the back window is perfectly acceptable. If you are installing a SIRIUS radio, the reception inside the window would not be quite as reliable as XM because SIRIUS does not have ground repeaters and always needs a clear shot of the southwest sky.
Unfortunately, the wizards that designed the ES350 headin unit and radio/amplifier set all the inputs at the same attentuation "level". This means the CD, FM, AUX, AM and XM inputs are not attenuated to account for different signal strengths. The radio and amplifier are one unit and neither it nor the Pioneer XM unit have any attentuation controls to set different sound levels. The result is that when changing from FM to XM, etc., you'll have to change the volume to achieve the same sound level.
This is a lousy and inexpensive setup for a luxury vehicle. If you look at the radio/amplifier and the XM receiver, they are TOYOTA parts made by Pioneer. There is a company, called VAIS (vaistech.com) that manufactures audio interface devices to seamlessly connect aftermarket electronic devices with factory headin units. They specialize in Toyota/Lexus and will be releasing a new product, called the SLXI SoundLinQ that will interface between a TERK XM receiver and the factory wiring harness for the ES350 and allow you to set the audio levels for each input as well as have remote control capability of your IPod. The factory XM receiver will not work with the SoundLinQ SLXI but the Terk unit only costs about $50 and the SoundLinQ will be around $300 MSRP. The dealer cost of a Lexus XM radio alone is around $590.
The result will be that you can customize each input on the LCD screen, setting audio levels, etc., and matching volume levels between inputs, avoiding having to change volume levels when switching between inputs. In addition, you can control your IPod onscreen. Most Lexus technicians that install the Lexus XM radios are familiar with other SoundLinQ products and will be able to install the new system for you, when available.
I wish every ES350 owner would send emails to Lexus and complain about the cheap XM audio setup (yes, even the Mark Levinson)installed in Lexus vehicles and the poor sound quality along with having to constanly change volume levels when switching between inputs, especially with the XM radio installed. Lexus will never do anything about the system until there are enough complaints to warrant a "fix". The Pioneer XM radio is a cheap unit and will only work with a Toyota/Lexus. If you ever decide to switch to another brand of vehicle, you can't take your XM radio with you. Right now, the Lexus attitutde is, concerning the XM radio (paraphrased): "that's the way we designed it, so, live with it or don't buy it".
Not true. Sirius DOES maintain ground repeaters and you can ascertain the relative contributions of the satellite and the ground repeaters on any Sirius receiver by pressing the "signal" button. It will show you a bar graph of the satellite strength and a separate bar graph for the repeater strength.
Sirius rules!!!
After all, where else can you hear Howard Stern?
On a related note, I traded in a Honda Accord with XM. I just recently extended the service for a year on that radio. How does XM handle this? Will they apply my remaining "credits" to the new XM Radio. Will they waive the activation fee (they should)?
Too bad there are variable volume problems with this unit, but I can't live without XM regardless.....I just hope I don't get blasted out of my seat when hitting the Mode button on the steering wheel.....
XM simply transferred my account over to the new radio. Nothing was mentioned regarding an additional 3 months or free trial - oh well - but they did try to sell me an additional portable XM receiver - no thanks!!
The satellite radio performance is about what I expected. There is most definitely a volume difference between XM and FM, but I can live with that. I found the ML sound system with XM can be a little more "full" by setting the speaker balance adjustment a little more to the rear than using the default speaker balance. XM sounds not that much better than FM, but I think that is a result of the after-market approach to XM that Lexus is now doing.
As far as the overall sound system goes, you really can't appreciate the ML sound system until you play a DVD audio or video disk. Like home systems, the audio system in this vehicle is better when using better source material. For instance, I placed a DVD of Spielberg's A.I. in the CD changer and WOW. Great depth of sound and detail (I haven't yet played a CD in the system). You might want to try this.
Commercial video DVD's will play on the navigation screen only when the parking brake is on. If you release the parking brake, the video disappears but the audio continues to play. It's a safety feature that, I suppose, could be easily defeated, but then why chance hitting a telephone pole in your new Lexus while watching "The Lord of the Rings?".....
The 3 months free trial was given to me by Lexus, not XM. Sorry, the way I wrote it did sound misleading.
quality of the current cars that have
satellite radio integrated with the factory
stereo system. I'm currently using an XM
Roady portable receiver which is played
through the cassette player on my 2002
Maxima. It sounds as good as the CD Player
and, in fact, the volume comes in louder than
the CD player and much louder than the radio.
I think I'd like to hear the actual sound of
the satellite radio on these new cars when
I seriously start looking for my new car.
I just put a deposit down on a UL Es350 I'm looking to get the Smoky Granite. I have a week or so before the car gets to Port so i am debating whether to get XM or not. I have seen a number of isssues here with regards to the volume and/or sound quality Does anyone have XM with the ML system?
Has the dealer or Lexus been able to offer any solutions regarding the voume issue? and finally for those that do have the XM are the problems making you rethin your decision to get it?
Thanks All
But it is a moot point for dealer-installed XM radios in ES350 cars. There is no current SIRIUS, dealer-installed, radio. The only unit being installled is a Pioneer XM receiver that plugs directly into the factory wiring harness via a cable that is part of the kit.
Subject: Satellite Radio Antenna Placement.
FAQ: "Could you speak about the differing antennas available, and why Lexus chooses to use the trunk mount instead of the roof antenna?"
Lexus reply: "Reception quality varies in the different areas of the country. From a continental US national perspective, the trunk mounted antenna provides the best XM satellite radio signal reception for sedans as does the front window mounted Sirius antenna. For SUVs, the antennas for both XM and Sirius are mounted on the roof. Installation of antennas in areas other than those recommended by the manufacturer could lead to a degradation of satellite signal and poor reception. The Genuine Lexus satellite radio kits include wire harnesses specific to each model that allow for the recommended installation placement of the antenna."
FAQ: "Can the antenna be placed somewhere else, other than the trunk?"
Lexus reply: "From a national reception quality perspective, we cannot recommend that the antenna be placed anywhere other than the installation instructions specify. Installing it elsewhere could lead to a degradation of the satellite signal and poor reception. For sedans, the XM antenna should be installed on the trunk lid, while the Sirius antenna should be installed behind the rear view mirror on the front windshield. For SUVs, the antennas for both XM and Sirius should be installed on the roof."
You can find an archive of their mailings here: http://www.lexus.com/pursuit_archive/?s_ocid=Pursuit:0606:Main:Archive
The email was from "lexus@lexuscommunications.delivery.net"
The Subject line was "Lexus Pursuit: Partnering with XM(R) Satellite Radio"
Here's the relevant text:
We're proud to introduce an exciting new addition to our vehicles—available XM® Satellite Radio [1]. At Lexus, we focus on carefully crafting every facet of the driver and passenger experience. And now that same level of precision extends to in-vehicle entertainment.
This October, we're raising the bar on car audio again by offering factory-installed XM Satellite Radio [1], allowing drivers to access and enjoy more than 170 channels of music, talk, sports and specialty programming—all with unmatched digital clarity, and easily controlled through their vehicle's existing audio system. The 2007 LS [2] is the first Lexus that will offer this option, but soon all our vehicles will offer the choice.
There was also this interesting tidbit:
Another benefit of XM service is the available XM NavTraffic® [3], the nation's first satellite traffic data information service. XM NavTraffic enhances the Lexus voice-activated HDD Navigation System [4] with continually updated traffic information in many of America's largest cities. With more information at your disposal, you can avoid traffic congestion, accidents, road construction, and find the best route to your destination, in real time. All of which means you can get there faster. Though we'll certainly understand if you'd rather take the scenic route in your Lexus.
Our partnership with XM Satellite Radio [1] is just another example of Lexus' passionate pursuit of the perfect sound
I sometimes think our generation is a bunch of whiners. It is not difficult to turn the volume up and down when switching from different audio inputs. If you decide to get XM, I think you will be very pleased with it overall.
