Dodge Durango idling up and down
I can not figure out what is wrong with my car I really can not afford to take it to the shop so I'm trying to see if I can fix it on my own. The car idles on its own with out me doing anything to the car sometimes the service engine light goes on which makes the car jerk. I took it to a shop and was told it was the idle speed control motor. So I bought the part and put it in myself, but the problem still continues. The shop also said it might be the TPS. Can someone help me?
See Also
Edmunds Answers: Dodge Durango Idle Question
See Also
Check the Dodge Durango: Problems & Solutions discussion for any related posts over there (try a Search This Discussion for idle).
Cindy
Was/is idling high. Cleaned throttle body plates...no luck.
In the past i had heard what i assumed to be the fan switch click on and off. However because of/while doing the above with car running, I noticed the switching was from the air conditioning unit switching on and off.
Checked nob on console, air was off, blower set to blow from upper and lower (arrows). Moved the knob to another position to the right, and, the air stopped switching on and off and the car idled down! Stands to reason that the idle would be high with air conditioning on. Now to find the solution.
The fix? maybe someone can share their knowledge. All i know is the hight idle was getting bad and i have to now change brade pads, and, what sounds like front u-joint.
Ron
Escanaba, Michigan
downshift to speed up by hitting the gas pedal, the rpm fail to return
back
to normal even when I stopped the car, the ideal speed will stay at
around 1000-1100rpm instead of the 700rpm idle, I have to stop the
truck and momentarily tap on the gas pedal to correct it. Will happen
again from the next stop and go.
Also another issue is when it is picking up speed from stop, it has a
hard time upshifting to second gear not until it went up to around
2000rpm in
about 2s.
Not sure if relating to the IAC unit and if these two issues are
related. Appreciste if anyone can give some advise.
4.7L (V8)
94,000 Miles
Guys, I am a little stump as well as some other mechanics; Maybe someone has had the same issue or something close to it. The vehicle was running fine and then the check engine light came on and there was erratic idling (500RPM to 1500RPM at a stand still), one of the spark plugs was mis-firing, so the wife told the mechanic to go ahead and do a tune up, Now that the erratic idling is gone (idles at roughly 700RPM or so), now when driving I notice a vibration (not too rough, but enough to now something is wrong) and what I believe is a sound of airy and/or fluttering (I do not know how to describe it) between 2000 and 3000 RPMS, and appears to go away once I am at about 45+MPH. It does not do this on a cold start, only after about 5 minutes or so of drive from 25 - 35MPH (2000-3000RPM). I just assume after the mechanic did a tune up he had not cleared the computer, so I reset it by disconnecting the Negative cable from the battery, but still no dice. The dealership says to come in and they will hook it up to the computer, but that will cost another 100 bucks for a diagnostic that will not tell them very much from what another dealer knows (No error code). I have the Haynes repair manual and pretty good with a toolset, but by far not a mechanic. So if there is anything I could be checking, any help would be appreciated.
Billy
the motor just turns off no choking no nothing just turns off, but the weird part about this is when the engine tuns off all my gages remain the same with the engine then all my gages shut off.
WHAT COULD THIS BE !!!!!
ANY IDEAS ???
My durango did throw a check engine code, but it did not reveal the problem with the TPS.
By the way, my TPS was the problem and has been perfect since replacement. The fuel injector service did not help fuel milage :-(
I'm having the same problem with idling up and down, was told by dealership TPS needs to be replaced--for about $180, is this a complex issue or can i have any shop replace this? From what i have read it doesn't seem like it's a big problem....
2000 durango v8 4.9 engine
Recently I took a trip to the mountains in Colorado. As soon as I got up to about 6,000 ft, the engine started surging and it wanted to downshift. The check engine lite came on. When I returned to a lower altitude, after a while the lite went out and the performance improved somewhat. It still surged somewhat and continued to do so occasionally even after returning home to Illinois.
Any thoughts please.
Jim347
SUVs and Smart Shopper
I was in the same predicamant with my Durango thinking my only option is a new car but fortunately replacing the PCM solved all of it's woes. It now idles perfectly in all temp conditions and even fixed another issue I had which was the AC compressor clutch staying on all the time. The engine code for PCM was P0601 which was a GENERAL FAULT CODE PCM. This part is $800 if bought through a dealer, I found a refurbed one on Ebay for $200 and free shipping!
Anyway, trouble code showed the power steering pressure sensor was bad. It controls the idle speed during stops and starts and when the ac is on. Haven't had a problem with the idle since. Of course this is a dealer fix. Local garages wouldn't do it. Hope this helps.
I've cleaned the IAC a couple of times but the next time I'll probably just replace it.
