Toyota Tacoma Performance Tips and Mods
in Toyota
I just bought a 1997 Tacoma and I was wondering what improvements I could make to the truck to increase its performance, such as intake, air filters, etc. It would be a great help if these improvements could be on the low priced side of auto parts. Thanks!
How much and do you like the sound??
Is this part of the TRD Sport package??
system.
I have always wondered about this but no one could really explain to me why an engine needs backpressure. I found this article "Destroying a myth" (http://www.uucmotorwerks.com/html_product/sue462/backpressuretorquemyth.htm) that states a lack of backpressure is not the cause of burnt valves. Rather, it was a problem with the carburetors which produced too lean of a mixture. Today, with our computerized engines which can modify the air/fuel mixture on the fly, this is no longer a problem.
Cheers
2002 dbl cab v6 3.4 prerunner.
My main concern is problems while offroading. I heard that there is a possiblity that the air intake will not be able to filter some of the fine sand and dust as well as the factory air box.
Also if anyone has had problems with there intakes please post your issues.
Any insight is awsome! thanks!
Jay
mine was due to bad cadylic converter. dealer changed it under warranty.
i saw the invoice they charged the warranty and it was upward 1500. get it done while you can. gas mileage and pedal is more responsive.
also swap out the stock 215/70/15 out to goodyear wrangers 235/75/15.
best tire for the money and offset of mph by 3.0 in your favor.
stock tires are -2.5 thus expiring your warranty sooner. if you want on the dot speedo go with 225/75/15.
