GMC Yukon AC and Heat Questions
My front fan quit. Last December, I got a new front control, installed it and it didn't help. I removed the resistor block, cleaned it and spun the fan and it started again. Now, 6 months later it quit again. I did the same thing as before and it ran for a couple of days. This time it started again on its own for a short time, but the rear air fan also quit once. Would it be the body computer?? I know I read something about the noise coming from the headliner, the auto temp sensor fan making noise, it is or has in the past. Also, wondering about a dead spot on the armeture, but it doesn't explain the rear problem too????
Thanks for any help, Lyle Pfeifer
Lyle Pfeifer
I have crawled under it but cant find it.
My problem was that I didn't know there were 2; one for the rear and one for the front. I thought everything worked from the front but there 2 complete systems, only one compressor tho.
The thing is it's different from how it used to work, where it would control to the temperature that was set.
The dealer simply said that I need a new computer. But to me it seems like a sensor problem, because the computer is still doing everything that it normally does, except backing off when it reaches temperature. It's as if it can no longer sense the cabin temperature correctly.
Has anyone had any problem like this, and if so did you figure out how to fix it? Any thoughts would be appreciated.
Update on my problem, it started again, not to work. I pulled the controller out and the plastic was somewhat melted again. It looks like the meatal tab that is suppose to come down hard and make good contact on the controler contacts was hanging up in the plug, creating a lot of resistance, causing the thing to heat at the contact point. I worked the metal contact down so it makes good contact, but the wires are now somewhat hard from the heat. Looks to have been a defective plug from the factory as I have never had this part out since new.
Good luck, Lyle
Did I get duped?
Well, I work with computers every day, and I know that unit must have a "self-learn" function. So, I went to the fuse box under the hood, pulled the fuse to the A/C control system. Waited a few minutes, reinstalled the fuse, and started the car, and within one minute the system reset and started working correctly.
Of course, over multiple trips to the mechanic it has worked every single time for them.
This is driving me nuts! At this point, if there's a part that's a likely culprit I'll just buy it, hand it to the mechanic and have him replace the !#$@ thing. Does anybody have any ideas what could be failing that would keep that nice cool (or hot) air from getting all the way into the cabin ?
Thanks in advance,
Pat
When I turn on the AC, the motor is actually making a sound. It sounds like something might be caught in it, but it's a humming sound, and I don't know how to go about diagnosing it.
Also, there is a clicking sound, but ONLY when it's on the direct ahead placement. Whenever air is directed to my feet or the defroster, the sound goes away. I'm sure a dealer will scerw me, so I wanted your input. Thanks!
I change out the a/c belt and the belt tensioner becouse they were worn out.When i turn on a/c all was good while at adl,but when i accelerate the belt tensioner would jump,bounce,and make a clamping noise.
Just don't know what to cheak for now,any ideas were to start trouleshooting next or what to look for?
I started hearing a rattling noise from the engine compartment every time I turned on the A/C, which subsided after driving. Around that time, it was blowing hot air in the rear compartment. Then I began to hear the rattling even with heat/defroster. Finally, I'm getting hot air from the front. I checked the fuses and all appear good.
Any advice/help would be appreciated.
Thanks. Also, don't know if this matters. The battery went totally dead and was replaced approximately eight months after I took delivery of the car.
If any of you have any insight as to what migh be my problem I'm all ears (eyes).
D
Lyle
Lyle
I recently had a new water pump and t-stat installed as part of a non-related repair, but no-heat problem was not solved. Operating temps seem to be within normal parameters. Water supply line to heater core is very hot, return line is ice cold. Possible plugged inlet to heater core? Seems possible, but not probable. Somebody suggested that I look at the actuator(???). Any other suggestions?
My Yukon is doing the same thing. I was wondering did you ever get your fixed and if so what was the problem. Please inform me because I have not had my Yukon for 4 months and the dealer is about to get it all.
Thanks for the great tip! I recently replace my battery on my '04. Well, when heater is turn on the passenger side blows Hot air but, the driver side blows Cold air; "very cold".
I called the dealer and they didn't have a clue but wanted to keep my GMC for a few days.
I think your reprogramming will reset the system. . .thanks --Los Angeles, CA
in the summer sometimes it takes mins. before the a/c will blow....
no problems with air temp.. just the time lag for it to blow any air at all...
anyone have a clue?
Lyle Pfeifer
ok this morning it was cool 45degrees and it took awhile to come on. now it's 65 and it will turn on real quick... if it's 100 the a/c will take awhile to blow
but rear air is normal in all aspects
SUVs and Smart Shopper
Lyle
Hope this helps. Let me know, as I had this problem with a 2001.
Lyle Pfeifer
I remove the fuse and waited few minutes before replace it.
It didn't work. I still have cold air blowing on the drivers side and hot air blow from the passenger side/. Any Ideas
I have a GMC Yukon XL ’02 and it was fine with me until today, I drove to work (it’s about 20 minute drive) and after I park it I turned it off, then suddenly the AC turned on as if it on Auto, I tried ever thing to shut it down I remove the large gray fuse and small 10amp fuse under the hood and the AC still works I turned the SUV on and I couldn’t even control the AC it seemed it has a mind of it's own.
finally I unplugged the battery and guess what it works the damn thing went back to normal. my question is what the hell is wrong with my SUV !!????
