Dodge Sprinter Audio Systems
Does anyone know how to reset the factory installed radio in one of these vrhicles?
x x x x
x x + x
0 x x 0
0 x x 0
We have a 168" dualie 3500 limo style, band touring build on our Sprinter. I'm trying to replace the stock radio with one that has CD/CDR/mp3/SAT/iPod. Finding the one we want to buy is not the problem. Finding the kit/harness/antennae adapter is the problem. Anyone? Bueller??
Don
The post i referance gives a diagram of the plug and which wire to tap in to.If you can not find it contact me as i think i have a copy.
I am having the same problem.
E mail bsperty2@comcast.net
http://www.crutchfield.com/S-evM5UDzO7Qh/cgi-bin/ProdGroup.asp?g=103000&avf=Y
This is the same connector as for Volkswagons (some European Volks Vans use the Sprinter chassis/body too).
That piece takes care of the basic harness, but you may need the antenna adapter too.
On the yahoogroups sprinter forum you can find some good audio helps, like how to add an external input to the factory SOUND 30 sprinter radio. look in the archives/files
KenB :shades:
Sprinter-Forum.com
Also, for the short term, does anyone know of an adhesive that will allow electric current (to glue antennae into stripped receiver)? There's too much plastic to try and solder it in place.
tdarling
TDarling@aol.com
Suggestions? I Am a 72 y.o.electronic idiot. Thanks foryour help in advance! (06 Sprinter)
Anyway, perhaps we can find you info on that booster or other antenna issues.
Did he have to use a convertor cable? or is it the connector direct-attached to the radio?
KenB :confuse:
KenB
http://www.berrysprinter.com/sprinterinfo.php
click on the radio codes by vin link on the page :shades:
KenB
any other sources to find it? dodge is being useless as always trying to look it up.
KenB :shades:
Dan
KenB :confuse:
Also, technical stuff answered better on Sprinter-Forum.com
WWW>Sprinter-Source>COM
http://sprinter-source.com/forum/
(come join us there too)
KenB :confuse:
