Nissan Armada Towing
                    Can anyone help me with this..The GVWR (Gross Vehicle Weight Rating) For the LE Armada is about 7000 lbs, it's curb weight is 5623 lbs, that leaves about 1400 lbs that the armada can be loaded up with to meet specs. With a towing capacity of 9000 lbs, trailers that are 7000 lbs and up have hitch weights of 900 to 1200 lbs. That leaves about 200 lbs. I weigh 250 lbs, does that mean my wife goes on vocation without me and the dogs. I can't believe that nissan would design the Armada without at least GVWR of 7500 lbs for a 9000 lb tow capacity...Somebody please explain.
Also, you should maintain a tongue weight of 10%-15% of the trailer weight. So, with a 7,000lb trailer you would maintain a tongue weight of 700 - 1,050lbs. Assuming your weight distributing hitch redistributes approximately 30% of the 700lbs, or 210lbs to the trailer axles this leaves you with about 490lbs added to the Armada. Taking away the 490lbs from your 1,400lbs available leaves you about 900lbs for other cargo.
Maintaining proper tongue weight, and properly setting up and using a quality weight distributing hitch is essential when towing with an Armada or any other 1/2 ton vehicle.
The 2nd time we tried, we could smell the burning fluid again, so we turned around and took it easy coming back home and they said they found metal shavings in there and replaced it again and this time they said they put synthetic fluid in. We took it up there once more, but did not fill up the trailer with water and left the quad at home to reduce the weight. We made it this time. Not sure what will happen the next time we add the weight to it...
Ct..
-mike
Another option for those of use planning to tow often would be to get some finned rear diffy plates, perhaps off of the pathfinder to aid in cooling.
-mike
-mike
-mike
-mike
I have a friend who lives in LG and we usually stay at his place but next time I may stay on the boat either at the Lake George Village Muni docks or one of the coves. We lauched at Fishies Marina on the Eastern Shore. Heading up there camping on the big island July 8-12!
I launch out of Barneget in NJ and Liberty State Park for NY Harbor.
What kind of boat you have?
I'm also planning on doing the rear diffy fluid shortly, so I'll let you know what that looks like after towing with the truck a lot.
Pics are up http://pbase.com/paisan/mdw07
-mike
Price was fairly cheap on the water about $3.75/gal on LG. I have a 185gal tank so I almost always tank up on the trailer. We put in 105 gal on saturday to the tune of $325...
Cruisers are cool, my next boat will likely be a cruiser although thinking of selling the 33 Outlaw and getting a 30ft centerconsole with Twin 225s or 250s.
-mike
-mike
This Armada does have the factory towing package with a hitch capacity of 910 lbs. I was told it has an auto leveling system but if it does it isn't working. I have no idea how to tell if this auto leveling system is installed.
Can you tell me how to verify this is installed? And how to determine if it is working as it is supposed to?
If it is not, what would be the best way to raise the rear end? Airbags??
I never had a problem with the back end being to low...just a problem pulling up a mountain.
-mike
"All U-Haul braked trailers use a surge brake system."
I assume I don't need brake controller. Please correct me if I am wrong.
Related to this also I am not able to locate brake controller plug under the dash. Actually I found the white tag which reads "brake controller" or something but I cannot pull it out and I don't see the head. It is also possible it was already used by previous owner.
And lastly I am planning to change transmission, transaxle and transfer case fluids. Any thoughts for this would be very much appreciated.
-haro
As for the brake controller, none is needed on a trailer with surge brakes so you are good there. If you were to hook up a brake controller at some point you will need the harness that plugs into the trailer harness under the dash. Essentially there is a harness with bare ends that you connect your controller to and then plug that in under the dash.
-mike
I feel good and safe now
I have the harness and it was left in the glove box when I bought the truck. Hence I think someone must have used it before me. Anyway I don't need it now.
I have around 34+K on odometer (it is a 2006 model) and am planning to have all gear oils changed before moving. Does anyone knows any details, like transmission oil filter change is needed, or any gasgets, etc.
-haro
I consistently get 13.5mpg in the city with my 04 LE w/towing package and I don't drive gently.
On the highway I'll pull about 17-18mpg doing 70-75mph.
Towing 10,000-11,000lb tri-axle boat trailer at 67mph with AC on I get 10.5mpg from NYC up to Lake George.
-mike
-Andy
-mike
Motorsports and Modifications Host
We regurlarly tow a 4horse trailer with 2 horses on board and load the Armada with saddles and gear.
We also tow hay(4 horse trailer fully loaded)frequently from the North Ga mtns to Ocala,Fl.About 6500LBS without a Load leveler with NO swaying problems(99% interstate).
We now have 40K miles on it and it is a great SUV to run these mountain curves with (25mph-many).
I HIGHLY recommend the Armada and that's said after my 400 races I've driven(retired).
The trailer has electric brakes and my controler is easily adjusted.
This is the one if your looking
PS:No service problems,perfect mechanical record.
-mike
Has anyone delt with this or is my system faulty?
Thanks...
-mike
Subaru Guru and Track Instructor
Just read all three pages, easy read. I cannot wait to tow with the Armada as we recently upgraded from a Toyota 4Runner, 8cyl. That towed great with my camper, I am expecting the Armada to do way better as it tows 2k more. Mike, I agree with you that most people believe that you need either a dually or HD to tow and that is not that case. I loved towing with my 4Runner and looking forward to many happy years with the Armada. Ours is 2014.
