its running very rough,getting bad gas milage. when i get off the freeway and come to a stop it stumbles and then picks back up. it does it at a stop light also,lacking power.
i hooked up my "OBD2" code reader, and it gave a reading of "P301" #1 cylinder Missfire Detected
#1) Replaced Plugs & Boots and coil housing
#2) i placed a ohm meter between #1 & #4 on the coil tower and it read 5.0 ohms the same between 2 & 3 and no reading between coil and cover Plate
#3) switched coils around to see if it was the coils. still shows #1 Missfire
#4) i checked my ignition module by connecting a test light (at the module) between bat. pos. terminal to the coil(Terminal A) and terminal B or C . when cranking engine light blinks. according to the book tt that should eliminate the module from being bad. but to check for open or shorted circuit in the coil wiring harness. i didnt do that. how do i do that? and where do i do that?
#4) put a ohm meter to no.1 injector, the reading was within specs described in book.
#5) i Disconected the electrical connector to the (IAC) "idle air control valve"started engine and pulled off each injector connector to the injector and there was a noticable difference in idle change
i didnt have a spark tester light so i couldnt test that
from what i described you have any advise or instructions besides "take it to the shop"
thank you
if it has to go to the shop again, this will be the 3rd time in the 6 months i've had it.
Everything lights up fine, they just don't work.
Just about everytime, I have to hit the top of the radio panel a few times to "jar" into working, however a few times this doesn't work.
I have called auto repair places and unless it is doing it at the specific time that you have it tested, they said it will show up as nothing wrong. I have taken to auto zone with no luck.
Is anyone else having this problem and is there anything that can be done?
I have to drive 2 hours when I pick up my kids from their dad's soon and I can't drive with the windows up and no working a/c in the summer with them in the car.
Refarding the wet floor, ask your mechanic to lo clean the Drain hole for the
Air Conditioning. It could be located in the firewall, behind the engine.
Also check the Heater Core.
Bev
is is the swirch in the column or is it electical
help Bev
In the owners manual there are not any relay related to parking lights. I do not know if it is switch lever related or relay related. 2001 Pontiac GAm GT
http://www.grandamgt.com/forum/showthread.php?t=50126
A) get a new remote
or
My question is, where is the keyless entry module located, so I can remove it if I go another route.
Also, If I want to get a replacement remote, can programming be done by me or require speciate equipment.
I appreicate your responses.
