Toyota Yaris: Towing Questions
![[Deleted User]](https://secure.gravatar.com/avatar/3ccc0da67b422086372047c2bd4ca48c/?default=https%3A%2F%2Fvanillicon.com%2F05e82f3781f900461b597509ca8d7b27_200.png&rating=g&size=200)
I commute 90 miles one way to work and would like a small car that I can trust. I also need to tow a small trailer only a few miles each year. Total weight of less than 700 lbs. Do any of these sub-compacts allow any towing or is this impractical?
Mike
I won't even go into how it hard (or impossible) it is to get options and parts for my Yaris here in Vermont, when the Canadian border is only 50 miles away. Major manipulation by Toyota/Scion and probably Big Oil / Big Car to boot. And I thought this was a free country!
I saw some online references to Yaris trailer wiring harnesses, and some about hitches for the sedan, but nothing yet on the hatch. But why would they mention it in my manual if it wasn't available?
found a couple websites offering trailer hitches for the fit. All have 1 and 1/4" receivers- price range about $125,
and is a bolt on hitch. I think tow rating is 1000#
I've loaded my xA on a steep hill with cargo (a lot) and then launched it uphill and it struggles. I'd venture to say that with 750 lbs or so behind an xA or Yaris, if you aren't on the straight and level, you're going to be buying clutches. I could SMELL my clutch last time. Not good--but in all fairness, fairly radical hill.
Also try "Honda Fit accessories"
My Fit is so low I would not want a hitch, even thoughit would be nice. A hitch would scrape on too many things
http://www.etrailer.com/products.asp?category=hitch&ql=yes&year=2007&make=Honda&- model=Fit&h=e
boatfloyd
Bob
The main difference would be where that wieght is located. The wieght when towing with a fit will be on the back bumper (toungue wieght)and I doubt Honda had in mind more than 200 lbs directed to the back bumper.
If you hook up a trailor even some of the smallest trailors, the trailor itself will probably wiegh 2-300 lbs. Once you start loading it, the wieght adds up quite quickly.
Although the engine would probably be okay, though struggling mightily on any sort of incline, my main concern would be damaging the transmission. There is no transmission cooler in the Fit.
I've seen pics of a Fit towing an ATV. It probably works, but I can't help but think that guy is slowly ripping up his tranny. I think towing an ATV behind the Fit on any sort of incline would be strongly ill advised by Honda.
Tell me more about the difficulties of tail light hookups and brake hookups on the Yaris.
I would appreciate any experience anyone has had with towing a Yaris and help with what hitch to use. I would prefer to use a hidden hitch like blue ox. However they do not make one for the Yaris.
I bought a Stowmaster Falcon II hitch and they make a hidden hookup plate for bith the 2 & 4 door Yaris.
Ken - Surprise AZ
I don't know where auto makers get their weight numbers, but pretty much any car on the road is over-loaded when full.
I am interested in the teardrop trailer too. Do you have any protection on your tranny - like a cooler? What type of gas mileage do you get? Do you pull long distance, for long days --- like across the country and on an extended vacation? What about wear on the tires?
do you have an automatic or manual tranny? I have automatic.
and then about your trailer - where did you get it? do you have any photos?
babz
2008 Liftback.
But I have no idea what the wire color codes are for a Toyota?
They certainly are not standard SAE color coded (as usually American
cars are)!
I need the wire color codes for the rear:
Brake/Right Turn/Left Turn/Park-Tail/and Ground.
Trailer does not have brakes on it. Reading what the UK has for towing on this car 2,000lbs is max braked or 850 unbraked. Of course in the US they say its not recommened. I'm sure the car will pull it, but if I have to stop to the side on the road (narrow for only 1 1/2 car to fit going by) for someone to pass in the other direction, I'm afraid that if I stall out the trailer is going to drag me down and possible accident. Thus a braking trailer would be ideal. Of course I could try this when I get the car and see how it handles. If I get the 'Oh Sh*t' feeling then trailer would need to be braked. That or I scrap the whole idea of getting a yaris to rack miles on and keep my S10 4.3 for a winter vehicle and carpool in my Wife's Scion TC. Oh yea, she refuses to install a hitch on her vehicle!
How did that work out towing through the Rockies?
Dan
I have one too and just bought a trailer hitch with the hopes of towing a small dingy/sailboat. I was surprised to read at the toyota site that they recommend not to tow with this vehicle.
I was glad to read about someone else towing. Any more thoughts or advice on towing with an Echo 2001?
Sean
Any suggestions are well appreciated.
Sean
