Toyota Matrix Brake Questions
OK, so I've done a VERY stupid thing. I put power steering fluid in my brake reservoir. The brakes seized up and now the dealer tells me that I have to have my entire brake system replaced.
Couple of questions:
1.) Does that sound reasonable? I mean, I know I have to replace the rotor on two of the wheels because they were really scratched, but the entire system?
2.) What should I expect to pay? They're telling me $3300, which includes a rental car for 3 days. That sounds like a lot, but I've never had anything like this done before and it's at the dealer instead of at a regular mechanic.
Cheers,
Steve/OHIO
either the return spring is bone dry and desperately needs lubrication OR it could have something to do with some sort of plastic clips associated with the brake pedal that i've also seen discussed quite a bit (not sure what that is..could that be what are referred to as the bushings?). I've seen other people talk about this problem in a Toyota Tundra, but not the matrix. am i the only one!? does any one know what can be done? thanks for your help
Will take it dealer soon.
:confuse:
One thing is freaking me out a little bit though. Whenever I brake moderately hard-(thankfully I have never had to make a full out panic stop), I get a slight rattle from the middle of the dashboard. It sounds like BB's inside a tube or jar. It only lasts as long as I am braking, a second or two.
Any ideas what it could be?
My tires, when 10K miles on them, were wearing weirdly. I had them rotated at 10K and when I drove away, got on highway, I felt the vibrations. I called them the next day, scheduled Another appt to see what's happening. Was told they would align front end (free) as it was just to the one-year date of purchase that very day! They re-rotated the tires, stating they puyt the "best" ones back on the front. What was now, again, on the rear has worn on the inside row of tread. I am now getting a louder tire noise than before. Now, I will not be told it's my imagination....I know a thing or 3 about cars and this isn't right. Tires should not wear like this on a ($22K)car this "young" unless there is a Problem with manufacture. Back to the dealer....again.
Help!
Erica/Washington
Brake fluid absorbs moisture, and if you don't have the brake fluid flushed every couple years what happens is the moisture collects in the caliper and actually rusts the inside of the piston cylinder. As long as the brake pads are wearing the piston continually moves outward, and isn't effected by the sludge. At some point the pads need replaced, and when you do that you push the piston back into the cylinder (to make room for the added lining thickness of the new pad). When that occurs, the piston now sticks. Putting on the brakes creates sooo much pressure that it forces the piston out (and puts on the brakes), but the piston is not free to float back when you take your foot off the brake. The result is the brake is continually on, you wear out the brake pad real quick, the rotor becomes overheated and/or warped, and everything needs replaced.
You should have had your other front caliper replaced at the same time, I suspect you will have problems shortly with that.
I normally just replace the front calipers every 2nd brake pad change as a maintenance item. They're cheap and relatively easy to do (for someone who works on their own vehicles).
This is a little hard to diagnose further without looking at it, but I'll give you my thoughts of what come to mind...hopefully others might chime in as well.
- first thing that comes to mind, is that they didn't get the caliper and brake pads (or the wrong brake pads) put back correctly, and something is binding
- second thing that comes to mind, is that you might actually have a frozen piston on the left side caliper (you didn't replace this, right?), which isn't doing any braking whatsover, in which case all of the front braking is done by the right side....and it is getting hot under what one might consider normal braking. If you let go of the steering wheel when you put on the brakes, will the car continue tracking straight? or does the wheel and car turn to the right?
- might be a crimped brake tubing/hose in the front right.
- starting to get less likely, but might have a blockage of some sort in the brake distribution circuit. I don't have the Matrix service manuals to know exactly what is included with the Matrix.
- Assuming the master cylinder is like almost every other vehicle, you'd have a front and back fluid circuit. No problem there would effect only one wheel.
However this is an excessive noise that grinds when the brakes are applied during snowy or icy conditions.
Any suggestions to fix the problem.
Charles
A few months later, the battery died. And amazingly the battery change fixed the problem. I have a more powerful battery though. Maybe you can try it.
The vibration at stop used to drive me nuts, especially when the A/C is on. Now no more vibration. Good luck to you.
Sometimes an old battery will draw a lot of charge current due to worn out plate separators. The alternator would have to supply that extra charge current. That increases alternator drag and makes the engine work harder, especially at idle.
Thank you in advance!
Johnson
I don't think anyone can offer more specific help sight-unseen.
Brake fluid attracts and absorbs water, which lowers its boiling point.
You should replace the brake fluid every 3 years for this and other reasons.
If you don't have ABS it's a moderate DIY job:
siphon out and refill reservoir then bleed brakes (and clutch if manual).
In the past all my vehicles that had ABS system made a funny sound (grinding noise) or other sound depending on the model.
Those where a 1991 GMC Safari, the sound resemble a mooing cow, I called my Safari "my big cow" because of this, it was my first with ABS, I freaked the first time I heard that sound.
Then a 1994 Chevrolet Blazer, this one had a grinding sound but I knew it came from that ABS system, after that a 1999 Chevrolet Venture, this one I'd say a "humming sound" almost like a organ note and presently I own a 2005 Equinox and the ABS system produces a very soft grinding/humming sound.
It seems that the sound comes from the brake system computer adjusting the wheel so they don't stop turning giving them the same pressure on all 4.
That's what makes you steer your vehicle while applying the brakes.
Weird isn't it. Four different vehicle, four different sound.
Your grinding sound seems pretty normal to me.
I've been hearing that noise since 1991 when applying the brakes on every vehicle I've owned, every time I apply the brakes on a icy or snow covered surface and even on dry or wet surface every time the brakes are applied hard I hear that (grinding/humming or ever) sound that you hear.
By the way...not an accident since I started to hear that sound.
It doesn't even come from the brakes, it's from the ABS system.
Don't worry, it has nothing to do with the recalls that Toyota came out with recently.
I had a similar problem (not a brake problem) but a problem with the service at the dealer where I had bought the car and I simply went to another Toyota dealer across town and they where extremely nice and polite with me far better than the dealer that had sold me the car.
They gave their 100% for my satisfaction.
Any Toyota dealer can, will and are supposed to take care of you with respect and loyalty.
