Honda Element Real World MPG
SUVs and Smart Shopper
City 60% & Highway 40%: 22.19 mpg on mixed driving 205.5 miles/9.26 gals.
Highway 100%: 109.6 miles/4.11 gals. - 26.6 mpg
Equipment & Maintenance:
Odometer: 133,000
87 Octane Kroger Fuel Used 80% of the time
Synthetic Oil Change every 5,000 miles
Cooper Radial Tire Rotation every 5,000 miles
After Market Fuel Reduction Molecular Plates Attached to Oil Pan and Fuel Tank 8 Months Ago
Comments:
This vehicles used to get a maximum of 21 mpg on the highway and about 19 in the city. I added the fuel reduction plates about a year ago and have seen a maximum of 32.5 mpg on a trip during December between Columbia, SC and Orlando. I typically run 75 - 80 mph on the highway. The air conditioning is always running, even if I have the sun roof removed when it's really hot. The plates seem to be working. $80 well spent. Getting ready to install an HHO device to see what that'll do.
It's a commuter car with 100% city driving.
Used to get 19.5 - 20 mpg.
Two tanks ago started to drive like there is an egg under gas pedal, trying to keep rmp near or bellow 2000.
And the result is 24 mpg on each of the last 2 tanks - that's 20% better.
Best
I'm interested in the 2008 SC Element automatic and have read alot concerning gas milage. Has anyone purchased any after market chips to improve their gas milage?
What types of after market handware are drivers using if any?
The manufacturers are under a lot of pressure with CAFE rules to get the best mpg they can out of their engines. I think most of the aftermarket stuff is a waste of money. The easiest way to help your mileage is to slow down.
Anyone try a chip?
Mileage - consistently 23 in town (hilly town) and 26 on the highway at 75 mph. I've done 27 mpg a few times when the road system is flatter than Huntsville. When the mileage slips I've learned to grab a new air filter; mileage shoots right back up. Once in a while the engine gets sluggish, which I've attributed to a bad tank of gas, and a bottle or two or injector cleaner gets things back to normal pretty quickly.
At 6'5" I love the head room and leg room in the Element. One tip I'll offer buyers/owners related to tires; the original equipment tires are more expensive to replace than wider tires with a slightly shorter aspect ratio (sidewall height). When the original set wore out at 30K miles I replaced them with 225/60R16 (not a perfect alternative but it works fine), I saved $100 on the set of tires and, since the car was much less likely to sway with the shorter aspect ratio, I got 45K miles out of the second set of tires. That's a huge savings for such a minor change.
How many miles did that used '94 Element have? Just kidding, I assume you mean '04! :confuse:
Hi, can you please post details about these fuel reduction plates, and where you got them? Thanks!
Craig
I will be tracking my fuel from the first tank, and I will post here frequently. My plans:
Immediately: K&N air filter; drive with "slow & steady wins the race" style; use Sunoco fuel, 87 octane; minimal AC usage.
Future: Switch to Castrol Syntec oil.
I've heard that the combination of using synthetic oil and the K&N filter will consistently yield about 10% better mileage. Remains to be seen, but that is my plan.
The only catch is, Honda recommends NOT using synthetic oil until the car hits 10K miles, at the earliest. I will hit that mark in about 5 months (I drive a lot..).
Any other thoughts or recommendations on when to begin using synthetic oil?
Thanks-
Craig
Edmunds didn't find any measurable difference in mpg testing AC vs no AC. They didn't test driving with no AC and the windows up though. More here:
We Test the Tips
We Test the Tips Part II
Aggressive driving seems to be the real gas mileage killer.
Thanks for the info & links, makes sense. I will take your suggestion and run the oem air filter through the first 10K miles, and switch to synthetic oil and the k&n together. I'm not approaching it very scientifically, but I will have a good base to compare against as you suggest.
One thing I have noticed in my Civic is a solid 10% increase in mpg when I use Sunoco fuel. I've compared it against Sheetz, Citgo, and a few others. Again nothing scientific - but it happens consistently enough to keep me going back Sunoco.
Take care,
craig
Is there a difference in mileage when using 10% ethanol vs. regular gasoline?
Sunoco is a Top Tier, but some say that's just a marketing designation.
Please report back as you enjoy your new ride!
For example in my Civic, between April and October I would average 36mpg. Once October hits, I'm lucky if I get 32 or 33. And it's not a sharp drop in temperature, because literally one week it's high and the next week it drops... even if it's in the 50's... until mid-April again.
So whether my theory is accurate or not, I'm not sure. But I've always heard that Ethanol is widely known to cost us about 10% in fuel economy.
Picking up my Element TODAY.
Hey, should I pick up one of these Scan Guage devices? Thinking about it, wondering if it will pay for itself over time.
Thanks-
See the NY Times article of 26 Jul 08 page B1 "Ethanol Stirs Up A Mutiny" on the effect of mpg. I noticed on a recent drive through South Dakota that mpg dropped off on a clocked tank full of "corn pone." (My moniker for ethanol.)
- Stay below 55 mph for the first 600 miles
- If you go on a long trip (two hours or more), try to vary your RPM's now and then (e.g., don't go 60 mph for an hours straight
- Do your first oil change between 1500 and 2000 miles
- Use common sense and drive it "slow & steady" for the first 1500 to 2000 miles
Again, this is what I do, not stating anything as fact - just my opinion(s).
craig
I should mention that my salesperson was also in agreement with his techs as well, but again others will tell you differently.
hth,
craig
So I clocked my mileage for my first tank of gas. Now I have to say the dealer is the one that filled it - so whether it was truly full, that is unknown. If it was not full, this works in my favor.
My driving consisted of roughly:
- 10% highway
- 10% city (stop & go)
- 80% suburban / rural roads (40 to 50 mph, but plenty of hills here in PA)
- Additional notes: AC was on for maybe 1/2 hour, passengers ranged from 1 to 4 (mostly 1)
MPG: 25.81
Total miles on tank: 345
Refill: 13.367 gallons X 3.81 = ~$50
My driving style: For this tank I would rate it as slow & steady. I only really get on the gas when I have to pull hills, and even then I am as light as possible on the accelerator.
Not bad! Will report stats back on tank #2 this week.
EDIT: Oops, forgot: 2008 Element EX AWD Auto
Can an Element hit 30 mpg on all highway driving if you keep her at 65ish?
Is there storage in an Element for bags to keep them from shifting around when driving?
Depends - not really as far as the Element is concerned. The FWD models are only rated 1 mpg higher on both sides (city & hwy).
Probably not maybe 30 with the wind at your back - but I think someone here reported 32 mpg after installing fuel saving "plates"? I asked for a link to more info but never heard back.
Yup - bungees. Plenty of little rings and hooks to tie down to. Plus the driver's side seats both have kind of a net behind them, good for smaller bags & things.
hth,
craig
Well technically, the 08 awdex is 1 mpg less efficient than the fwdex, on both the highway and city side.
Well, not really. For that, I picked up the Cargo Cover, so people can't peer into the area behind the back seats. But it's not really a "locking compartment", like say, the trunk on a Civic.
If someone wants to get into your car, they will. But if you hide your stuff well and don't leave any clues as to what might be inside... you should be relatively safe. By clues I mean - no stickers advertising stuff you like - Nikon, Apple, stuff like that.
Guns...? Not sure. But most thieves won't break into a car if they don't see anything of value right out in the open (wallet, camera, watch, computer bag, etc.).
So the Cargo Cover should help with that. Out of sight - out of mind!
OK, for my 2nd tank, I used my baseline of filling the tank between $.50 and $.75 over the "click" of the gas pump handle.
Driving conditions:
- maybe 5% highway
- 95% back roads, 40 to 50 mph, pulled lots of hills
- used Sunoco fuel 87 octane
MPG: 26.80
An increase of 1 mpg, even more back road driving this time. Still driving slow & steady, taking it easy going up those hills. Essentially I am doing the speed limit, maybe 5 to 10 mph more here & there. Nice & light on that gas pedal.
For my third tank I am curious to see what I get - I filled up with Sheetz fuel. I don't expect the same as Sunoco, but we'll see. And, I will be doing some more highway driving over the next few weeks. I will keep tabs on the general percentage of highway vs. back roads.
(so don't get too upset if the Sheetz tank is way off what the Sunoco gave you ...)
The beefier new Toyo tires did seem to lower the mpg it for a while. Now it seems to be back to where it was before I replaced the stock good-years. I do agree that choice of gas does seem to cause some variance.
I am curious about the gas saving plates from earlier, but that sounds sketchy to me. There is a lot of chatter on this list lately. I'm cuious, are folks buying Es right now downsizing from larger SUVs and trucks?
Personally, I just traded an '07 Civic EX for my Element. Took a hit in mpg (averaged 36 mpg in the Civic) but I LOVE the room and versatility of the Element. I rescue / train / show dogs, so it is a perfect fit for me.
Essentially it is costing me about another $80 per month to drive, but it's worth it. And now my wife - who never liked them before - totally wants one. They are contagious...
craig
Again essentially I am just feathering that gas pedal, and taking easy up hills - and coasting on the way down. Slow starts & stops, and I do right around the speed limit, 5 to 10 mph above.
craig
The Element has a conventional 5-speed automatic while the Freestyle has a CVT, so maybe the difference is there, but how does that make up for 500 lbs of mass difference?
I like the Element and want to buy one, but am unwilling to get about the same MPG numbers as my bigger, heavier, more powerfull vehicle I have now for a 4-cylinder light Element. You'd think the Freestyle's bigger 17 inch wheels would reduce MPG to way below the Element, but thats not the case. What is going on with the Element?
I am reasonably certain that I could hit 30 on a long flat trip as well, based on what I've seen in my first three tanks.
At 60 mph the element (awd ex auto) hovers just under 2K rpm, if I recall correctly (sorry - I've only had it for 10 days..). At 70, 2.25K rpm. Not bad at all, and right inline with my Civic.
A lot of factors could go into why these two cars get about the same mileage, despite the weight and hp difference - the short answer is, that's just how they're engineered. Specifically, the CVT and general aerodynamics could be a big part of it as well.
Ya between my dogs and my photo gear, it so versatile. Coming from a 36+ mpg Civic, it is still worth the difference in mpg.
I think the car will work well with your child seat, with the way the doors are designed. And it's an added safety that kids can't open the back doors without the front doors being opened first (although, to some, this is not a plus...).
I owned a 206 FS, and I don't think the aerodynamics are nearly as bad as the Element. The Element is boxy; the Freestyle (while is has a pretty large frontal area) is much "smoother". It is based on the Ford 500.
I think the difference between the two is the CVT in the FS. When coupled with the 3.0 engine, the computer can use the lowest possible RPM.
I use Shell Gas because it seems to run better and get better MPG's.
I go about 75% highway, 20% dirt/gravel roads, 5%city.
I ease off the gas pedal, brake easy, only use the A/C in spurts on the highway, use windows in town.
I wish I would have gotten the manual transmission though. I hate how long this auto takes to shift up and down. I wish I could do it myself!
