Pontiac Sunfire Convertible Top Problems
I have a '98 Sunfire Convertible. The bottom flap is off completely from the window. Apparently the dealer tried to "fix" the problem instaed of doing it right. Any ideas on how to repair without having the entire top replaced?
I am having a heck of a time finding someone and my top is loose from the window.
Help please
I hope to find someone in the fall. Thanks for the input and help.
It's a pity we can't post pictures of our cars in this forum.
william
http://asashop.org/
BTW, I have a '96 Sunfire convertible which they are keeping running far longer than I ever expected.
The first is to take the car to a glass shop. They CLAIM to have an adhesive which will re-adhere the fabric to the glass. This may, or may not work, but it's quick and cheap, and worth a try.
Another solution is to go to the dealer and buy (order) the rear window insert. This is the fabric which the glass is attached to, and includes the glass. This insert is attached to the rest of the top, and can easily changed by any top shop. This solution has the advantage of keeping the read heater defroster working.
Another solution is to find a GOOD top shop and have them install an old style flexible rear window. Most shops will tell you that this part doesn't exist, yet there is one installed in my car. The disadvantage there is that you lose the rear window defroster. By the way, my shop installed this rear window insert in about three or four hours. However, this needs to be done on a warm day.
A tip on finding a GOOD top shop. Go in and ask to see their box of staples. The top is attached to strips of wood on the car using staples. A good shop will understand that these staples need to be stainless steel staples. Other shops try to save money by using regular steel staples which rust. One way to find a top shop is to check with other auto upholstery shops. These guys all know each other.
