Thanks Linda
Dealer did a computer upgrade but said they have had problems with these transmissions and said a new one would be about $5000 and that I should consider "dumping this car."
Any thoughts or suggestions? I have it back but have only driven it locally since the computer upgrade. The shifting in the lower gears issue is still there intermittently.
Thanks for any suggestions.
Al
I just took my car in for the wrench light coming on, the car not changing gears however when I turn the car off and restart, it goes away. They told me the code that came back was a P0942 which on the 2005 Ford Freestyles there was a service bulletin stating this was a computer issue. Ford stated that it needs a new hydraulic pressure unit however this part is no longer made therefore needs a refurbished transmission that will cost 5,600-7,000 dollars. I am shocked that you were told only 3,200 for a transmission?? Either way, I keep reading these same issues and seems that they don't really know the source of the problem whether its computer system or a part therefore they just recommend something with no guarantee it will work. Pretty expenisve part to replace to just see if that fixes the problem. Thanks!
I just came here to get some advice from other users. I own a ford freestyle 06 wagon I bought second hand from a private owner. Recently, I have started noticing that the car is not as efficient as it used to be.
2) My main issue is that when on the highway sometimes the car seems to not want to gove over 80km/h however when I pull over and retart the engine, everything seems to work fine. This is happening now more and more often as I use the car more often to commute.
3) Also, when the car in gear and I turn the steering, sometimes the car tries to lunge forward. For example, when I try to park inbetween cars in a busy lot, while manoeuvering the car to park, it simply lunges forward. A few times I have missed hitting other cars.
Can someone tell me what these issues might be ? I have read things about transmission but I honestly cant spend 3000 now on this car having bought it only for a few months ago for about 6.5000.
PLEASE ADVICE
Lets see where do I start, Lets begin with this, I have owned 2 Ford Freestyles in the last year, a 2005 and now currently a 2007 AWD SEL.
I have had problems with both these vehicles and both times transmission, the 2005 started with a lurching forward at any given time when at low drive speed (IE: pulling into park and backing up to get out of parking space.) greatly increased in the heat of the summer with air-conditioner on. Then the noise started from the transmission, I looked at it and tried to hear where the noise was coming from but with no success as it seemed to come from everywhere and a couple locations. So before I even had a chance to bring to ford the Torque converter and gears associated had blew up and caused catastrophic damage to the transmission which required a rebuilt and a $4500.00 bill, after the replacement I still had issues with lurching and lunging forward and was told that i had to replace the Throttle Body Module, at another $905.36, re-programed the computer ( flashed ). I did not have enough time to have tested everything that was done as i was T-boned at an intersection 1 1/2 weeks later that wrote off my car. I was not a happy camper, as not only did I loose my money from the transmission, i have been out of work since November 23,2011 to date. I don't know if I will be able to return i have been suffering from health related issues from the accident and have no time frame to getting better.
With the write off of my 2005 ford freestyle, i needed another vehicle, the girlfriend and i enjoyed this vehicle so much we decided to go ahead and get another freestyle as we liked its all around functionality for what we used it for and that is allot of highway driving to and from the trailer and space. we purchased the 2007 ford freestyle on December 23/2011 and loved it ever since, I realized that we were having the same issues as we did with the 2005 in the summer of 2012 with regards to the lurching and lunging.
I brought my 2007 back to the dealer i bought it from and they informed me of the throttle body issue. I asked if warranty will cover they checked into it for me and said no.
I could not afford a $1000 dollar repair. The lurching had stopped so I decided not do anything at that moment. I had bought some cleaners to see if the throttle body issue would stop or lighten up and it did for the most part. Odd time here and there would i have the issue.
I then started to hear a noise from the time i would start my freestyle until I engaged drive or reverse, the noise would go away even in driving, with a week of hearing this noise i noticed when i would put the car in reverse and move i heard a very loud gear winding noise.
I paid close attention to it, keeping track of things as well, i finally decided to bring into a shop with my after market warranty, it is currently being investigated for transmission issue, the mechanic has suggested to me that he thinks it some kind of a ( plemun gear ?? ) not sure. but he needs to open the transmission and go from there.
I called Ford Canada today, reported issue and was told there is a 1 time customer service satisfaction recall/??.
I have the number for it and was told after the transmission is fixed bring to a ford dealer and this will be taken care care of the following is what Nancy said at ford, they will clean the throttle body and or replace and re-flash the computer. Now i think this might do it but i have my doubts.
Plus this does not fix or help me with the transmission issue as i think the two are directly related, this whole transmission is based on electronic signals sent to it via the computer and throttle body.
My question to anybody that wants to listen and i would also direct to Ford is, if you know the throttle body is causing the electronic lunge forward, on a system that is mechanical, would this not cause early failure in the transmission as its the transmission that is being told what to do by the electronics that are being fed by the computer?????.
I know it seems simple to ask and the question is simple and may not be related but i cant seem to understand why one part fails and its fixed by replacing and re-flashing a computer that controls everything from top to bottom in the car. Its not right, I Believe there is a direct issue with the computer to the transmission because there are more electronics in this CVT transmission than any other, I believe the lurching forward that goes on is not the only issue. I believe that the problems the computer has with the throttle body and the signals it sends to the computer to cause parts within the transmission to prematurely wear and or break. because who knows what else the electronic signal is activated at the wrong time within the transmission.
Sorry if I sounded long winded in this but I believe I have a true and valid point with Ford and ford is hiding more than what they are saying or just fixing as a customer satisfaction. I am not happy with them even though i enjoy there cars and trucks and think they are the better one of the north American dealers and would go back to them with a new purchase if I could afford it.... But I think they need to stand up to this issue and fix both the transmission and computer as I am no computer wizard I do know computers can send more than one signal at a time to cause parts not to function in the right order. Hence causing catastrophic failure in the transmission.
mjbelfiori@rogers.com
I am nonplussed with the faulty transmission in our 2007 Freestyle AWD (CVT). It will cost us $6,100 to repair + $1,700 for the faulty transmission sensor. Since this issue has been found to be typical for this vehicle and this year, I would like you to know we are joining the class action lawsuit against you and buying a Chevy next time. Sincerely, Me.
Law Firm:
http://www.seegerweiss.com/news/seeger_weiss_investigates_cvt_transmission_defec- ts_in_ford_and_mercury_vehicles
Considering that my husband and I were just informed we will have to pay $6000 to replace the transmission on our 2007 Freestyle (by the Ford dealership), we are joining the class action lawsuit. We can neither afford the $6,000 for the transmission nor feel the car is worth that much in repairs. We've already paid $1700 to replace the mechanitions sensor, so we're very unhappy with this latest news.
If anyone wants to know more about this particular class action lawsuit, I've provided the link:
Dianna
Learn the lesson guys do not buy ford there is nothing to be proud of them. pieces of junk left and right or us.
The questions to ask yourself is why to try with your own hard earned money on so cheaply made cars and expect that they are better than most known to be good makes like Toyota and Honda. I am not buying any other car made by ford. Mater of I will not talk to my family member who ever drives a Ford from today.
http://www.seegerweiss.com/news/seeger_weiss_investigates_cvt_transmission_defec- - - ts_in_ford_and_mercury_vehicles
I am very eager to be a part of the fix in this wrong doing that Ford Motor Company has created. I have a 2005 Ford Freestyle that has cooked through its second transmission and has also had the motor replaced as well. I am a working class citizen who makes 50,000 per year. I am by far a rich man but have already taken a beating from a few months after the purchase of my car back in 2006. I replaced the first transmission after about 90,000 miles. I had first experienced a problem while still under warranty and could not get the dealer/manufacturer to fix because the wrench light that was going off and throwing car into "limp" mode would reset itself and not keep the code in the memory bank. To the point mind you of taking a photo of it when it went on and showing dealer and still nothing satisfactory was done. It wasn't til after warranty expired that transmission died all together and paid $2,200 to have a used transmission put in in 2009. 2009 a other problem but this time the throttle body needed to be fixed or recalled a d was done by dealer. I'm seeing now that this function might actually be the result of or adding to the failure of transmission. In 2011 the motor blew and spent another $2,000 getting parts myself and lining up through connections to get this repair done as inexpensively as possible. The tranny just died again and had to purchase a used vehicle for a couple thousand to get me back and forth to work. I paid over $21,000 for the car as a demo with full warranty but have gotten no help in any of this. I still owe on the car and hear it sits in my driveway. Please help, I don't know where to go from here.
Sincerely,
MVE
After multiple trips to the shop, several after driving a few blocks from picking it up, ours has been fixed. Apparently some of the replacement parts are defective (that's the story anyway). But if your at wits-end, AAMCO Transmissions in Fort Collins Colorado became an expert. We paid well (~$6k) to get them educated, but that was close to two years (and ~15,000 miles) ago and we haven't had CVT issues since.
I want to join the class action lawsuit
