Dodge/Plymouth Neon: Real World MPG
I have a 2004 Dodge Neon, it is well maintained and has about 37000 miles on it. I get an average of 28 mpg, and that is all highway. It doesn't matter if I'm going 70 mph, or 80, it is the same...crappy! I've taken it to the dealer, and they say that is the way the vehicle is. Does anyone else have any suggestion or similar stories, I'm wondering if it is like this will all 04' Neon R/T or just mine.
I get 30 in town (never above 40mph, 4.5 miles one way to work), and 36 on the highway.
I found something interesting at that 2.0 engine - it likes higher RPM. Don't lug it, and you get better mileage. The speed limit in town is 25: I keep it in third, and take it easy on the pedal since it reacts so fast.
By the way, my mileage was worse in CA. Now I live in OK where the gas is not oxygenated.
1. AFTER MARKET PULLEYS, LIGHTER AND SMALLER, WHICH HELPS THE ENGINE A WHOLE LOT,
2. LIGHTWEIGHT FLYWEEL. THE STOCK ONE WAY I BELIEVE ANY WERE FROM 15 TO 16 POUNDS, MY GUESS, AND AN AFTER MARKET ONE MADE OF ALUMINUM IS APROX HALF, 7 TO 8.
THE LESS DRAG ON YOUR ENGINE THE MORE POWER YOU HAVE SO NO NEED FOR MORE PEDAL, WHICH IS LESS GAS USED BETTER MILAGE.
EXAMPLE, I PUT UNDERLINE PULLEYS ALONE ON MINE AND WENT FROM 26-28 TO 30-32, AND I TAKE OFF AT 60 AND STOP AT 60. THE PULLEYS' EASY, FLYWHEEL NOT SO EASY, BUT CHEAP POWER MODS AND BETTER MILAGE,
ALSO I CHANGED MY THROTTLE BODY TO AN AFTER MARKET ONE AND THE RESPONSE IS SO MUCH BETTER AND SMOOTHER.
WWW.MODERNPERFORMANCE.COM OUT OF HOUSTON, TX. THEY ARE WHO I GOT THESE THINGS AND IDEAS FROM OTHER NEON OWNERS, CHECK THEM OUT READ THE REVIEWS I WAS SOLD ON IT. HOPE THIS HELPS YOU SOME.
AND NO I HAVE NOT DONE THE FLYWHEEL YET, BUT I DID GAIN MORE POWER AND MILAGE PER GALLON WITH THE PULLEYS AND THROTTLE BODY. AND OTHER BOLT ON MODS, NO TURBO, WENT FROM STOCK 121 HORSE TO 243 HORSE AND AVERAGE 30.5 MPG.
">http://www.cardomain.com/ride/3938661/2003-dodge-neon-r-t-sedan-4d
An underdrive pulley might give you from 4-7 HP increase, but only at the high RPM's. Modernperformance.com sells larger throttle bodies than stock that will give better throttle response because it lets more air in with less pedal travel. So it fools you! But it, too, could give more HP at only the high RPM's if your fuel system can deliver more fuel as well. Let's say maybe 10-12 more HP tops!
I love bench racers!
