Toyota Prius Test Drive - What Do You Think?
                    Have you taken a Prius for a test drive? This is the place to post your thoughts on your experience. Tell us what impressed you, or what left you wanting more.
1) This car had trouble gaining any speed from a stopped position. It was fine after it picked up speed, but I would be afraid to pull out into busy traffic with it. Are they all this way, or could there have been something wrong with our demo model?
2) I kept hearing a high pitched noise from the rear of the car. This would become very annoying on a long trip.
In all fairness, this was an '04 model, but I would hate to order one only to find out these two problems exist on the newer ones as well. I would appreciate any feedback from current owners regarding these or any other issues with the Prius.
Thanks...!
Can't help you on the noise issue. Of all the 2nd gen Prius I've driven, I have never heard such a noise. My advice is to rent one for the weekend. A test drive for 10-15 minutes is not enough for any car.
If you are used to the massive torque feeling of a big truck when you stomp on it to get into traffic the Prius will seem to lack.. but most 4c cars are also in this situation.
kdhspyder
The car is a great commuter car that can haul stuff. But it does have limitations. The noise, as you noticed, is pretty bad. On the highways, depending on the surface, it can be pretty intolerable. There is like no sound insulation on the car. It's also the only car I've owned where the acceleration totally varies. If the battery is green, it's actually pretty fast. Usually the battery is blue, which is 'mostly adequate'. If you go to a drive-thru on a hot day, and have the AC running, when you pull out the battery will be pink, and the car can barely get out of it's own way in this state. The lack of adjustable seats and a tilt steering wheel makes it somewhat hard to get uncomfortable.
But if you want a basic commuter car, and don't mind paying a lot more than a comprable car, the Prius isn't bad.
I think it was the car I came from. My old Jetta was tomb quiet on the highway. With the Prius, I can hear the road and wind. And if there is sound insulation, I don't think there's that much of it.
OK, I'm looking at the Prius because:
1. It's a very efficient design, body wise.
2. It's an electronic car and I'm an electronic tech.
3. I like the looks.
4. I currently own an SUV (Pathfinder) and a sports car (RX-7) and am getting tired of subsidizing the oil companies. Don't get me wrong, they both get pretty good mileage for what they are, it just doesn't come close to "economy car" status.
So on friday I took a Prius for a test drive. Salesman says "I'm pretty busy, here are the keys, here's how it works, have fun...see you in six months (wink)". Woh. Car sales have changed lately, or this is an exceptional dealer (latter I think - Toyota City in Wetaskiwin Alberta).
I was surprised with the power (acceleration). The gadgets are cool (speedo etc). I've got to read the owners manual so I can understand what the car was doing. The only frustrating part was I couldn't tell when the engine was running! I saw 6.5 l/100 km (not really good mileage), but I suppose that will change once it's broken in, and I'm not testing acceleration all the time.
This is a cool car! I'm now selling my RX-7 so I can justify buying another car! Any takers
Power is similar to our Saturn LS1 (With 5 speed). The passenger room is spacious and comfortable.
The hatchback is convenient. Remember that the 16 cu ft is measured from the cargo floor to the roof.
Handling is a "soft" - not real crisp - creates a little uncertainity.
1 week of driving the rental resulted in 47 mpg, mostly at highway / interstate speeds and A/C running (temps in the upper 80's - low 90's) Total mileage about 600 miles. It was interesting how much flucuation in MPG with A/C and winds as low as 12 mph.
This spring drove a Prius that was considering purchasing - on I-70 in rain - wind, @ 75 mph felt twitchy. I decided to hold on purchase, in retrospect - I think the drive by wire steering gives different feel and car stable.
A little concerned about battery disposal costs when car is older (usually drive vehicle to 200K) and reliability of switching gear after 4-6 years of use.
Not purchased yet - considering currently with the $3,150 tax credit. Without credit, hard to justify the capital cost for the hybrid.
The drives were brief, about 7 miles. I took the Standard out first, and drove a bit cautiously. I felt the ICE cut out a couple times, and overall felt good about the ride, noise levels, steering feel, etc. I was not autocrossing of course, but the car came across just fine.
With the Touring, I immediately noticed 'feedback' through the steering wheel, not the sort I was looking for. While not feeling like an out-of-balance condition, there was a definite sensation through the wheel that was not present on the Standard model. I was thinking perhaps the lower profile tires and the shock / spring differences were the cause. In addition, the engine was quite a bit more audible than in the Standard. That one made no sense to me, since the drivetrain is identical in both. I sure doubt Toyota opted to give the Touring a "sporty" sound. The ride was a bit harsher, with a trace of jiggling. I did not mind that, since I enjoy driving. It's just that the Standard model was much smoother.
For the brief identical drives, the Standard reported 44 mpg, while the Touring returned 40. I was probably driving the Touring a bit more briskly. The HID headlights were nice, but not as effective as those in my Mazda Tribute.
Does anyone out there with more time behind the wheel of both think what I experienced in the Touring is normal? Or might there be an issue with that particular car? The dealer does not have any other Tourings for me to try.
The plus you get with the touring is slightly better handling, particualrly in corners. You also have 16" tires, which should give more choises when tire replacement time comes around (15" tires are going out of favour, so aren't available in as many styles/sizes). Further, the OEM 16" tires are much better than the 15" Goodyear Integrities the standard model comes with.
for the receiver hitch.
I use it mainly for a bike rack. Works fine.
In Western Los Angeles County it is $3.25/gal for 87 Oct regular. It has been well over $3.00 for over a month.
NOW the driving season begins. It'll probably stay well over $3.00 in this area at least through Summer--maybe permanently.
That's one reason we bought 2 of the Cars.
Carl
Reading the comments on this thread however will make me think twice before buying one.
However, I have heard of two issues that might dissuade me from purchasing this car, and I would like current Prius owners to comment on their own experiences.
1. Slow acceleration from 40 MPH to 65 MPH, i.e., accelerating to "highway speed."
2. Loss of traction in snow or gravel causes onboard computer to incorrectly think car is in idle and shut down electric power to steering wheel and brakes.
Paul
For example, a Corolla, Yaris, Civic, or Fit will be cheaper to operate over that term than a Prius. I'm not sure what the median purchase price is for a Prius, but with the other alternatives, one is already starting with a $8 to $10K advantage over a Prius in purchase price. You'd have to buy a lot of gas to make up for that initial price differential. There's more than the price of gasoline when it comes to calculating total cost of operation of a vehicle.
I live in the mountains of Colorado and have two problems.
1. It's not a 4WD so when heavy snow falls, I prefer to use my 4WD Subaru Outback if it's not being used by my wife. If she is using it, I use the Prius which has Blizak snow tires, and have never had a problem.
2. On long, straight, steep mountain passes, like on I-70 to Denver, the battery boost runs out after 5 minutes or so. You are then running only on the ICE gasoline engine which is about half the total power so you can't accelerate past 75-80 or keep up with trucks going that fast. It is worst in very cold weather, with deep snow on the road, and strong head winds. That "perfect storm" has happened to me only once in 3 years. Otherwise the car is fine. A larger engine or "bigger" battery would solve that problem but be less efficient the rest of the time. A turbo booster would probably be the perfect solution.
Another cheaper alternative is a Camry LE. Certainly as comfortable, and 32 to 34MPG on the highway, and still cheaper if you watch the option list. The Prius is a great car, and a technological tour de force, but not something I would purchase. This is somewhat a paradox, as I'm an engineer, but one who believes in the K.I.S.S theory of design (Keep It Simple, Stupid).
"32-34"MPG...thats quite adequate,but the city mileage IMO doesn't approach what's on the sticker.My car is rated 24 cty,but I've gotten as low as 12.2 ,so to me thats where you really save with a hybrid,more than on the highway.Consumer Reports rates virtually all the cars of the size of a Camry,at real world mileage ,city,at around 15 MPG.I'm speaking of the 4 cylinder models now,not the sixes.
BTW we have several friends who have Prius,and in both cases put well 100K miles on them with no problems,so I think the technology is getting quite mature.
But since you raised it, I'd love a car for 13K for my teenage son that has a good safety record and predictable handling. Your suggestions are....?
I hope the moderator doesn't yell at me about posting this on the Prius thread,but I'm just answering your question.
In 2007, they are not asking for mark ups. However, there is more road noise and engine noise compared to my 10yo Camry (4cyl). I still get mileage over 33 driving between Dallas and Houston averaging 75mph and 27-28 in the city. Going to 40/45 won't save me much on gas. The Prius also feels flimsy - like the hood/dash/fender - everything is made of cheap plastic to make the vehicle lightweight.
I remember - when I bought the Camry, the dealer asked me to lift the hood - "See, how heavy it is? This is how crumple zones work properly, and what saves you in a collision and gets the vehicle stability". The Prius dealer also told me to lift the hood - "See, how light it is? This is the new technology that helps with the great mileage". Now I don't know which is better, having a heavy hood or a light hood! :confuse:
It's great technology, the dials and gadgets are fun to look at, but I could get into an accident trying to look at the shift of power between different sources and not focusing on the road. Headroom, legroom, hip room, shoulder room - every room is more than sufficient for me. The start button and the 3" shifter on dash are unique, too. The dash has a futuristic look to it, too. The big digit display deep in the dash (speedometer) could be a distraction, and I think the display size for the other meters should be comparable (they are much smaller) so you dont have to squint. The rearview camera is a nice feature while backing up.
An aside (buying decisions are influenced by dealer reputation, too). A colleague of mine drove her Prius on a gravel road, and something went wrong with the suspension, within the warranty period. The dealer wouldn't recognize the problem, and she had a hard time with Toyota Customer Service to get the problem fixed. She will not recommend that dealership to anybody. Now we drive 12 more miles to the next dealership. :mad:
I wish some of the more popular, resale-able and reliable cars (like Camry/Accord/Civic) offered the options of Xenon headlight and backup camera, features useful for driving, as opposed to sunroof, designer wheels and surround sound systems. If they did, I would not even consider the Prius.
Bottom line - If I spend that much money on options for creature comforts like leather seats, sunroof, Xenon headlamps, and not save substantially on gas, the Lexus ES would be a better upgrade for myself. :shades:
I'll guess which one has a heavy or light hood. I know more than the salesmen anywho. You know me!
DrFill
On that note: before you buy, check out what your car ins is going to be for a 16 yr old boy that has to have collision and comprehensive on it. You may quickly decide that an older car that you can pay for in full and carry liability only on is the way to go.
Good luck and best wishes
Peggy
So the bulk of the costs are to cover the damage he could cause to other people and property.
Peggy
2. Loss of traction in snow or gravel causes onboard computer to incorrectly think car is in idle and shut down electric power to steering wheel and brakes."
Can't speak to number 1.
Number 2 was a problem but was fixed in the 2007 model (as I recall - might have been the 2006). The problem was the traction control could not be disabled, and it was protecting the electric engine by shutting the car down instead of allowing a "rocking" technique.
2. There was a software problem that sounds like what you describe. It got a lot of publicity, thanks to GM and Ford PR firms. The fix was already being implemented when the [non-permissible content removed] hit the fan. It never happened to me and my computer had been updated a few weeks before as part of a group of TSBs.
I never saw it from a GM or Ford source. It was reported by someone on this site.
My squawks
Hence, my clarification on the source of my information (not from the press).
The ride was smooth to me on the short circuit in the Tysons Corner area of Virginia. Acceleration for the way I drive was up to par for my needs. More will be known when I rent one for the weekend perhaps.
The things I liked about my short time with the 2011 Prius was of course the MPG, dooh! The ride was very comfortable, maybe more so than my Subaru 2003 Baja - which was always nice on long trips. But it seemed smoother and of course quieter. The front cabin was comfortable, rear seat area seems it would work for trips with friends. What won me over is the trunk space.
Seems to be more than enough space for me and my better half for any road trips - without the need to fold down the rear seats. This has been a concern at times in my Baja and their Yaris in road trips. We never liked exposing our luggage. The benefit of the fold down seats will help in some cases with the potential loss of the bed of the Baja.
I am torn though - even as I plan on a rental of the Prius - just wish there was a car. Another factor as I look towards buying a new car is one that I don't want it to look too dated 7 to 10 years out. Along with reliability, so far the Baja and Prius fit the build. The Corolla doesn't stand the test of time IMO - nor does it ride.
In the end MPG may rule the heart over the mind...
