>>My gas mileage has been right around 50 with combined city/highway driving. I do notice that I take it easier on the peddle and watch the screen to see how to maximize fuel economy.>>
I would blame the driver, except for the fact that I just did the comparison road test. The only variable was the car!
1. Cruise control that "resumes" only about 25% of the time, requires accelerating up to previous speed and re-setting. Totally defeats purpose of cruise and "resume".
THIS IS A TOYOTA THING. MY SIENNA DOES THE SAM THING. IT SAYS SOMETHING ABOUT IT IN THE MANUAL, BUT ONCE BELOW 25 MPH, YOU HAVE TO RESET IT AGAIN. IT WILL NOT RESUME.
I agree with what you are describing below 25 mph. Every car I've owned for the past 30 years has had cruise control that works that way below 25-30. But...on my new Prius, this happens about 75% of the time, at well above 35 mph (45, 50, 55, 65, 70).
2. Hatch lid that requires "slamming" to get Smart Key to lock car (10 second alarm sounds if not slammed hard enough).
AN ADJUSTMENT MAY BE NEEDED. MINE SOMETIMES LOOKS SHUT, BUT WHEN YOU PULL ON IT, IT IS NOT FULLY SHUT. I CAN USUALLY GET IT TO SHUT WITH A THUD.
Again, in the dealer's parking lot, the sale rep pulled up on the hatch lid himself, and both times, it WAS shut. I figured out the "slam it shut" solution after I got the car home. I was out there at midnight, trying to get the car locked for the night, and stumbled across the fix, probably because bey then I was so frustrated, I just slammed it!
3. When stopped at light, intermittent "jerking" forward. Gas engine stays running many times at full stop.
MINE JERKS, BUT WATCHING THE READ OUT, IT APPEARS THAT IT IS ENGINE TURNING OFF.
It never jerks when the engine is off, or starting up. My concern is that the engine is still running at a full stop (= poorer mpg in the city), and that is when the car lurches forward. Poor mpg and a safety issue I would think!
4. A/C never stops running, even when on Auto and temperature is set quite high (70-71 degrees). The only way to get thermostatic control is to set interior temp at 75-76 degrees or higher. Sorta defeats the purpose of A/C.
THIS IS ANOTHER UNIQUE THING I HAVE NOTICED. YOU HAVE AUTO CLIMATE CONTROL REGARDLESS IF THE AC IS ON (CLIMATE BUTTON ON DASH AND THEN THE AC IS LIT GREEN ON THE SCREEN). EVEN IF YOU TURN THE AC OFF (GREEN LIGHT OFF), IT WILL STILL LOOK LIKE THE AC IS ON VIA THE DASHBOARD. ODD. MY ACURA HAD A SIMILAR THING. WHEN YOU TURN THE AC OFF BUT THE DASH LIGHT REMAINS LIT, THE SYSTEM IS IN AUTO MODE AND WILL TURN UP OR DOWN THE FAN BASED ON THE TEMP THAT IT IS SET TOO. IF YOU CHANGE THE FAN SPEED DIRECTLY, THE AC LIGHT ON THE DASH WILL GO OUT.
I'll have a look at the screen next time in the car. Every car I've owned before with auto A/C, you set the temp at something reasonable (70 seems reasonable here in NC) and when the interior temp gets down to 70, the fans slows down, and the system maintains the desired temp. The only way I can get this A/C to do that is to set the temp to at least 75 degrees. That is ridiculous. My house is set at 70, I should be able to drive in my new car at 70 degrees too! My lady friend has a 2006 Avalon, and her A/C shuts down at the desired temp and she sets hers to 68. So...it's not a "Toyota thing" if they can get it right in the Camry and Avalons.
5. Steering wheel is about 25% off to the right when driving in a straight line.
YEP MINE TOO.
I'd say they have a QC problem then.
6. Battery has yet to ever be "full" even after long drive. Highest charge seems to be about 75%.
NEVER GOTTEN MINE TO FULL CHARGE EITHER. FIGURE I WILL WHEN I CRUISE THE BLUE RIDGE PARKWAY DOWNHILL.
LOL
9. I'm presuming this is an intentional design feature, but having the low beams only light up to a height of about 3 feet is dangerous, IMHO. Last night, I just about ran over a kid on a bicycle, riding along the side of the street. Shouldn't have to drive with brights on in town, just to be safe.
WEIRD. THE HIDS HAVE TO BE SET TO SPEC AND IF YOU ARE NEW TO THEM, THEY TAKE A BIT TO GET USE TO. YOU WILL SEE A LINE WHERE THEY ILLUMINATE AND THEN THEY DON'T. TRY DRIVING WITH YOUR FOGS ON. THEY WILL HELP. YOU CAN HAVE THE DEALER OR A LOCAL GARAGE CHECK THEM FOR YOU. SIMPLE TO ADJUST. BEWARE THAT IF YOU CHANGE THEM, AND YOU GET BRIGHTED BY CARS IN THE OPPOSITE LANE, YOU'VE SET THEM TOO HIGH!!
I suppose I'll get used to them!
Thanks again.
Call them to make sure they don't sell the Buick before you get there.>>
stevegold,
They've already sold it! Why not - it was in great shape, fully loaded, well-maintained, and got pretty good mpg!!
Friend has 2007 Prius, 6 months old, averages 52.5 mpg, has never had any problem with car, only service has been oil changes.
This afternoon, I drove his car and my new car on the same route, same time of day, same weather conditions, same speeds, same driver. His car? 48.7 mpg, my car? 32.3 mpg. Really big Hmmmmmm...
Your friend's values are almost exactly my own ( 52 mpg on the flat OBX and Hampton Roads VA region ). The difference you note between the two vehicles is unusual since I've driven about 300+ over the last 6 year and they are amazingly accurate from vehicle to vehicle IMO. There could be a setting wrong. It should be looked at. Do I understand that you're in western NC?
Also, so far my 2 day old car has:
This is intentional on all Toyota's. There is a 25 mph window below your set speed. When you brake and slow outside this window the system is still on it just loses the memory of your setting. I surmise that the reason is safety. If you had set it at 75 and slowed to 5 then hit resume ( by accident? ) the vehicle could go rocketing off up to 75.
I've never experienced this. A firm closing is needed but not a slam. By locking do you mean 'catching' rather than being ajar? BTW the SKS will not lock it until you've pressed the black button on the outside. Hope this helps.
Yes occasionally the vehicle will shudder just after stopping. The design of the system is that the gas engine turns on and off depending on the relative charge on the battery. The master computer is always checking to see if the battery needs a boost. The ICE will run almost continuously for the first 5-7 min as it brings the cat converter and fluids up to operating temp. In winter it runs more often to heat the cabin as well. This is a key reason for lesser fuel economy in winter. It doesn't shut off as frequently.
Yes and No on this one. 70-71 is freezing for me so I've normally got it set at 75 or higher. When it's 90+ like now 75 is frigid and I've got to move it up to 78. You can turn off the Auto AC on the steering wheel or manually on the screen. I just move the temp up and down to do it. This is also a design of all Toyota's with auto climate control.
It's an alignment that's needed.
Again this is a failure of the sales staff to explain how the HSD works. You should never reach 'full' charge and you should never be below abt 30%. This is how the HSD protects the NiMH batteries from wearing out. They just cycle back and forth between 40-80% of charge. It's how it should work.
7. Many times, gas engine runs when in reverse. Owner's manual (yes, I read them front-to-back!) says on page 10 that "When starting or backing up, etc., the vehicle runs on electric power from hybrid battery...". Not this one!
This goes to the question of the relative charge on the battery as noted above. It has nothing to do with driving the vehicle. Again a lack of information given to you.
8. Car is very noisy on the road. Lots of wind noise, and sounds like grinding brakes on an old jalopy while driving down the street.
I haven't noticed any wind noise but the tires are very very noisy on the road. The Goodyears that are OEM's are very run of the mill and are found on most Corolla's, Civics and other small/medium autos. Most owners drop them at the first opportunity.
With the HID's you have I think that you're correct.
Called dealership this afternoon after the road test comparison with friend's car, and explained displeasure. His comment was "Hmmm...we have never had a complaint about a Prius before. Bring it back here and we'll take a look". Another 7-8 hour drive, plus sitting around dealership experience. Hotel stay too???
Reasons for buying the Prius? Mileage (ha, ha), quality of build (double ha, ha), peace of mind and reliability (not so far!) of brand new car.
If we lived closer I'd like to help but the store was right some of those things should be looked at. There are no other Toyota stores closer than 7 hours from you? There's 5 within 90 min of us on the OBX and 10 more within 3 hours...and I live 3 miles out in the middle of the Atlantic :surprise: :shades: literally
#3. Vehicle wants to move and engine wants to run when stopped.
a. The brake lamp switch may need adjusting. It senses when you want to "not move" and "pauses" the system. If you release the brake very slowly, you should see the electric "automatic creep simulation" begin - that is, you see energy on the arrows start to flow from the battery to the electric motor. If this happens when you are stopped with your foot on the brake the switch may be out of adjustment. You should be able to shut this "creep" off with the brake pedal. Try pressing a little harder once you are stopped. It's a two-stage master cylinder, first using regenerative braking, then switching to hydraulic. It has a little more travel than most people are used to.
b. The engine (ICE) will run to keep itself and the cat warm, and sometimes to build up the state of charge (SOC).
4. Climate control seems to run all the time.
Be aware this is an electric A/C pump and is variable speed. It will try to run more than a mechanical one for efficiency reasons. Even though it seems to run too much it doesn't use a lot of energy. Also, cabin air is used to cool the "traction battery", so it's a good idea to keep the cabin at a reasonable temperature. Now if the temperature seems to be out of control, then you have a complaint.
6. Battery state of charge (SOC) indication is actually 80% charged with all bars lit (green), and 40% charged with no bars lit (last few are red). Mine usually stays blue, with three empty bars at the top, but can vary. So far (just over a week) I've seen it down to 1/2 (still blue) and last night it got to only one bar not lit and green. The system is programmed to keep the SOC "in the middle" to leave some room in case you brake a lot or descend a long hill. It is also programmed to not allow the SOC to vary too much. This extends the life of the battery.
8. Car is noisy on the road.
Mine is quite quiet. I'm running 40 PSI front, 38 PSI rear. There have been a few reports of brakes out of adjustment (rear). Also, maybe your rear hatch IS out of adjustment, because I get almost no wind noise unless I open a window.
You have some concerns certainly and I also think that you were not given a proper delivery by the sales staff.
Quite possible. Bought and paid for the car over the phone since they were so hard to find in the #6 package and color I wanted. Sales rep met me the first time when I drove to Raleigh to pick up the car the next day. I was out of there in an hour, spent most of my time with the finance/warranty guy. I just wanted to write them a check and spend more time getting advice, but they seemed to be very much "production line".
I hope they can find the setting that needs to be changed! Not western NC - west of Charlotte. The 7-8 hour drive is total drive time there and back to get them to look at it.
As I have said to previous posters, I understand the need for the memory to cancel below a certain level. In this case, it is at higher speeds than the minimum, and it will not resume even if the speed has dropped by only 3-4 mph. In other words, the cruise is set at, say 55 mph, I put the brakes on which cuts off the cruise, I then push the lever up to "resume" at 53 mph, and it will not resume. These parameters are well within the normal operation of the cruise control on any car. It's just that THIS car doesn't respond properly.
I'll try to describe the problem better: I get out of the car with the SKS fob in my pocket, I shut the driver's door, walk to the back of the car, lift the lid to get something out of the back, close the lid to the point that pulling up on it confirms that it is closed. At that point, I press the black button to lock all of the doors, and the 10 second alarm sounds, indicating that "one of the doors is open", and the car cannot be locked. The fix is to reopen the lid, and really slam it down. At that point, the lid is closed and I can lock the car with the black button. That part of the system works fine, the problem is that you shouldn't have to slam the lid down with both hands on a new car to get the system to "see" that the lid is actually closed.
I guess my point is that the purpose of auto control is to allow the driver to set the interior temp at a certain level and then ignore it. If the temp goes up, the system kicks in, when the temp is at the desired level, the system cuts off. Mine, on auto, operates the same way as it does on manual. It does not automatically monitor and operate. I can get the fan to slow down by taking the auto off and doing it manually. But...I paid for auto A/C, and I think I'm justified in wanting auto A/C in return. If I wanted to operate it manually, why have an auto feature?
Thanks for the advice. My concern was that the battery indicator very quickly drops to one bar after I start driving. The one thing the sales rep made sure I understood (told me 3 times, and asked each time if I understood - thought I was going to have to sign an affidavit to that effect!) was that I had to be very careful to not deplete the batteries, as it was a $5000 fix, not covered by the warranty or the extended warranty. So...I'm watching the indicator carefully, and notice that the batteries deplete rapidly while underway. My understanding of the system is that it charges while driving, either through braking or the gas engine kicking in. This does not seem to happen. At most, I get three bars after driving for an hour or so.
I haven't noticed any wind noise but the tires are very very noisy on the road. The Goodyears that are OEM's are very run of the mill and are found on most Corolla's, Civics and other small/medium autos. Most owners drop them at the first opportunity. Wait until you over inflate them like many do to 42/40 psi then it's like running on wooden wheels. But it does help your FE a little.
There is significant tire noise, but there is also a noise like "grinding brakes" while I'm driving. By the way, speaking of tires, do you really have to take the car to a Toyota dealer to get new tires? The owner's manual is quite specific about this, due to the tire pressure sensors.
There are 4 in the Charlotte area, and one in the town I live in (with a very poor reputation for both sales and service), with three more withi
First, MPG -- sorry, but I gotta ask since no one else has: are you absolutely sure that you're not accidentally putting the car in "B" with the transmission? Of course you're not, sorry I mentioned it. As with most folks, now that the weather has warmed, we're getting in the low 50s.
#1, I noticed this as well on our recent, first road trip and concluded that if you brake at any point during your "cancel" of cruise control you've killed your previous setting; however, if you release your cruise control and coast, then hit "resume" you will, in fact, resume. I've never had a car since the implementation of cruise control (Accord, Grand Cherokee, Volvo, Civic, Prius) that resumed below 25mph.
#2, Smart Key is great -- it went from the "I don't really care" package item to "I gotta have this on every car I get in the future". There's obviously something that needs adjustment in yours.
#4, Have you owned another vehicle with modern climate control? Just because the AC light is on doesn't mean the compressor is running. Besides, unlike most cars it doesn't draw power directly from the ICE when it does run, as it does on the previous generation of Prius.
#7, An excellent article how about what happens and when with the engine(s):
http://prius.ecrostech.com/original/Understanding/WhatsGoingOnAsIDrive.htm
#8, Again, you've got problems. Ours is as quiet as our Volvo sedan -- which is church-like.
Good luck with resolving your issues. As far as I'm concerned we'd have two Priuses if it didn't snow 240 inches a year where live.
Your explanation of the battery charge indicator was excellent.
Just drive normally and it takes care of itself. Even when full (green bars) the battery represents less than 5 minutes of driving. Except when in reverse, almost all the power comes from the ICE. The battery is there to provide a quick, big power boost, to pull away from a traffic light, enter a highway, pass another car on the highway, climb a short hill etc. I think it works perfectly (as designed) except on a very long, straight, steep climb when the battery boost simply runs out. The ICE will then do the job alone but your speed is limited to 60-65mph. A bigger battery would take up more space and cost too much to drag around the other 98% of the time. I think they got it just right for 98% of the drivers. (A turbo would help with this problem without a big penalty when not needed.)
LOL, yes, I'm sure I have it in "D". I actually check that every time, since I'm sure in "B" there is some degradation of mpg.
There's "cancel" and there's "resume". I've had cruise control in every car since 1970, and they all operate the same way, regardless of manufacturer, except this particular car.
It is nice, and I like it a lot. The problem actually seems to be with the hatch lid. Perhaps there is a sensor that needs to be adjusted.
Like cruise control, every car I have owned since the mid-70's has had "modern" A/C with the auto feature. Again, I don't believe after thirty years, and at least 15 cars with this feature, I have suddenly forgotten how to use it. :>)) It is something with just this car.
I'm convinced that I just got a lemon car. Too many gremlins with features that should be no-brainers, and features with which I am very familiar. The real acid test came with the "road test comparison" with my friend's Prius where the only variable was the car. I used to be a test pilot, so I am very familiar with using and maintaining parameters in a situation, and keeping very good records of performance against those criteria.
The unfortunate part of this is that Toyota is selling the Prius as fast as they can build them, so giving Prius customers satisfaction is probably way down on their list.
Yesterday, the local Toyota dealer offered to take my 315 mile Prius, fully loaded, in trade for a demo Camry hybrid without the Nav package, and cloth seats. They only wanted my $31K Prius and almost $3000. Very nice of them! Pretty expensive three days of driving!
The dealer who told you that fully discharging the battery and damaging it needs to be better informed. The "traction battery" has a 100,000 mi replacement warranty (more in some states). NO MATTER WHAT! This is because you can not control the charge/discharge of that battery. You can influence it somewhat, but you really can't control it. Now, if you start modifying the system the warranty may be voided. Perhaps the dealer was talking about the 12V battery and wasn't clear enough about that - but it's "only" $250 to replace.
I just occurred to me, you -are- turning off the system when you park, aren't you? The sequence goes:
1. Park the car.
2. With foot on brake pedal, press down the e-brake pedal. You should see the parking brake symbol light up on the dash.
3. Press the "P" button to place the HSD system in "park". You should see the transmission select indicator go to "P".
4. Press the "On/Off" button on the dash. All lights on the dash should extinguish. Transmission select indicator is usually last to go out. Eventually the red light will begin flashing to indicate the immobilizer is functioning. This may not happen if the FOB is in the car. Also, if the FOB is seen by the car (inside only I think) the two green LEDs on the FOB slot in the dash will be illuminated.
All interior lights MUST go out after about 30 sec. This is very important. If they do not go out you could fully discharge the 12V battery overnight. You would then be unable to start the car, as it is necessary to power up the electronics.
I would like the cruise control to work as it should i.e. set the cruise at 55 mph, put the brakes on to slow for traffic, slow down to 53 mph, push the wand up to "resume", and have the cruise automatically bring the speed back up to 55. That is how it is supposed to work, and I don't think it's asking too much to have it work properly in a car three days old.
1. Park the car.
4. Press the "On/Off" button on the dash. All interior lights MUST go out after about 30 sec. This is very important. If they do not go out you could fully discharge the 12V battery overnight. You would then be unable to start the car, as it is necessary to power up the electronics.
Yes, I am putting the car in "park" with the "P" button, all lights go off. The owner's manual (I always read them cover to cover) states on page 13 "When parking, be sure to put the hybrid transaxle in "P"...". The issue is not with the 12V battery, it is that the big batteries discharge after I start driving. Nothing to do with powering up the electronics.
Appreciate your comments!
However, the primary reason I bought this Prius was to achieve the mpg figures quoted by friends who already own one. The "leadfoot" of that group gets only an average mpg of 48.7, while the rest enjoy 51+ mpg. I am getting 34.5 as of this morning, but when i drive my friend's Prius, I can easily get 48-49.
The car I traded was a beautiful ride (better than the Prius in many ways)and got 31-32 mpg. There was no need to switch to a new car, other than the mpg increase and to a great extent, the "green" aspect of the hybrid.
So...putting all of the other service/malfunction issues to one side for now, does anyone on this list have personal knowledge of purchasing a Prius that did not achieve very good mileage, but the service people were able to do something to the car to get the mpg up where it should be? I would feel a lot better about getting a lemon in other aspects, if I could at least get the great mileage everyone else attests to. Please, someone, give me hope!!
I just went out and tried to duplicate your explanation and found it happened as well. I opened the hatch and just let it drop closed with no pressure...then tried to lock it. It's the same as you described. The I opened it and gave it a little push with two fingers and it closed tight.
It doesn't have an electronic lock like the 4Runner hatch or GM trunks ( Buick? ). It's a mechanical lock.
4 Auto climate..
Again I think this is a characdteristic of Toyota's systems. When the temp becomes comfortable I just turn down the fan manually say the 2nd setting and it just keeps the air flowing.
6 Battery.
Yes they were smart to warn you about driving just on the traction battery alone. However it's very hard to do this. Very hard. Just about the only way you can do it is by running your gas tank to dry - then running on battery/electric alone. If there is a risk of running on battery only you'll know about it right away. All the warning lights come on like it was Christmas and the vehicle goes to reduced power.
Having only 3 bars after an hour's driving is very very weird. It does fluctuate up and down but normally after 30 min or so I've got 7-8 bars.
The batteries charge 3 ways actually.
..Regen braking; ( the little Prius icons on the screen )
..the ICE splits its output while cruising, half the output going to drive the wheels and half going to charge the battery
..when you let your foot off the pedal you'll see the arrows go to GREEN and reverse from the wheels through the motor/generator to charge the battery. The front wheels are capturing the stored kinetic energy of the vehicle as it decelerates driving the generator.
Tires...
No you don't have to take your vehicle to a Toyota store to have the tires changed. However you should go to a knowledgeable place that understands the new technology in the tire sensors. One area that is a problem is changing the wheels. From our experience the new rims never seat the sensors as well as the OEM rims. This sets off the warning lights all the time. The tires themselves shouldn't matter.
1) don't crawl up to speed from a dead stop trying to conserve gas by driving on the e-motor. This uses a lot of battery power and keeps the relative charge low. Accelerate normally, even quickly, up to the legal speed or speed of traffic and then let up. ( No one ever gets off a stop light faster than I do in this Prius ).
When up to cruising speed let off the pedal and glide. If you are below 41 mph you will induce the ICE to turn off completely. If you are at 41 mph and faster the ICE will go to 'idle' at about 950 rpms.
When cruising keep a light constant 'feathery' touch on the pedal to maintain speed.
Anticipate. This is a huge benefit because when you can see that you have to slow down or stop up ahead letting off the pedal as early as possible turns the ICE off and you glide not using any fuel....sometimes for a loooonnngg time.
Avoid short trips if possible. This is the single biggest killer of FE other than towing something. You can lose up to 20% of your 'normal' fuel economy if your trips are less than 10 min long.
Thanks for all of the advice. I'll try some of your techniques, especially on the pulling away from a light bit. Guess I'll have to be sure that no one beats me away either!
As I mentioned in a previous post, I'm sure a lot of the problems with my car can be addressed at the service dept. However, I'm not very hopeful that I can gain 20 mpg more by slightly altering my driving style in town. But, I'll give it the old college try!
I really like the car in most respects, but I HAVE to see somewhere closer to other folks in the mileage department before I'll be a happy camper.
Thanks again.
John
I just got back from a road trip to Norman OK. I averaged 53mpg for the entire trip there and back, nearly 700 miles.
Some points....
1. Cruise control.... seems to be very efficient at maintaining road speed, however at the cost of mpg.. It did not seem to drop tone on the CVT. I flipped it of and was able to maintain road-speed 70mph quite comfortably... again it is a feather touch on the "gas" that is needed.
2. Seats.... quite comfotable, but had to readjust posture several times... (I think it's called numb bum syndrome).
3. Navigation system.... seems very accurate, found everywhere I wanted to go (just remember to changed the map zone, if going out of your current map zone).
4. Audio System... 6 disc changer fantastic.... I stuffed mine with MP3's on CD....
5. A/C.... again excellent job at getting the cooling done.... but after a while had to make a manual adjustment, just so I didn't feel I was in a freezer..... It does get very cold...
All in all a good trip... first real long one out of town...
I would thoroughly recommend taking a long trip to anyone.. you will be pleasently suprised.
Do you need to replace discs when you drive across the border of a zone or something?
The Toyota/Lexus ( and maybe Honda/Acura ) system divides N America into different geographical zones. The vehicle will always be triangulated but if you want addresses then you have to choose the zone where that address is located.
There's a Van Ness Ave in San Francisco and one in Pompton Lakes, NJ. In choosing a destination I always suggest going from the 'macro' to the 'micro'. Start with the Zone, Enter City, Enter Street, Enter Number.
I think you and the car will definitely need more than 3 days to get on the same page. I thought you had the car a couple of months the way you were carrying on. :confuse:
Maybe some conversations with your friends who have mastered a Prius would be in order, before damning the machine as inferior to your last ride.
It's not a light switch. You will have to be more lenient to get big numbers. It may take a couple of weeks, but you will find it's "Happy Places", and will drive accordingly.
So Love it, and it will love you back. Just ask someone who owns one! Good luck.
DrFill
Thanks for your comments.
Not sure if you have had a chance to read all of my posts, but my original post concerned a number of defects that should not arise in a car one day old. Any car manufacturer (even Toyota) can have a bad day and produce a lemon or two. I was trying to find out from other Prius owners if they had similar problems, or if it could be operator error. I do not think that my expectations were too high. It is not too much to ask for a good quality vehicle in return for writing a check for said vehicle. I think it's called good faith. Indeed, if I HAD owned the car a few months, I could probably expect a few service problems, but in a brand new car??
Also, the last thing I wanted to do was blame the manufacturer for what could be operator error/inexperience, so I went to the pool of owners. Many gave me good ideas and advice about the differences between the Prius and other vehicles.
Again, following ALL of my posts would reveal that I have had many conversations with many Prius owners, both prior to, and after buying mine. Their experiences were much more pleasant than mine, from a quality of build (NO service problems in up to 18 months) to high mpg right from the beginning (even allowing for a learning curve with the new technology).
I agree that it is not a light switch. But...(and herein lies the problem), as far as my most important reason for making the switch to the Prius (high mpg), in one of my previous posts, I related that I did a "road test comparison" with a friend's Prius specifically to determine if it was ME and not the car. Identical conditions with the only variable being the car I was driving, mine vs. my friend's. While I would probably be able to improve the mpg in his car even further with more experience and driver seat time, I was able to instantly go from 32-34 mpg in my new car to 48+ mpg in his Prius. It didn't take a couple of weeks, actually a couple of minutes to get out of my car and into his! He routinely gets 52+ average, and I would hope that, with more experience with the technology, I could get over 50 mpg in HIS car too.
Today, I'm going to do a reverse test, something I had not considered earlier. I'm going to repeat the road test comparison, but HE will be driving MY car. I really, really hope he can instantly achieve close to 50 mpg with my car, since he has been driving his for over 6 months. I want the problem to be my inexperience with the technology.
So, drfill, I hope that you can see that I am trying my best to give credit to Toyota and the Prius and take as much of the blame myself for the service problems and the poor mpg. The last thing I want to do is admit that I made a mistake getting this car. In fact in post #321, I asked anyone to give me hope that I made a good decision. Cross your fingers for me, please!
Thanks again for your comments.
http://www.autoblog.com/2007/06/25/toyota-set-to-rectify-the-poor-dealer-experience/
Oh, and the trip cost me 1/3 as much as the anti-Prius (my previous 2001 Pathfinder). I'm currently at an overall average of 4.9 l/100 km, or 56 MPG imperial, or 48 MPG US. I don't pulse and glide, I just drive, carefully, at or slightly above the speed limit.
What really sold me on the Prius was the efficient body design. I carried just as much stuff as I used to with the Pathfinder. The Prius has a little less room, but it's more adaptable, and easier to reconfigure the space.
Love the "Smart Key System", the built in Bluetooth, and the technology in the car. I added my amateur radio, and will probably add a Garmin Nuvi 650 soon.
I really love the nimbleness of this car - coming home from the airport in Edmonton, there was a serious accident just inside the city. Main road in was blocked, and I was in the third lane from the right (of five). I was able to turn right in one car length, squeeze through the cars to the curb lane and turn right off the blocked road to take another route. Couldn't do that with the Pathfinder!
Maybe something like a wedge shaped cushion on the seat bottom?
Then I suppose you could get a forearm/elbow pad to provide comfort and protection from the concrete-hard center armrest that will otherwise leave you sore and bruised on an extended road trip.
Maybe a sheepskin cover would be enough padding for the center armrest, but it looks like it would get filthy pretty fast.
I have to take issue with Toyota about local gas mileage being 60 MPG in the city. If you only make short trips where the engine temperature is not getting up to operating temperatures (the first 10-15 miles) and especially in heavy traffic, the gas mileage is about 40 MPG. The only reasonable way to get 60 MPG is in light traffic where one quickly speeds up and coasts most of the time.
As far as comfort is concerned, my Lexus RX330 is much, much more comfortable, contrary to what many Prius owners tout. The seats in the Prius leave a lot to be desired, as compared to my Lexus. Comparing a Prius to a SUV or a truck is like comparing apples to oranges anyway. The Prius is made for great gas mileage. A SUV or truck is made for hauling/towing and country/off-road driving (except for city-slickers who buy for a "status-symbol"). I dare one to put a trailer hitch on a Prius and haul a 2000 pound bull. It may happen but it won't be pretty. I only bought the Prius for great gas mileage, nothing else. We will still will take our vacations and haul our four grand-children around in my Lexus. I'm glad I got option 6 with the leather seats, navigation control, and JBL stereo system. It brings the creature comforts up a little.
I am fully supportive of those that buy the Prius to save money on gas; however, those that buy it for environmental concerns do not get my sympathy. Considering that 40,000 people are killed each year in car accidents, the Prius is not the safest vehicle in a serious accident. My suggestion is let the oil companies go tax free and drill as much oil as possible so the public can have cheap gas. Then they can demand and buy larger and safer vehicles, like ones with turbine engines, and we can build bigger and better interstate roadways. I mean, really, the safest vehicle on the road is a semi with a turbo-diesel engine. Everyone should get one.
As far as blaming Toyota for the mileage rating, again, people are sure uninformed about this. It's an EPA mandated test, using EPA methods, and is required that manufacturers do it the way it's specified and report the results they get. So blame your government, not Toyota. BTW, the revamped test procedures result in a rating of 48 MPG overall for the Prius, more in line with what people are getting. These results are to be used/reported starting with the 2008 model year. While it would be more "honest" if Toyota reported the new numbers now, it would be against the law.
I own a freestyle, and it is not close. BTW, before discussing the two vehicles, they really shouldn't be compared; they are completely different classes, and serve different purposes. Having said that a comparison is foolish, here is a comparison
- The FS can seat 7; don't try that in a Prius.
- The FS has 22 Cu Ft behind the 3rd seat. That is more than the 14.4 Cu ft of the Prius. So it can carry more luggage than the Prius even while carrying those 7 people.
- 47 Cu Ft behind the 2nd seat - so that is with 5 passengers. This is probably the fairest comparison, since the Prius seats five (with 14.4 Cu Ft of luggage). The FS thus has three times the luggage capacity of the Prius with the same number of passengers.
- 86.1 Cu Ft behind the first row of seats. Would you believe that the official Toyota site does not list the cargo volume of the Prius with the rear seats folded? Neither does Edmunds. However I would wager it is rather less than 86 Cu Ft, since the total interior volume for Prius is listed at 96.2 Cu Ft.
MPG wise, yes, no contest - if you are only carrying 5 people and 14.2 Cu Ft of luggage, or two people with ??however?? many Cu Ft there is in a Prius with the back seats flat. If you are carrying 5 on an extended camping trip, or if you have a larger family, other vehicles are more appropriate.
However, you should note that I get around 23 MPG mixed driving in my 2006 FS SEL, maximum of 32 MPG on pure highway (yes, that is not a typo - 32 MPG at around 60-65 MPH - but I seldom drive that slow. My usual Interstate MPG is 26.5 @ 80 MPH), and around 20 MPG for all-city mileage. Driving style is important, and mine is an FWD as well, which gets a bit better MPG than the AWD. BTW, I have gotten as low as 17 MPG when I drove the FS hard... but I don't drive that way as a rule.
Enjoy your Prius. It is a fine vehicle for what it was designed to do.
It is not that great on safety as mid sized cars go. It is 4 star rated by the NHTSA with SABs. Most current mid sized sedans are 5 star rated. Even the Honda Civic Hybrid is safer than the Prius.
You have to remember that the old 60 mpg city rating is required by the EPA. It's not Toyota's test it's the EPA's test. The manufacturer has no say in the matter.
The new EPA test is more reflective of reality but it's on the low side IMO. Almost all Prius drivers will exceed the new standards handily. Again these are the EPA's numbers not the manufacturer's.
The seat comfort issue is certainly subjective since coming from 4 standard model Camry's I like the Prius seating much better. Our Highlander ( RX330 ) is more comfortable for long trips though.
You very conveniently omit to use the harder and more up-to-date IIHS tests which reflect how most other nations measure their NCAP. There is a very good self-assessment of the NHTSA testing at: http://www.safercar.gov/NewCarAssessmentEnhancements-2007.pdf. The NHTSA discusses how it's own outdated testing might be brought up to current standards.
The more relevent testing for all vehicles is found at:
http://www.iihs.org
specifically small car ratings: small cars
Since the Govt's ratings are so outdated the only conclusions that can be drawn are Pass/Fail
4&5 stars are Pass
3 stars is marginal
1&2 stars are Fail.
In the report referenced above the NHTSA addresses this themselves say in effect ' Nearly all vehicles now are rated 4 & 5 stars by our tests yet severe injuries still occur so how relevent are our ratings'
4&5 stars are Pass
I also prefer the IIHS testing as it is more realistic in comparing econboxes to larger vehicles. You will concede that the Prius without the SABs is POOR by even IIHS standards. I am assuming the 2007 model comes standard with all the safety stuff.
The reason? Because of the long waiting lists, most buyers were able to essentially order the options packages they wanted. Also because the Prius attracted a different kind of buyer (not necessarily interested in lowest transaction price), side airbags were commonly ordered. I understand the installation rate on 2006 models was 92%.
And I will reiterate that the difference between 4 and 5 stars in the NHTSA tests is not significant. This is especially true in the side test where HEAD INJURY measures are not even figured into the star ratings.
BTW, every car the IIHS has side-impact tested without side airbags has rated Poor, but there are a handful of SUVs and minivans that have scored above Poor without side airbags.
With regard to fuel economy, the car is simply the most fuel efficient vehicle sold in America today, with EPA city/highway estimates of 48/45 mpg, under the "new" testing regimen for 2008 models.
Critics had pounced on the fact that few Prius drivers could attain the "old" city rating of 60 mpg. However, this was not the fault of the car, but rather the government testing procedure which was developed long before gas-electric hybrid cars were on the drawing boards.
The last great advance was the side impact air bags (for the shoulder/torso) and side curtain airbags (for the head). The current great advance is active headrests and other gear to minimize damage to the occupants from rear end collisions.
I'm not negative on any of this, I just find it funny how people forget so soon the good ratings a car design got when it was introduced.
One very important fact people should keep in mind, is a "safe" car is not necessarily going to be inexpensive to repair after a collision. It usually sacrifices itself to save the occupants. So repairs, if possible, will be expensive. Not a bad thing, just one to always keep in mind. Maybe drive a little slower.
I know what you mean, I had an Odyssey minivan for a long while, but once the kids got out of the strollers, it just seemed way too big.
Still, I like to keep a perspective on the use of vehicles, and how each one has it's purpose. Often times these hybrid forums enthusiasts get, well, a bit enthusiastic. :P
Have a look under the hood. The only belt-driven thing on the ICE is the ICE water pump.
The computer keeps saying I am getting 50 + MPG.... So I put gas in the car 2 times to verify this.
Once at 300 miles ( took 6 gallons ) and again at 450 miles ( took 3 gallons ) So the computer seems to be right on.
I drive in the city most of the time AVG 35 MPH.
Took one highway trip of 150 miles at 65 MPG.
So far, I love the car!!
You are saying the opposite.
The better city mileage is not because it runs on the battery. Common misconception. It's because you don't have a large loss due to air friction. The Prius, unlike "normal" cars, can take advantage of this by shutting off the engine while stopped at lights etc. and can recover about 50% of the energy lost while stopping (regenerative braking). The 50% figure allows for losses in recharging and then discharging the battery, as well as losses in the motor/generator. This makes the statement "running on the electric motor" partially true, but it is just an assist.
On the highway, you will still loose energy from running the A/C, but you will do so for a shorter time period/mile. You can't take as much of an advantage over a "normal" car re energy recovery and engine shutdown. So the overall mileage tends to be lower, but not always. In nyprius' case, anyway.
I average better in the city (4.2 l/100 km or 56 MPG US) than the highway (4.9 l/100 km or 48 MPG US). But it's not that hot here, so A/C isn't that big a load, and I don't sit in NYC style traffic.
Having lived/worked in NYC for 30+ yrs I took my Prius back to replicate my former commute to Downtown. Going across town from light to light to light to light gives horrible FE, say in the 30-35 mpg range. However turning N or S on one of the major Avenues and just staying with traffic at ~25 mph or crawling on the FDR at 10-20 mph gives a FE of 65-75 mpg.
Generally, it's a fun car to drive and a real pleasure in cities and towns. On long stretches of interstate where the posted speed is 75 mph, not so much. Over 70 mph your mileage numbers are penalized by wind/drag as noted elswhere on this site. And the seating is troublesome after a 10 hours or so. On the days where we had lots of stops, sightseeing, activities, etc. it was no problem. But for the big-mileage days I was wishing for our Volvo seats.
Using an 8gb iPod Nano connected with a $9 Radio Shack auxiliary cable we had plenty of new music. I've complained in other posts about audio quality in the "upgraded" system that is part of the #4 package and learned with many days in the car that tweaking the settings made a big difference depending on individual recordings.
Our trip took us from Colorado to Oregon and back through Wyoming, Utah and Idaho. As you know, the west has been brutally hot the past few weeks. Big kudos for the climate control system which works well and cools the car down quickly. However, the big, black dashboard is a big, black negative acting as a heat-sink even when the AC is on. Next time you've parked out in the sun awhile and are back in the car hold your hand out over the dash: the heat will be radiating up from below your hand, not down from the window. Next accessory purchase: Prius-specific windshield sun screen.
We got a 10k mile required oil change and service at a dealer in Bend, OR which resulted in quite a sloppy mess under the hood and with them reducing the tire pressure to spec which we promptly re-inflated to 42/40.
One thing about driving all day and visiting friends and relatives with this car is that once you get there they then want you to drive everywhere for the novelty of riding in a hybrid and/or the sheer economy. But then there was the one 20-something hotel front desk guy in Boise, ID that said "what's a Prius"?
It was great fun pulling up to river to fish and pulling out a fully assembled 9-foot fly rod while guides and clients had to re-assemble rigs broken down to fit into pickup trucks and shorter rides. But leather seats would have been preferred under a butt damp from wet-wading.
The last night out found us in Rock Springs, WY very late where absolutely no motel rooms were available. A call east to Rawlins revealed only of $112 rooms at an "Econo"Lodge that we wouldn't have made it too until well past midnight. In the true spirit of a road trip I decided to make for an I-80 rest stop where I found a dozen or so other folks in the same predicament along with another dozen truckers who probably were regulars at this stop. Hey, it was safe, well-lighted and had a bathroom.
The good news is that the Prius passed the "sleep-test" -- and with flying colors. Typically a night in the car is about waking up every hour or so to fidget and shift while taking a peek for first light. That night in Wyoming I overslept through sunrise and the starting engines of the departing motorists around me. Was I tired? Evidently. But being able to fold those front seats down flat surely helped.
Arriving home with 2/3rds of a tank remaining the trip's fuel costs were $184. Fabulous. Best price: $2.88/gl with full service as is the rule in Oregon. Heading west with wife in the car, avg. 51.5 mpg. Returning east after flying her home in advance, avg. 53.5 mpg. No wife jokes, please ;-) She's already hating her new nickname, "Ms. 2mpg".
That's it from me as I migrate toward the "Old Prius Owners -- Give Us Your Report" section.
-Phil
