So, is your Nav System still working? Do you still disable the Motion Interlock feature?
Steve
This only works on the 5.1 version of the Nav DVD - not 6.1 (but there is a way around that too).
http://www.wikihow.com/Override-Toyota-Prius-Navigation-Gray-out
says it should ...
Steve
http://www.clublexus.com/forums/showpost.php?p=2141921&postcount=122
Was that an 8-Track?
Sorry, couldn't help myself, just had to say that
Hummm.
http://www.lehigh.edu/~sol0/Toyota/2007-Camry-SLI-Install.pdf
Sometimes when it is really cold overnight (usually for a few days) when I start my camry for the first time it forgets ALL my radio station settings, and previous GPS locations. It remembers however my Favorite buttons.
What the heck is going on? I dont want to bring my car into the dealer and have them keep it, and them never fix the problem. Especially considering I don't get a loaner car unless they say it is going to take more than 24 hours (but I don't know that until after the service is done)
seth
1 - I've tried to hook up an MP3 player (Ipod) to the AUX input in my 2007 TCH. I thought that file & folder information was supposed to show up on the screen (I have Nav system). Only info on screen was "AUX is in play mode". I tried again with a Zen player, and same message appeared. Am I doing something wrong?
2 - Is there any (safe)way to override the feature that blocks the navigation and audio controls that are blocked while the car is driving? It is a pain to not be able to at least have a passenger use the system while I am driving.
James
I've tried to replace the "DASH" with "HYPHEN", "SLASH", "SPACE", and have even tried to speak the address without any punctuation (ex: "ONE" "ZERO" "TWO" "THREE" "SIX") but then the system tells me that no such house number exists.
Any imput is welcome!
James
Also, the new radios are not as powerful as the older models so some shops may want to install a booster for the signal. Great, but you have to turn off Sirius when you want to listen to regular radio. My guys circumvented this by adding a connection to my rear window defroster... blew me away. Just wish Toyota would not list XM/Sirius on the sticker as it is very misleading.
I have the Stiletto 100... there are some really small units that these auto shops can hide really easily. I happen to like the features of the Stiletto.
I do not know if there is a way to upload pictures... if there is I would show you the set up.
Let us know what you find out. Good Luck :shades:
I hate the XM programming with no DJs and no Howard Stern
The Cds are "originals" having the required logo on the front label so I assume it must be the unit.
It seems that all else works with the radio and navigation system.
I will be taking it to the dealer over the next few days and I'll post the results for those who have the same problem.
Gampa
It is like the player interferes with the car's audio system - any ideas, or similar experiences?
Thanks for your time.
Should I have bought the power supply/output combo, instead of simply the output plug? Is the iPod unable to send a strong enough signal without a power source? I tried different levels of "ASL" (including "off") to no avail. Any thoughts would be greatly appreciated.
Tim
First let me address how the satellite integration into the navigation head unit leaves a lot to be desired. Even though the head unit has a seven inch display, the Toyota truncates the text at ten characters, and only displays the title and artist.
Second, the installation options of the Toyota factory satellite antenna kit are at a level well below what I have observed at even Circuit City or Best Buy. In my previous experience all factory installed satellite antennas were integrated into the roof line and had wiring which was routed internally to the vehicle head unit. This was also the case in the factory unit which I retrofitted into my new (at the time) Jeep Liberty. Even the Circuit City unit installed in my truck hides the wiring unobtrusively and has a very small physical antenna.
When I picked up my Camry following the installation of the satellite receiver I didnt even think to look at the antenna installation. It was only after I noted that the quality of signal was worse than any of my previous experiences that I actually looked for the antenna. I had assumed it was part of the headliner and/or embedded in the front window. Imagine my surprise when I found a large clumsy looking unit sitting on top of my trunk lid.
Cosmetically it looks like an after thought. No real effort other than color matching was given to the aesthetics of the design. However, what is even worse is the draping of the antenna wire into the trunk. When the trunk lid is opened about eight inches of wire rise with the lid. Its only the artful bending of the wire that ensures it will drape back down into the vehicle when the lid is then closed. Incredible. That level of engineering (or lack thereof) is far surpassed even with a Circuit City antenna.
Lastly, the reception on the Camry factory satellite receiver is the POOREST I have experienced, bar none. In my other vehicles there are two locations through which I regularly travel where Sirius and XM both briefly lose the signal in the shadow of a large set of hills. In the Camry the signal regularly drops out in flat and level countryside with a degree of frequency which make it not worth the effort of listening.
Satellite radio is an important part of the experience I expect from any vehicle I own. Based on my expectations of quality from the Toyota brand, this was a complete surprise. I had anticipated a seamless integration into the onboard electronics and an engineered installation that would appear to have been carefully considered rather than a slapdash attempt to place an antenna.
I had hoped to find that the rudimentary satellite display integrated into the head unit, and the amateurish design of the antenna are just lower levels of options perhaps intended for an entry level vehicle and that a higher degree of integration of both form and function are selectable. But apparently this is the best that Toyota has to offer. I had the satellite receiver removed from my vehicle.
Toyota responded to my issue by directing me via a canned response to Sirius. No acknowledgement was made of the poor offering sanctioned by Toyota. How did those other car manufacturers coerce Sirius into providing a higher degree of integration? Why would Toyota allow a third party to damage their reputation?
Sirius gave me another Toyota phone number. That number gave me another Toyota number who claimed he would call me back in an hour. That was 7 hours ago.
Has anyone experienced a similar problem and/or has anyone swapped out the antenna?
It is clear that this is causing the reception problem, perhaps it works fine in other parts of the country, not so in North / Central New Jersey. Like many, I installed satellite radios in my other cars with roof mounted antennas and never experienced this level of reception problems.
So now I have three options, since I mostly use the car for freeway driving anyway just learn to live with it, go back to Toyota and expect a prolonged and frustrating runaround based on macmook's and others experiences, or just put in a roof/trunk mount external antenna and go on with my life.
A final option is to have my wife deal with Toyota's service department as she enjoys these kinds of battles more than I do.
