Pontiac G5 Coupe
Has the Pontiac G5 Coupe begun to arrive at dealerships yet? Will there be a manual shift option?
Greg
Anyone know whether or not the G5 coupes and sedans will be made in Lordstown, Ohio--or in Canada?
There were some features of the radio that I never did figure out... not too intuitive.
Heavier weight leads to a smoother ride...I'll have to try that line when i sell my 5600lb pick up.
Maybe they can add the gaudy hoodscoops and wing too (as an option, of course)? My lady likes them a lot on the GTO and the G6.
A few comments: I had to adjust the seat and it was very difficult with the door closed... the space between the door and seat was very tight. Seemed to be a big blind spot to my left... I turned to look over my left shoulder for a pass, and all I saw was B-pillar and headrest. I thought the big spoiler would bother me through the back window, but it didn't. Getting in and out of the back seat... UGH. But that's a coupe. Main gripe: the doors are BIG and trying to open them in a tight garage or parking space will be a problem. I illustrated it to the dealer (opened it two feet, the space in my garage) and barely had enough room to squeeze out with some contortion. Of course, they thought it was fine since they wanted a sale.
For anyone who owns a G5 (coupe or GT), can you comment on these issues for you as an owner? Is getting in and out a difficult exercise for you?
Tony
Thank you:) :confuse:
You may have blown a fuse, or the electric motor may have gone out on the power steering.
GM may view this issue as "the car is still drivable" without power steering.
I believe there is a factory TSB Service bulletin on this problem.
I'd say its downright dangerous.
i built a g5gt coupe in 2007 black inside an out all the bells and whistles. At 23 miles the wipers flew off the car in a snowstorm it was 45.00 and change to replace them at the dealership. at 123 miles the gasket seals on the doors fell off replaced under warranty.
the following are all under warranty:
on jan 23rd 2009 the stereo sytem sensor blew replaced also cracked the molding over the glove box also replaced ,now there is a hum when air or heat is on.
two weeks later the gas sensor blew also replaced (my best epa is 19).
the dash and stereo fashed like a disco ball very hard to see or so bright it hurts your eyes and is distracting while driving.
i have had all new brakes tires rotors twiceand they still are not that great.
i was almost killed once when the emergency brake failed it has been fixed,replaced and fixed again resolve to issue by dealership is to park on flat ground always,so i have.the front panel fell out while driving a new one will cost me aprox 200.00.
the wiring under the driver seat shorted ,it was repaired by electic tape i am suppose to keep an eye on it and let them know when the tape needs replacing.
in july of this year the oil in engine compressed so badly the dip stick was broke during removal if i want a new one it will cost me (not covered) compression test resulted in as inconclusive they can't explain what happened.
i am so heartbroken i built this car my first new ever.
i stopped going to dealership they laugh at me now. at this point i am spending 300.00 a month for gas to drive approx 400 miles a month.
unfortunatley on black friday my heat shield fell off had it riveted thought i was good to go.
saturday i got in the car smell of gas gave me bad headache took it back to dealership for a little over 900.00 i can have the catalytic converter replaced no warranty,even though the law says 8 yrs 80,000 miles for design defect.which it is all one piece unit to get to flex hose converter needs to be removed.
in short this has to be the biggest piece of junk out their.
anyone else have issues like these??? i would be interested in knowing i am in conversations with pontiac and plan on contacting the attorney general and epa commission on this vehicle.
i have spoke with dmv lemon law agents and still no where close to resolve.
Anyone else have water leaking into their car?
A few issues I had. I figured I'd post these to see if others have these before I go to the local dealer to get them resolved:
- When I park the car and leave, I hear a pinging under the car. Sounds like the exhaust system is cooling down and there is metal on metal, pinging as it cools down. The pinging slows down as the car cools down until it disappears. My old Cobalt did the same thing. Anyone else hear this? Is this just normal?
- My stereo has only 5 pages of presets instead of 6 for some reason. My old Cobalt and the Saturn Aura we own have 6 (same GM radio).
Good luck to those who own the G5! Nice car.
http://detnews.com/article/20091123/AUTO01/911230402/GM-sues-supplier-over-$30M-- spent-on-steering-repairs
Where to start?
Doors: Are definitely several inches taller and longer than 2 door coupe cavaliers. If you're short, be prepared to have to struggle to reach window at any drive thru. Also, I have noticed when in parking garages, I am struggling more to avoid hitting other cars in those tight spaces. You need a lot of space to avoid banging other cars when opening doors. They open up really wide! This car is hard to get out of in my tiny 1 car town house garage. Was never an issue with my cavalier.
Storage: center cup holder from older cavaliers gone. Hear it is missing in newer cobalts too. Only storage in interior is a shallow, barely there center bin. More like a shallow tray with a lid. No center cup holders. Basically no storage in entire car interior. Parking brake is now in center & not to the side like old cavaliers so by making it be dead center, the crappy, barely there storage tray is not made very deep and is set way back nearly behind the front seats.
Seats: Are rock hard and flat, no contor and no give or cushion softness. They are rock hard and your back will hurt on road trips over an hour or two. They are also this light-ish gray. It feels like sitting on a metal or stone bench. My old cavalier was a dark super textured gray. They were also cushion-y with some give to them. It didn't show any dirt at all. But this car is light gray and has a smooth texture with a slight sheen. I have only driven it a few days and I can already see every spot. Bottom of seats are very tall and even lowering seat down nearly all the way only make my short legs bent and hard to reach pedals. Forget about any storage under seats.
Roof: Inside roof is a light, creamy type gray that shows stains easily and clearly was only designed to make inside look bigger. No thought given to how easily it shows stains.
Gear Shift: Short and designed like race car. If you have short arms, hard to reach down to easily reverse, park, etc.
Dash/Speedometer/Steering wheel: Has unneccessary high arch in dash above speedometer that hinders view for short people. Speedometer lights are weird red color. Wheel tilts up and to center level but not down.
Trunk/Rear Area: Back end is tall and sloped up higher than front end. View is also hindered by rear view area (between back seats and rear view window) that slopes upward. Also, tall spoiler makes it even harder to see.
I am 5 feet even and this is car from hell. It is so umcomfortable to drive and adjusting seats does not help because I need to lower seats to make legs comfortable but that hinders view over dash and side windows. Maybe if you're 5'4 or 5'5, it is the perfect fit but for the 5"2 to 4"11 crowd, do not get this car. I hate it so much and can't afford anything else.
Radio - Too complicated if you are not a big music person. Has 6 pre-sets that are always shown on screen. No way to clear out and make it look more streamlined or remove from screen except to turn off radio. Stereo has a million buttons and a barely there volume knob that's hard to grip and adjust while driving. Time clock is oddly located to far right side of stereo, far from driver side.
Don't believe the lies. This is NOT the same thing as a cobalt or cavalier. I have driven coupe cavaliers for 12 years. I can tell that too many areas are higher positioned.
( you may want to consider applying to the federal government for permission to have a shop disable your drivers airbag? )
Hope the accelerator and brakes in your car are GM parts.
If GM (and their dealers) want us back down the road to buy a new car, they still have to treat Pontiac and Saturn owners well, and I got good treatment. I'm not worried about the new recall. When you're driving at higher speeds, losing power steering, if you lose it, is not a huge deal. You can still steer the car. It's when you're driving really slowly that power steering helps. If you're driving really slowly, I doubt you'll be in a catastrophic wreck. Unlike Toyotas that accelerate to 100 mph and don't respond to brakes. Now that is a big problem. Glad I got my GM.
"Roof: Inside roof is a light, creamy type gray that shows stains easily and clearly was only designed to make inside look bigger. No thought given to how easily it shows stains."
How does one get stains easily on your inside roof?
"Radio - Stereo has a million buttons and a barely there volume knob that's hard to grip and adjust while driving. Time clock is oddly located to far right side of stereo, far from driver side."
First of all, the volume knob is a huge knob in the middle of the radio. Plus, you're complaining about the clock display being oddly to the far right? This radio does not have a million buttons (Toyota's have a ton of buttons on their consoles, try one and you'll see, Pontiacs are really straightforward). In fact, this radio allows you to set your presets so you can mix AM, FM and XM and create banks of stations based on music, news, etc. It's easy to program (read the manual). In any case, the radio is a standard size (not built in like Hyundai, for example) so when you have some money saved, you can replace it with another radio you like.
"I am 5 feet even and this is car from hell. It is so umcomfortable to drive and adjusting seats does not help because I need to lower seats to make legs comfortable but that hinders view over dash and side windows. Maybe if you're 5'4 or 5'5, it is the perfect fit but for the 5"2 to 4"11 crowd, do not get this car. I hate it so much and can't afford anything else."
As for the seats, get cushioned seat covers at Walmart. That should make things feel better for you. Some places sell pedal extenders, so you can reach the pedals better without adjusting the seat so far down.
All in all, should have test drove it and said, "this isn't the car for me". If this was the only place in town to buy a car, ask Dad to take you to the next town.
Good luck with the G5 anyway. Hope you can make some adjustments and like the car a little more.
For hitch mount or roof mount there are many options.
"in july of this year the oil in engine compressed so badly the dip stick was broke during removal if i want a new one it will cost me (not covered) compression test resulted in as inconclusive they can't explain what happened. "
Please explain as this makes no sense whatsoever.
"i stopped going to dealership they laugh at me now. at this point i am spending 300.00 a month for gas to drive approx 400 miles a month. "
So back in 09 I will guess gas to be $2.50/gal?
According to your figures , this would mean your car was getting only 3.33 MPG.
(And 4 MPG if you had paid $3./gal)
Re your post...
Hmmmm.....
Did they ever find a solution? I have a 2009 G5 and just noticed a leak in the trunk that I think might be coming from the satellite antenna, but I'm totally freaked out about it.
