Toyota Sequoia Real World MPG
Please report on your gas mileage - tell us about your driving style, city/highway mix, mods, odometer, octane used, or anything you think will help others compare their mpg to yours. Thanks.
try it. it is a modest investment for the results.
check AMSOIL. it is a oil that has to be bought through a dealer, not off the shelf. the guarentee is unbelievable. priced competively. i use it in my Porsche turbo, ford festiva, and toyota highlander. i have used it for too many years to remember. it has never let me down.
i'm anxious for the new sequoia. i got a feeling it is going to be too pricey. it will be replacing or into that land cruiser/lexus money. too bad!
Amsoil synthetic oil. K& N filter. Goodyear TriPlex tires.
Awesome vehicle; now if I can get my rear lift gate handle replaced without losing a finger I will be good to go.
Are the 08's supposed to get better gas mi than previous models?
The methanol mixed gasoline will cost you 2-3 mpg.
How do you know if E10 is in your Gas - Assuming there is a sign etc... or all gas in state XYZ has E10?
Will have to look at the gas when I get back to Cali - perhaps I'll be stuck in the 12MPG as well.... have not pulled the trigger on an 08 yet - did not really consider MPG before but at this point I'm wondering if I should start.
City: 11-14mpg depending on how aggressive I drive, its hard to not dip into the HP
Highway 65-70ish: 18-19mpg
Highway steady 80mph across SD, MT: 17mpg
The highway mileage was with 7 passengers, gear, hitch mounted cargo box, so a full load.
Fuel was 87-89 octane, probably some tanks were a 10% or less blend of alcohol.
I removed the carbon filter from the airbox at about 1000 miles, did seem to improve highway mpg by about 1mpg. At the the 5 k service, replaced oil with 5-20 castrol synthetic.
Bottom line is that you can achieve reasonable fuel economy with this vehicle if you go easy while accelerating, but it will suck gas big time when you put your foot in it. But, it sure is great to feel this thing get up and go when you do stomp on it, so I definitely enjoy 'hypo'-miling in it as well as trying to squeeze 20mg out of it on the highway.
